Sodo Samba Member
Joined: July 06, 2007 Posts: 10617 Location: Western WA
Posted: Wed Jun 11, 2025 1:56 pm Post subject: Re: Which Transmission Rebuild Shop? |
Phishman068 wrote: |
Realistically if you haven't shifted in the past hour, you're cooking your transmission. No one should be cruising in just 4th for that long. |
I wish we knew how long it takes 4th gear to dry out and begin to get hot.
Because it does show "heat".
I wonder if it's "minutes" such as 10, 20 minutes?
I did a rather significant test once, placing a temperature sensor in the path of the oil spray coming off 4th gear. See: https://www.thesamba.com/vw/forum/viewtopic.php?p=8945649.
See the verdict: https://www.thesamba.com/vw/forum/viewtopic.php?p=9257995
The test was only for a few minutes (like less than 10 minutes) and did NOT show 4th gear getting hot.
But we know some gearboxes have melted (plastic) needle bearing cages.
Looking back at this.....maybe we needed to "Wait longer for 4th gear to deplete its oil then get hot".
And THEN, the oil spray (off a hot 4th) hitting the specially-positioned sensor, would confirm suspicions.
And we'd KNOW how often you should do a "decel", or better yet, a downshift.
But dangit, back in 2020 we hadn't connected the dots WRT 4th depleting oil over time.
(never letting up, like cruise control would do). _________________
....KTMs, GasGas, SPOT mtb |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17127 Location: Brookeville, MD
Posted: Wed Jun 11, 2025 2:21 pm Post subject: Re: Which Transmission Rebuild Shop? |
Sodo wrote: |
I wonder if it's "minutes" such as 10, 20 minutes? |
My cooler returns the oil right on top of 4th gear so I hope that helps a lot. _________________ Dave O
The Western Syncro build
Sodo Samba Member
Posted: Wed Jun 11, 2025 3:29 pm Post subject: Re: Which Transmission Rebuild Shop? |
dobryan wrote: |
Sodo wrote: |
My cooler returns the oil right on top of 4th gear so I hope that helps a lot. |
4th gear dries out on the inside and at the bearing thrust surface. Due to the helical gear thrust that presses 4th gear hard against the mainshaft bearing.
Dave your straight cut 4th gear has no helical thrust against the mainshaft bearing, thus the gap opens & closes (probably at random?), even with steady throttle for hours (in 4th). That's the entire reason for the 'straight cut'.
I don’t think you have any worries about 4th gear drying out. It would be best if your oil return was blasting the oil at the gap between 4th and the bearing, instead of the gear teeth. _________________
Sodo Samba Member
Posted: Wed Jun 11, 2025 3:35 pm Post subject: Re: Which Transmission Rebuild Shop? |
Bill T:
Stock is .85. .82 is referred to as "a taller 4th gear" but it's only 3.5% taller.
Some say "longer 4th".
1.8Turbo has such a fat lump of torque at ~65-70mph, I will guess that .82 is a good 4th ratio. But some people with a 1.8T might prefer a .78 to drop the RPMs at 70mph.
.78 is a little harder on your transmission though.
at 3500RPM, stock .85 goes 70mph, .82 goes 72mph, .78 goes 76mph
You wrote that you have a GT 4th gear? I think a GT 4th gear is probably better than a Weddle 4th but we don't really KNOW that unless people start taking gearboxes apart and specifically comparing wear. Weddle gears have not been great for longevity. Weddle are made for racing thus softer, to resist breakage. Think of it like a plexiglas mirror vs glass mirror.
Depending upon the usage, if one is correct material then the other was wrong.
GoWesty races their Westafari Van in Baja. We don't race.
GT Gears are probably better for us RV-drivers who prefer a "hardened gear" to be longer-lasting.
We accept the risk of breaking (in a long off-road race).  _________________
Bill D Samba Member
Posted: Wed Jun 11, 2025 4:32 pm Post subject: Re: Which Transmission Rebuild Shop? |
Some say "longer".
You wrote that you have a GT 4th gear? |
Yes, my .82 4th is a GT gear. But I was wondering if, in light of my tranny problems at only 30k miles, changing back to the stock .85 would be advisable and or significantly easier on the tranny? Even before my tranny problems, I was kinda thinking when driving up over mountains that I regretted changing from stock (having to downshift to 3rd sooner). (but then again, maybe having to downshift out of 4th is a good thing after reading about not driving over an hour in 4th It was Stephan's recommendation to go t the .82, but he drives a lot in flat Sacramento whereas I live in the mountains... perspective... 95% of everything )) |
Bill D Samba Member
Posted: Wed Jun 11, 2025 4:37 pm Post subject: Re: Which Transmission Rebuild Shop? |
Do you guys thin that adding a Peloquin or other LSD during my current tranny rebuild would unnecessarily complicate things and/or create yet something else to fail?
Would a Peloquin make is less likely that I get stuck in deep sand?
