Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11807 Location: Redding, CA
Posted: Sun Jan 17, 2016 12:38 am Post subject: Rear alignment? Really? |
After I get my new front end stuff installed, new wheel, etc., the new alignment shop I'm going to wants to do a "rear" alignment, as well as the front alignment.
Is this just up-selling? My tires have shown no unusual tire wear in the rear, so is this really necessary? I've never had the rear of any of my bugs aligned at the rear.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17658 Location: Left coast, Canada
Posted: Sun Jan 17, 2016 2:51 am Post subject: Re: Rear alignment? Really? |
Do you think your rear suspension has sagged a bit in the last 40 years? If so, the rear wheels are not aligned to the same specs as what VW did when they first built the car.
Given the amount of trouble you've had with your car's suspension, getting the rear aligned is a good idea. For your own information, maybe you should mark the relationship between the spring plates and the trailing arms so see how much they get adjusted.
Here's a tip. When you get the car aligned, tell them you would like to sit in the car while they do the job. Your weight affects the wheel alignment. Bring a big newspaper.
If the shop is really good, they will also measure the ride heights of all 4 corners and correct that during the alignment. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Sun Jan 17, 2016 3:57 am Post subject: Re: Rear alignment? Really? |
I think it's up selling.
I doubt you can get $1000 of labor for the $89.95, errr $109.95 4 wheel job. Chances are they will set the toe, of course it will be off with human weight added. |
KAmes Samba Member
Joined: February 16, 2014 Posts: 917 Location: Illinois
Posted: Sun Jan 17, 2016 3:58 am Post subject: Re: Rear alignment? Really? |
| I recently ran into this with my Thing after replacing tie rods. I asked the alignment shop to set my toe in, and they came back like this wasn't possible unless they did a full four wheel laser alignment. It's not that I minded the idea of it and I wasn't concerned about the cost, what bothered me was I'm not ready to tear into the rear suspension at this time when things break due to corrosion or cannot be properly set due to being 43 years old. My rear tires are wearing normally and I feal more comfortable leaving well enough alone until I'm ready. I ended up doing it myself with a tape measure for now. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Jan 17, 2016 4:01 am Post subject: Re: Rear alignment? Really? |
| well yeah it's impossible to align a car - properly - without referencing off the rear axle... |
thechief86 Samba Member
Joined: January 18, 2012 Posts: 860 Location: middle tn
Posted: Sun Jan 17, 2016 4:45 am Post subject: Re: Rear alignment? Really? |
I've done 120k miles in my car with just tape measure alignment since 2005, and my tires dry rot before they wear out. I'm more or less of the idea that the car is so light that tires seem to just last longer... _________________ "A poor workman always blames his parts... Ya gotta have skillz to hang junk." -johnnypan |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Sun Jan 17, 2016 7:45 am Post subject: Re: Rear alignment? Really? |
yes, you need to do it now cause it's in your head  _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
Posted: Sun Jan 17, 2016 10:55 am Post subject: Re: Rear alignment? Really? |
What's in my head is that I don't need a four-wheel alignment. The front end alignment is all I need.
Richard O'Brien |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2931 Location: Germany
Posted: Sun Jan 17, 2016 11:40 am Post subject: Re: Rear alignment? Really? |
| Tim Donahoe wrote: |
Tim |
How far out of alignment did they say the back was? Oh... they didn't check. So maybe it's fine and u don't need one. That's more of this shit, telling you they have to do something when they don't know whether they need to or not. Tell them NO and check it at home. _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
miller0358 Samba Member
Joined: November 07, 2007 Posts: 1200 Location: northford,ct
Posted: Sun Jan 17, 2016 12:13 pm Post subject: Re: Rear alignment? Really? |
| I've also been told that on a super you should have a full tank of gas and add your weight under the front hood if you can't sit in the car for the alignment. It makes a big difference in the stance of the car for adjustment. I put a couple of bags of cement in the front and full tank. I don't know how it would handle not doing this, but handles pretty good doing it.m Jeff |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5576 Location: Lefty, CA
air-h2o-air Samba Member
Posted: Sun Jan 17, 2016 9:05 pm Post subject: Re: Rear alignment? Really? |
4 wheel, if not your (pardon the french) your half azzing it....rear is adjustable, and rear can create a tendency to drive the car left or right...google "thrust angle"...read what it does and how it can effect the driving/handling and you will see why you need it.
If all the past alignments did not include rear adjustment, or even rear readings...you did NOT get a proper alignment (IMO) |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3543 Location: Houston, TX
Posted: Mon Jan 18, 2016 10:34 am Post subject: Re: Rear alignment? Really? |
Tim-
I normally get the "life-time alignment" (for as long as you own the car) from Firestone for $130, it pays for itself after 2 alignments.
And, I do sit there, and watch them.
