Kadrons? How the heck do you get to that mix screw?
Jerry J
Jerry J is offline
PostPosted: Sat May 23, 2009 4:09 pm    Post subject: Kadrons? How the heck do you get to that mix screw? Reply with quote
Ok I searched dozens of thread here and in the bug section but couldn't come up with what I needed.
I can see and get the idle mix screw on the passenger side carb but the screw on the drivers side is mostly hidden by the fan housing.
How do I get to that idle mix screw on the drivers side? Or do I just need to buck up and do the best I can. These carb have been adjusted before... how did they do it?
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
dubkrzy
dubkrzy is offline
PostPosted: Sat May 23, 2009 4:24 pm    Post subject: Reply with quote
Take the filter off, and use a long handled screwdriver Wink
vwracerdave wrote:
always modify the cheapest part and never modify the most expensive part.
Glenn wrote:
Sure... you can take a grinder to them. You can also use an adjustable wrench to assemble it.
Jake Raby wrote:
That looks like Tom Jones
DarthWeber
DarthWeber is offline
PostPosted: Sat May 23, 2009 5:49 pm    Post subject: Reply with quote
Yup, that's what I used, a loooong skinny shank screwdriver, like a 12 incher. Never had to take off the air filters on my Ghia though.
mharney
mharney is offline
PostPosted: Sat May 23, 2009 5:52 pm    Post subject: Reply with quote
Go to the hardware store and get a drywall dimpler tool (simple one, with a bit pressed into a centering collar), and get a flat head bit (shorty, like the phillips bit), and the slot not being the style that is wider than the hex portion). Take them home and drive the phillips out backward with a vise. Then drive the slotted one in roughly flush or a little less. It'll help you center on the screw a lot easier.
Very Happy Twisted Evil
My daughter wanted you to see those faces.
Jerry J
Jerry J is offline
PostPosted: Sat May 23, 2009 9:59 pm    Post subject: Reply with quote
Taking the filter assembly off was the only way that I could even see the screw. Or at least see how tough it was going to be to get to.
I finally found my really long slot screwdriver. I was able to get a very slight, maybe 1/8th turn on the screw to turn it out. The engine is running pretty lean and dying everytime I came to a stop. I didn't get to road test my adjustments today but will give it a run this weekend.
I may have try that drywall dimpler. That's a slick idea. I had to look up what exactly a drywall dimpler was.
Thanks guys!
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
mharney
mharney is offline
PostPosted: Sun May 24, 2009 8:25 am    Post subject: Reply with quote
What I left out was that you need one of those bit style screwdrivers to put it in. Works great. I can work blind with that and get to it.
= joy!
Das Dragon
Das Dragon is offline
PostPosted: Sun May 24, 2009 12:42 pm    Post subject: Reply with quote
I made this device 7 years ago:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=216505
Rest In Peace HamburgerBrad, we will never forget you!
_________________________________________________________
DB3 said:
"Awesome!!!
*********'s constant over-estimation of his own importance never ceases to amaze me."
With *****, "Bullshit Happens"!
1961bluebug
1961bluebug is offline
PostPosted: Sun May 24, 2009 12:56 pm    Post subject: Reply with quote
you need to take the filters off and use long thin screwdriver..ut it is always a bit of gynekology... Laughing