Would it complicate or interfere with a filter/cooler system?
thanks,
Bill D |
Sodo Samba Member
Posted: Wed Jun 11, 2025 6:02 pm Post subject: Re: Which Transmission Rebuild Shop? |
At 3500RPM, stock .85 goes 70mph, .82 goes 72mph
Not worth spending another $570 on a different 4th for a difference this small.
That's if your 30,000 mile GT 4th is still in nice condition.
I would tend to agree with Stephan that the FAT torque of the turbo would be good with .82.
Yes don't be averse to downshifting. Proper smooth downshifting.
FYI .78 goes 76mph at 3500RPM. You would feel that difference.
Downshifting periodically is good for a Vanagon gearbox, it floods the inside of 4th gear with oil.
But you gotta be a "good downshifter" to have a net gain in gearbox happiness.
A periodic 'decel' helps too, but nothing like downshifting.
A long decel in 4th like downhill is probably good.
This video shows the gap that opens up. 4th gear moves to the left when you "decel".
Downshifting to 3rd also pulls 4th to the left, and freewheels 4th on it's needle bearing too.
Perhaps for a longer period, perhaps allowing more oil to enter 4th gear.
Peloquin does not complicate anything.
Peloquin is pretty important if your van does NOT have a locker.
If your van already has a locker, the Peloquin will barely make any difference.
If sand is something you need to prepare your van for, you need a "Solid Shaft" and a decoupler.
If you see other cars driving on sand, your Syncro can always do better.
It's when you DON'T see any other cars, or ONLY 4X4s with wide tires.... that you need to consider the solid-shaft. _________________
Bill D Samba Member
Posted: Wed Jun 11, 2025 6:54 pm Post subject: Re: Which Transmission Rebuild Shop? |
If your van already has a locker, the Peloquin will barely make any difference |
Yea... my van has a 'locker'...
But I NEVER remember to use it... lol.... I just don't use it because I don't think of it...
My understanding is the Peloquin sorta works on it's own without having to do anything to engage it?
Are there complications of having both a Peloquin and a 'locker' ???
b[/b] |
Joined: January 01, 2007 Posts: 17823 Location: sticksville, ct.
Posted: Wed Jun 11, 2025 7:21 pm Post subject: Re: Which Transmission Rebuild Shop? |
I'm a firm believer these systems were designed to REV.
Lugging it in a higher gear, or even changing the gearing to allow for it to go to an even higher gear load- only increases the stress on the transmission (and the engine). 4500RPM is better for transmission life than 3500RPM.
^^^^this
Everyone wants to cruise at 400 rpm at 90 in 4th. It doesn't work that way. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Sodo Samba Member
Posted: Wed Jun 11, 2025 7:29 pm Post subject: Re: Which Transmission Rebuild Shop? |
Bill D wrote: |
Are there complications of having both a Peloquin and a 'locker' ??? |
No complications to having both Peloquin + locker.
I have both on front and rear.
Video of 9 passes.
This is a Syncro with rear drive disconnected.
So it's a "front wheel drive only" Syncro.
You can see that the Peloquin does "something" on its own...
but its contribution is almost "nothing" compared to Pass#9 "locked".
If you're gonna buy a Peloquin I'd get one for the front when it's front-rebuild time.
Then you have Peloquin on the front and VW locker on rear.
GT makes a similar diff too.
They are not a TBD, nor an LSD, but people refer to them as such.
There is an LSD that fits the Vanagon, but it's not strong enough for the Syncro Granny gear. And there's no repair parts,,, so if you bust it.....deepshit. _________________
Bill D Samba Member
Posted: Wed Jun 11, 2025 7:46 pm Post subject: Re: Which Transmission Rebuild Shop? |
Quote: |
Video of 9 passes.
So it's a "front wheel drive only" Syncro. |
I don't understand...
How can you 'disconnect' rear drive?
And even if can, somehow, is there still drive going forward?
Thru VC? or was that eliminated?
Honestly, I must be tired because I'm not noticing big differences in the videos... and not sure differences would not be due to slightly different paths thru the gravel... or due to the gravel being churned up or rutted differently in previous 'passes'... Tired, I guess... and confused...
b |
Sodo Samba Member
Posted: Wed Jun 11, 2025 7:56 pm Post subject: Re: Which Transmission Rebuild Shop? |
I took out all the 6 bolts of one rear CV joint.
then the rear was just free-wheeling, just rolling.
Not pushing.
I agree it's not easy to see the behavior.
You have to watch for dust and rocks being thrown up by the slipping tire.
You should rebuild the front diff while it's still quiet.
I did mine at 225k miles and the builder told me I caught it "just in time";
that my R&P was still good but bearings were getting loose and would have ruined my R&P if I drove it until it vibrated.
And I thought I was being "highly prudent".
He said I was "a little prudent".
There are no more front R&Ps, make sure yours has good bearings to protect your original R&P.
If you have a vibration at 60-65mph, that behavior is "emerging theory" as "front diff needs rebuild".
Front diffs get ruined when the Viscous Coupler leaks silicone into the oil, degrading the oil, then the bearings and gears wear out.
So you should change front diff oil often just in case the VC is leaking.
If the VC is kinda old you shou;ld assume that its ready to leak anytime.
