Dan22 Samba Member
Joined: August 30, 2019 Posts: 678 Location: Battle Ground, WA
sunroof Samba Member
Joined: October 06, 2006 Posts: 2052 Location: Winnipeg
Posted: Mon Jul 08, 2024 10:13 am Post subject: Re: Field find 1954 Canadian custom |
Quote: |
Don, is it the same motor? |
Yes, it is the same motor. She put up a hell of a fight but she is sweet as anything now. The latest is that I had to replace the intake due to a big hole in the heat riser. The good news is that it idles and runs noticeably smoother now.
The bad news is that the diaphragm clutch has got to go. Really hating on it now.
Don _________________ Better and better mistakes! |
Posted: Sun Aug 04, 2024 1:10 pm Post subject: Re: Field find 1954 Canadian custom |
Looking at the VIN of my car and the tables here in the Technical section and doing a little math and guesswork I have determined that today is the 70th birthday of my little car whom I call Betsy.
Happy birthday old girl!
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11340 Location: Huntington Beach, CA
Posted: Mon Aug 05, 2024 9:18 pm Post subject: Re: Field find 1954 Canadian custom |
Happy Birthday! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Sat Oct 26, 2024 3:32 pm Post subject: Re: Field find 1954 Canadian custom |
The '54 report:
Betsy got some new parts!
Confession time. When I repaired the A pillars I did not brace them up and the whole front of the car dropped about a half centimeter causing the door bottoms to rub on the heater channels. Not much, just enough to take off the paint. Lesson learned. Anyways the door bottoms needed to be replaced due to hinge problems and rust so I bought Virtanen's ribbed door bottoms intending to do the job myself
https://www.thesamba.com/vw/classifieds/detail.php?id=1453062
https://www.thesamba.com/vw/classifieds/detail.php?id=1895664
But I could not figure out how to approach the problem so things sat on the shelf for over a year. In August I had a brainwave and took the car to a buddy of mine who has a body shop in his back yard and he agreed to tackle the door bottoms for me. This is a guy who only takes on projects that interest him so I was pretty stoked that he said yes. Well I got the car back today and am pleased beyond measure.
You can see the line where the new panel starts
Wow. That was worth every penny
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7535 Location: Houston, Texas
Posted: Sat Oct 26, 2024 3:53 pm Post subject: Re: Field find 1954 Canadian custom |
A diamond in the ruff! _________________ www.vwnos.com [email protected]
Busstom Samba Member
Joined: November 23, 2014 Posts: 4583 Location: San Jose, CA
Posted: Sat Oct 26, 2024 6:31 pm Post subject: Re: Field find 1954 Canadian custom |
Bodyline creases look really good, lined up nicely. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
cory464 wrote: |
if you aren't perfectly centered in the hole you will have issues when you tap it. |
Posted: Sat Oct 26, 2024 10:32 pm Post subject: Re: Field find 1954 Canadian custom |
That came out great!
Did he cover it with aluminum tape? _________________ Jimbo
TDCTDI wrote: |
Posted: Sun Oct 27, 2024 2:59 pm Post subject: Re: Field find 1954 Canadian custom |
Not sure what you mean
Posted: Sun Oct 27, 2024 11:10 pm Post subject: Re: Field find 1954 Canadian custom |
Maybe a reference to the foil-backed panel damping material inside the door  _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
cory464 wrote: |
Posted: Tue Oct 29, 2024 8:51 am Post subject: Re: Field find 1954 Canadian custom |
Anyways, further to the '54 report
I debated with myself for a while about replacing the door cards. They were pretty stained and worn out but sort of matched the body. However with the purchase of the type 3
I have decided to sell the beetle. To that end it was necessary to spend the money to get the door bottoms done and make new door cards.
Before:
Here we see the badly damaged hinge mount and my futile attempts to get things to line up. Replacement really was the only possibiliyt
After:
In order to repair the mistake I made with the lower hinges Peter had to drop the hinge about 1/4" to get the doors to fit. Also the hinge mounts in the doors were badly distorted from years of people (me) opening and closing the doors with seized hinges. Also also the door bottoms were rusted through so Peter took care of several problems at once and did a beautiful job. However! This raised the door bottoms by 1/4" so I was pretty worried the new door cards would not fit. OY!
So I was pretty happy with this:
I think that went well.
Posted: Tue Oct 29, 2024 9:59 pm Post subject: Re: Field find 1954 Canadian custom |
Busstom wrote: |
Maybe a reference to the foil-backed panel damping material inside the door  |
Exactly!
Selling? What? Good for you! I will miss your updates. Good luck and I hope it sells quickly and for a higher price than what you set it at! _________________ Jimbo
TDCTDI wrote: |
AlteWagen Troll
Posted: Sat Apr 12, 2025 7:18 pm Post subject: Re: Field find 1954 Canadian custom |
So my buddy Scott is restoring a '54 deluxe
https://www.thesamba.com/vw/forum/viewtopic.php?t=797788
But it came with a set of standard wiper blades. As soon as I saw them I said I want those. So we made a swap and now I have these:
They will go perfect with my car
Super stoked
AlteWagen Troll
Posted: Fri May 02, 2025 8:32 am Post subject: Re: Field find 1954 Canadian custom |
Quote: |
I may be mistaken but are those 59 up symmetrical wipers? |
I think you are right. I could only use one arm, the other was the same and pointed in the wrong direction. Good spot.
Anyways I was cleaning my windshield and broke the third and last WW reproduction wiper base, those things really are shit. I took the opportunity to install my "new" wiper bases
I think I will have to paint the blades black to match.
Anyways, these NOS SWF wiper bases now go to Scott's '54.
A good swap, happy to get the black ones.
Posted: Tue May 20, 2025 9:28 pm Post subject: Re: Field find 1954 Canadian custom |
Well rats, the generator pulley destroyed itself.
I ordered a new one from Kaefer-nostalgie. I just hope he didn't put it in the mail.
Posted: Fri May 23, 2025 7:38 am Post subject: Re: Field find 1954 Canadian custom |
I bet I could model one of these shims in solidworks and send it to someone with a laser and cut a couple out in the same thickness as the pulley. Then find someone with a lathe to cut the center out of the pulley then find someone with a TIG to weld the new centers in. Hmm, I will have to look into that. The lathe and the solidworks are easy but the laser and the TIG might be a little more difficult.
Also my buddy Jay has a '57 that he has had since he was 15, I remember meeting him then and how proud he was of the car. Fast forward to today and he is now 53 which means he has had the car for, hmm, lets see, where's my calculator... 38, yes, 38 years. Anyways he is not good around a wrench so he has asked me to rebuild his carburetor
Happy to help. I quite enjoy rebuilding 28PCI. Anyways he called me in a panic the other night because his car wouldn't start, turns out it was a stuck needle valve (float valve) so time to rebuild.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11322 Location: Oregon
Posted: Fri May 23, 2025 10:54 am Post subject: Re: Field find 1954 Canadian custom |
There's always Send Cut send to laser cut your design.
I know how you folks up north feel about the US currently. Maybe there is a company there that can preform the same type service for you, without the tariff bullshit.
https://sendcutsend.com/?srsltid=AfmBOoqVLFpcu3wkerXzP5BKzaZK2IjBaVtzEF6qUwpcWaOrW7C1YwLE _________________ I have learned over the years.
Buy Once, Cry Once!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
