zadieman Samba Member
Posted: Wed Feb 22, 2012 11:39 am Post subject: Mahle pistons |
| Sorry to have to put this here, but nothing on a search and knew you guys would be able to help out. I am going to have a stock rebuild done of my 1600 FI engine. I have one company with stock 85.5 Mahle pistons rings and barrels for only 150?? I see others getting closer to 300 for this set. What could be different?? I am scared to pull the trigger and get the wrong parts. Thanks |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Wed Feb 22, 2012 11:46 am Post subject: |
$150 = cast, like the pistons that came from VW.
$300 = probably forged pistons. _________________
| Mitey62 wrote: |
| Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Feb 22, 2012 11:52 am Post subject: |
I rebuilt a FI engine for a customer up the road from me using AA's. AA's are fine for a stock rebuild if your on a budget. Shes been driving it for over a year now. You dont need forged pistons for yours if its all stock. _________________ 2276 IDA's 86C 11-1 DD
| Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Wed Feb 22, 2012 1:10 pm Post subject: |
| I would rather have the aa pistons than the steel skirted mahle ones. |
D/A/N Samba Member
Posted: Wed Feb 22, 2012 1:54 pm Post subject: |
| mark tucker wrote: |
Why so? |
Posted: Wed Feb 22, 2012 4:30 pm Post subject: |
| Now even more confused. Are there two different levels of Mahle piston sets??? Is there a different part number for the steel skirted ones that you are talking about?? They have AA pistons, but they are even less than the Mahle's. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Feb 22, 2012 9:15 pm Post subject: |
What are you talking about, the little tabs on the inside? That's not exactly the piston skirt... _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
| satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Wed Feb 22, 2012 9:23 pm Post subject: |
| whell where exzactly is it??? splain that. and aluminum & aluminum have the same expansion rates too dont they.the mahles cost more because there hard to get and they price gos up, Iv seen these cast mahles being sold as forged, there not.to me there junk.do they work? yes they will .are they coated as days gone by . no. are the aa's coated? all that I have seen are, but I havent seen the 85 or 87's. I have seen way tomany cracked pistons with the steel strap skirts. |
kubelguy Samba Member
Joined: July 24, 2006 Posts: 51 Location: British columbia
Posted: Wed Feb 22, 2012 9:51 pm Post subject: |
| I heard the Mahle pistons are supplied by AA. Too bad there isn't a stock set made in U.S.A. |
Posted: Thu Feb 23, 2012 3:57 pm Post subject: |
| Now you guys have me even more confused.Are there correct part numbers for the correct mahle 85.5 pistons, cylinders and rings that will be the best for my stock rebuild!!!! |
Posted: Thu Feb 23, 2012 4:00 pm Post subject: |
If you call the tech guys at cip1.com they are VERY helpful.
Ask for all the choices , ask their opinions. It's fast and easy. |
Posted: Thu Feb 23, 2012 4:23 pm Post subject: |
http://vwparts.aircooled.net/Mahle-Piston-Cylinder-Set-85-5mm-x-69mm-Cast-p/311-198-069fma.htm
genuine Mahle 85.5s are excellent P&Cs.
| zadieman wrote: |
_________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Thu Feb 23, 2012 6:42 pm Post subject: |
| well the set I got a month ago,(cust brought to me) looked like poop and were more than 10 grams appart, ended up getting another set to make 1 set close enough to balance. the wristpin bore had a big chamfer on some and a slight one on 1 side of 2. |
Posted: Thu Feb 23, 2012 6:48 pm Post subject: |
What set of pistons were they? |
Posted: Thu Feb 23, 2012 9:53 pm Post subject: |
| 87 mahles.cast. I dont think aa is suppling mahle, although mahle has a new facilty in china.(so I have read from something mahle put out) |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5066 Location: Madisonville, La
Posted: Thu Feb 23, 2012 10:07 pm Post subject: |
On the 2110 I just did the pistons were 9 grams apart as well...mahle forged 90.5 B's. Waaaaaay off. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Thu Feb 23, 2012 10:40 pm Post subject: |
there is a big price increase coming soon on the Mahle Cast 85.5s...... _________________ It's just advice, do whatever you want with it!
Posted: Fri Feb 24, 2012 9:27 am Post subject: |
| I think he paid 2x as much for these cast ones as he should of,and were told they were forged.I would be happy to use a better aa piston over the steel struted brazilla ones.wish I would of put 90.5,s in it.but that dog wont hunt. |
Posted: Fri Feb 24, 2012 10:21 am Post subject: |
| To me, they are junk. Do they work? Yes, they will. Are they coated as days gone by? No. I have seen way too many cracked pistons with the steel strap skirts. |
FFS- it took me 10 minutes to fix just that one line, learn how to type man!
Stop blaming pistons for your lack of tuning acumen, I've been boosting them for over 3 years now without a single issue. If you're blowing them up, you're running it wrong. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
Posted: Fri Feb 24, 2012 10:28 am Post subject: |
most people on boost make the mistake of running too much timing, and run too rich too. _________________ It's just advice, do whatever you want with it!