More likely if it got abused by wrong size tires etc sometime in it's lifetime.
If it's leaking there will be a black coating on the fill plug (and everything, blackened oil).
So on the front you need to be hyper-observant for blackening.
Don't just "have a guy change the oil".
"The guy" needs to know how to look for blackening.
The Silicone VC fluid is clear when new but very pitch black when old.
When you do the front diff you will have to decide what kind of (rebuilt) VC to use, "normal", "sport" or "solid shaft". _________________
Bill D Samba Member
Posted: Wed Jun 11, 2025 8:01 pm Post subject: Re: Which Transmission Rebuild Shop? |
I can see now that we are not dealing with just any normal person here...
a true Vanagon fanatic! ))
b |
Bill D Samba Member
Posted: Thu Jun 12, 2025 9:02 am Post subject: Re: Which Transmission Rebuild Shop? |
Quote: |
When you do the front diff you will have to decide what kind of (rebuilt) VC to use, "normal", "sport" or "solid shaft". |
What is a "sport" VC ???
I assume "solid Shaft" means eliminating the VC?
Not sure I need a rebuild 'normal' VC as mine was replaced at about 105,00 miles... (still have that old one in a box)... and the replacement now has about 80,000 miles on it...
b |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18695 Location: Retired South Florida
Posted: Thu Jun 12, 2025 10:01 am Post subject: Re: Which Transmission Rebuild Shop? |
Bill I know you were asking about reputable rebuilders originally. But I had the impression the shop that did your conversion was sending it back to the original rebuilder. If, that’s the case, I’d wait for the autopsy before deciding on add ons. There may be some good will if just a main bearing has failed. A Peloquin for example on a fresh rebuild is more work to do correctly. Unfortunately the Peloquin dimensions are not exactly the same as the stock locker, so there is more labor involved$ vs just swapping out a mainshaft bearing. The builder might have some flex on cost.
I had a pro built transaxle for my TDI by one of the vendors mentioned. I got about 60k before it started jamming in forth gear.
I purchased the special tools and am doing my own now. I have a combination of stock parts, parts from Weddle and from GT Gear. I feel I have better control over workmanship and I’m not paying crazy shipping fees.
I don’t have any special cooling system. I see hoses, pumps, coolers, etc as points of failure. I also don’t use all the power I have available all the time. I’m actually gentle on it compared to some of my other fleet. I intend to tear it down at 60k to see if mainbearing wear is improved. |
Bill D Samba Member
Posted: Thu Jun 12, 2025 10:56 am Post subject: Re: Which Transmission Rebuild Shop? |
Quote: |
A Peloquin for example on a fresh rebuild is more work to do correctly. Unfortunately the Peloquin dimensions are not exactly the same as the stock locker...
...I don’t have any special cooling system. I see hoses, pumps, coolers, etc as points of failure. |
I don't understand your comment on Peloquin dimensions not exactly the same as the stock locker... ??? Is this a matter of 'mating' up the Peloquin with the locker? Or replacing? Please explain.
Yes, I have concerns about added hoses, pumps, coolers, etc as points of failure... especially if one of those hoses were to break, then all the tranny oil would be on the ground fairly quickly...(maybe especially concerning for off-road 4WD where something could kick up and cause damages)... if any of it clogged or just stopped working, seems to me I'd just be back to a non-modded tranny and the temp gauge would show that... but a broken hose would be catastrophic... still... the engine has hoses that could result in catastrophic failure also... |
Posted: Thu Jun 12, 2025 11:25 am Post subject: Re: Which Transmission Rebuild Shop? |
There are a few critical measurements and adjustments when changing a ring and pinion or the stock differential housing/peloguin.
For the differential, you have to set bearing preload and ring gear backlash. It’s often ok just to mark the side bearing housings prior to disassembling and if it was setup correctly and those parts aren’t changing to reassemble using those markings.
The Peloquin is slightly wider than the stock carrier and so you likely can’t reuse those marks and would to go through setting bearing preload and backlash vs just checking it.
If pinion bearings and ring gear bearings are being replaced or the actual ring and pinion or a combination, you are setting pinion depth, bearing preload, and backlash from scratch and that would be the time to swap in a Peloquin locker or other type. It takes a lot of time to get this correct.
If just the mainshaft bearing as suggested has failed, that could be a much quicker job and possibly the original rebuilder would make a deal. Something like they pay for the part and you pay labor. Or maybe a discount on the labor. No way to tell at this point. It’s all speculation.
Certainly if the transaxle is disassembled, that would be a good time for any internal upgrades. GT, I believe German Transaxle has made a big investment in the 091/1 and 094 transaxles with gear options, shaft options, billet housings and hubs. That is not who built my original transaxle. I used a pro originally because I did not have the special tools. As I mentioned the tools were less than shipping 2 ways and I’ve since built my syncro transaxle and my camper transaxle.
There are quite a few members here that have the skills to rebuild their own. The special tools is the barrier. Otherwise there are no snakes and spiders hiding in these. I’ve come across way more difficult ones to rebuild. |