Last time, they almost aligned it as a Standard Beetle, with front torsion bars (not the super beetle)
Also, they had trouble seeing the adjusting slots on the rear spring plates (they were covered up by the bolts)
You kinda have to sit, and tell them what to do with these older cars sometimes. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
VWCOOL Samba Member
Posted: Mon Jan 18, 2016 5:15 pm Post subject: Re: Rear alignment? Really? |
| miller0358 wrote: |
This is how to do it when on-road performance/road-holding is important.. such as a track car or serious fun road machine
Ensure all suspension bushes are fresh etc first and ensure the ride heights are even side-for-side with the driver in the car... this will usually mean the driver's side will sit a little higher (8mm) with no-one in it
VWCOOL Samba Member
Posted: Mon Jan 18, 2016 5:17 pm Post subject: Re: Rear alignment? Really? |
| post delete |
VWCOOL Samba Member
Posted: Mon Jan 18, 2016 5:25 pm Post subject: Re: Rear alignment? Really? |
| Volks Wagen wrote: |
Tim |
How far out of alignment did they say the back was? Oh... they didn't check. So maybe it's fine and u don't need one. That's more of this shit, telling you they have to do something when they don't know whether they need to or not. Tell them NO and check it at home. |
Odd tyre wear, vehicle crabbing and handling issues can be symptoms...but it's impossible to check without putting the vehicle on the alignment machine...
Volks Wagen, what process do you use at home for wheel alignment? In particular, how do you get a car squared, front-to-rear?
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Mon Jan 18, 2016 6:50 pm Post subject: Re: Rear alignment? Really? |
| I have a friend whoose bug dog tracks about 4" or more. Ive seen cars out of wack that dontn wear the tires.these are light and may not wear the skiny tires so you can tell it's off. but yes it should be checked ad adjusted if they can properly do it. the wider the tire the more importaint it is. what you dont need to happen is it to drive just fine then hit the breaks in the rain and WEEEEEEEEEEEEEEEEEEEEEEEEEE. you can also look at it with you eyes and possiably see it's out.(if you know what your looking at it's eazy to see in most cases) you probably should inspect the bushings first and replace them if needed(rubber or poly torsion/ swing plate bushings) the outers are eazy to change, inners a bit more diffacult. |
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Wed May 29, 2019 12:23 pm Post subject: Re: Rear alignment? Really? |
It's not like anyone here knows what to do and spelled it out for us is it?
I was wanting to get my new to me 1960 VW beetle handling right and have yet to do some pretty basic things like new tie rod ends and rear end bushings but after setting my front toe-in I measured the distance between the front and rear axles after trying to drive it as straight as possible before stopping and just jacking up the side I wanted to loosen those 3 big axle tube nuts on and kicking the axle housing forward to match the other side. But it's going to take another try because it's still about 3/16" longer on the passenger side. Was 3/8" though.
But what else can be done?
On a early bug the torsion bar suspension tucks the rear wheels in anytime the car goes over a dip in the road surface even at highway speeds. Sometimes it feels like the car takes a new heading coming out of a dip or bump if the lay of road on a curve is weird.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Wed May 29, 2019 1:01 pm Post subject: Re: Rear alignment? Really? |
| VWCOOL wrote: |
Tim |
Volks Wagen, what process do you use at home for wheel alignment? In particular, how do you get a car squared, front-to-rear? |
Well, I missed this Q 2 yrs ago. I use fishing line, a level, a few bits of timber, a carpenters square and a few measurements. I did the last one on uneven ground. Worked out fine, but I had to take a while to level out the car's base with bits of planks. After that...
First measure I make is from hub centre to hub centre at the back. Then I half this and run a fishing line from the centre at the rear at right angles to the rear axle (use the square first) up under the car to the front. I have to fiddle this until it's true (Trigonometry) and then I peg it in the ground.
Then I run 2 more fishing lines against the rear wheels/tyres up to the front and check they are parallel to the centre line. So this gives me a test for parallel rear wheels, and square chassis, front to rear. The rear toe measurement on the Citroen I did was ideal at 0 with a small negative camber. If there's toe on the rear wheels you'll find this with the strings and compensate to get parallel lines to measure. If you have to, then run the fishing line back away from the rear wheels to get your measures for rear toe. Trigonometry.
After this it's a straightforward case of setting toe up front for me and measuring the camber against the specs. Small bit of maths and a few longish bit's of fishing line to get the toe angles accurate (use TAN). Then mark the wheels on the ground, take it out for a drive and see how it feels, repeat and adjust accordingly until I'm happy. Ride height I eyeball, and body level also, but I'll use the level across the flat of some area at the rear and across the domstrebe up front if in doubt.
Does me fine. Last vehicle I did handled beautifully after it. I only do this once in a blue moon if I feel a car is not handling right or I notice odd tyrewear. _________________ 1973 1303 with AB-motor - sporadic
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4996 Location: Stuck in Ohio
Posted: Thu May 30, 2019 5:05 am Post subject: Re: Rear alignment? Really? |
From Bentley Orange, 12. Rear Wheel Alignment: Rear wheel alignment must be performed whenever you replace parts that directly affect the adjustment. These parts include the diagonal arm, diagonal arm bushings, spring plates, and torsion bar. Rear wheel alignment should also be carefully checked following accident damage to the rear or side of the car.
Based on that, my motivation for a rear alignment would be a lack of knowledge of prior owner work and maintenance, as well as the wear of bushings and sag of torsion bars over a 40 year period.
From Bentley Orange, 4 Strut Front Suspension 3. Front Wheel Alignment: The following preparatory steps are essential to accurate alignment measurements:... (2) Inflate the tires to specifications and unload the car except for the spare wheel and full fuel tank. Then jounce the car several times and let it settle into it's normal position.
It seems the specified numbers already contemplate the unladen vehicle.
Happy jouncing. _________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
