What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3 ... 34, 35, 36, 37, 38  Next
chrisurban
chrisurban is offline
PostPosted: Mon Feb 27, 2023 10:45 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Marcdeb wrote:
The numbers "4 65" is for April 1965 I believe. I'm not 100% sure, but it does not look like it matches the 65 Ghias.
I’m wondering if this is from a Type 3 Ghia - I don’t recall the early Ghias having the shift pips.
FunkyOldPatina
FunkyOldPatina is offline
PostPosted: Tue Apr 11, 2023 12:22 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Is this for a KG oil bath setup? It looks to be but I've not seen the exact same part in the classifieds or on a google image search?
Thanks all.
PostPosted: Tue Apr 11, 2023 2:14 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Yes, Ghia and Bus 1500cc piece for on top of the carb.
1966 Ghia example from Gallery
FunkyOldPatina
PostPosted: Sat Apr 15, 2023 9:28 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks Everett!
It was the rubber tube on the right of the part that had me confused Smile
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Sun Apr 16, 2023 1:58 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I know what this is and I know where it goes, but what years and which side?
The metal screen is about 6" wide, 3" high, 4 1/2" deep.
Maybe it's left over from when I owned a '61? I had a '70, but those screens were plastic.
c21darrel
c21darrel is offline
PostPosted: Sun Apr 16, 2023 7:12 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
The ones with an upper case "L" go on the left side. The ones with an upper case "R" go on the right side. Wink
It looks a little bent, i have a couple that are more rectangular. I couldnt get the 3rd screw out to determine L or R, one way the screw holes line up, the other fits but screw holes dont line up. Sorry not more help Chuck. Maybe once the "Blaster" seeps in...
GhiaBuild
1967 DC build
Samba Curmudgeon
iowegian is offline
PostPosted: Mon Apr 17, 2023 4:20 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
There is no "L".
There is no "R".
There are no screw holes.
It might be slightly bent, but the lower right corner is 90 degrees (+/- 15 minutes) while the included angle of the lower left corner is 60 degrees.
EDIT: this must be left (driver's) side isn't it?
Loren Premium Member
Loren is offline
PostPosted: Mon Apr 17, 2023 11:35 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
That is for the driver's side. It's for a low light Ghia. 60 on up Ghias had rectangular openings on the screens.
Samba Curmudgeon
iowegian is offline
PostPosted: Mon Apr 17, 2023 4:54 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks Loren---I have no idea how I ended up with a Low-Light part. Confused
kingkarmann
kingkarmann is offline
PostPosted: Tue Apr 18, 2023 6:12 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Perhaps we may talk about in the "Example of Overpriced Ghias & Ghia Parts" thread? Very Happy
Samba Curmudgeon
iowegian is offline
PostPosted: Tue Apr 18, 2023 9:07 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Indeed.
I was thinkin' about a hunert and fitty bucks. Laughing
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Apr 18, 2023 9:16 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
iowegian wrote:
Indeed.
Come on Chuck you can do better than that, we're talking about Overpriced Ghias & Ghia Parts. Very Happy
John.
FunkyOldPatina
PostPosted: Wed Apr 19, 2023 3:23 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Really struggling with this torsion bar/rod.
Its 59cm/23.25 inches long and approx. 1.5 inches max diameter.
and I can't think what it would fit. Is it a late Ghia part please?
wagen19
wagen19 is offline
PostPosted: Sun Apr 30, 2023 11:22 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hi, torsion bars 590 mm long are for type 2, march´55 till july 67
FunkyOldPatina
PostPosted: Wed May 03, 2023 3:56 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thank you wagen19, you're a star!
Cheers dude Cool
blue72beetle
blue72beetle is offline
PostPosted: Mon May 15, 2023 2:58 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Is this the reverse light circuit?
-Andy-
-1970 Ghia-
-1971 Bus Ongoing EJ22 Conversion-
Disc
Disc is offline
PostPosted: Mon May 15, 2023 10:56 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Yes, it is.
The glory never gets old, just need new paint.
Nick
pizza442
pizza442 is offline
PostPosted: Mon Jun 12, 2023 12:30 pm    Post subject: What's this Ghia part and Where does it go? Reply with quote
I know these look familiar but not having a car to run over to check, I can't think of what these knobs are for?
Peeteboy2
Peeteboy2 is offline
PostPosted: Thu Jun 15, 2023 8:42 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Not sure if I'm posting this correctly but any idea what these are exactly. Thanks 68 Coupe
sputnick60
sputnick60 is offline
PostPosted: Thu Jun 15, 2023 10:25 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
The edge trim for the kick board. passenger and driver footwell.
Discussed here, for a "66 but should be very similar to your '68
https://www.thesamba.com/vw/forum/viewtopic.php?t=711310
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Page 35 of 38
