surfindo Samba Member
Joined: March 11, 2004 Posts: 442 Location: Haarlem, Netherland
Posted: Fri Dec 30, 2005 7:07 am Post subject: 48DRLA |
A V8 guy told me he has 4(2set) 48DRLA that mounted in rover engine but the engine never put back to the car so the carbs is new(his version) after bit inspection I cant really tell that the carbs never touch the petrol, is there any way to tell this??, what is good price for good used 48DRLA??? just the carb no linkage/intakes etc.I own bus so I dont familliar with this size of carb.other question this carb been stored dry from the 80s(as he said) do i need to buy rebuild kits to change the seals??
thank
Happy-new yeaaaaa. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15605 Location: Deep in the 405
Posted: Fri Dec 30, 2005 7:58 am Post subject: |
One way to see what something is worth is to look in the classifieds here on the Samba, or on eBay and see what they are selling for.
Yes it is possible that they could need new gaskets and O rings after sitting on a shelf for 25 years. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Fri Dec 30, 2005 9:17 am Post subject: |
Ok thanks for the reply, been search in samba and ebay but not much 48 on the sale except new one with intake and all the kits ready to bold-on.other question since the 2 carbs are conected together for the V8 engine,do you think some parts been changed like the idle throtle adj lever??? I also notice that the main air corector are very short compare than my drla 36 ?
thank for the info. |
RIS Samba Member
Joined: December 18, 2003 Posts: 3044 Location: Youngstown, Ohio
Posted: Tue Jan 03, 2006 3:15 pm Post subject: |
| surfindo wrote: |
| since the 2 carbs are conected together for the V8 engine,do you think some parts been changed like the idle throtle adj lever??? |
Some of the V8 linkage will need to be discarded, depends on how it's set-up. I believe CB Performance sells a kit with all the throttle shaft levers to use in a dual carb VW application.
| surfindo wrote: |
| I also notice that the main air corector are very short compare than my drla 36 ? |
I've seen short and tall air corrector jets, shoudln't be a problem - all DRLA jets are interchangeable. _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
Posted: Tue Jan 03, 2006 4:12 pm Post subject: |
| Thanks RIS you answer my 2 post, I found a guy In Italy he will rebuild my 48DRLA and put the missing parts,I have 4 of them now and 2 without throtle return springs. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17700 Location: Left coast, Canada
Posted: Wed Jan 04, 2006 2:46 am Post subject: Re: 48DRLA |
| surfindo wrote: |
| I cant really tell that the carbs never touch the petrol, is there any way to tell this??, . |
What happens when you stick your nose down them and take a whif? |
Posted: Wed Jan 04, 2006 10:29 am Post subject: |
yes Bruce that the easy way, I wasn't sure after 20years+ I can still smell petrol, but now I bought 4 of them only 2 come with return spring and find out the set up for V8 engine change some parts in lingkage/thorotle shaft.
thanks |
