Official Oval Convertibles thread and Registry
Page: Previous  1, 2, 3 ... 203, 204, 205, 206  Next
kaieric Premium Member
kaieric is offline
PostPosted: Sat Aug 26, 2023 1:39 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
done
7/1958 RSA Beetle Cabriolet RHD
2Dokas
2Dokas is offline
PostPosted: Mon Aug 28, 2023 7:20 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
Thanks!
Now all I need is a block of time to redo what I've done.
87 Doka 2WD Ej22,
56 Convertible
kaieric is offline
PostPosted: Mon Aug 28, 2023 3:39 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
i'm curious about to see how you did it your way! as i tried and retried, i'm not yet 100 % sure about my approach even when i feel that i didn't do it almost wrong.
grailoc
grailoc is offline
PostPosted: Tue Sep 19, 2023 12:09 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
kaieric wrote:
done
where did you purchase all of your windows rubber? Wescoasmetric ?
That is what I need to do on mycabrio this winter.
thanks.
/Jerome
My 59 low light ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=452128
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
My oldspeed 36hp autotechnik express build: https://www.thesamba.com/vw/forum/viewtopic.php?t=670827
My garage build: http://www.garagejournal.com/forum/showthread.php?t=199438
Skim
Rants Master
Skim is offline
PostPosted: Wed Sep 20, 2023 4:51 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
Door reflection with Doug & Randy Very Happy
GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
kaieric is offline
PostPosted: Thu Sep 21, 2023 2:05 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
incredibly shiny!
kaieric is offline
PostPosted: Thu Sep 21, 2023 2:15 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
thanks.
/Jerome
they are pleinly available in europe.
you might try it here https://www.veteranen-service.de/e/index.php
if you need any help please let me know.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Thu Sep 21, 2023 10:17 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
Just came by this one today, another SK white vert. Looks like a 57 in a 58 issue.
Official Dual Carb Thread
2Dokas
2Dokas is offline
PostPosted: Fri Oct 06, 2023 4:19 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
Here's my window rubber and door sag....
this piece is trouble no way yet to get it to stay in place.
The passenger side is pretty good. I have about a 1/2cm difference between the front and rear window frames. The rear is higher but is adjusted as low as the frame can go with the 2 screws that hold it in place.
The drivers is not as nice and is about 1/2 cm lower than the passenger side as confirmed by the misalignment of the bottom of the door. Again, the drive side is lower.
Not sure what to do about it now, dont think I want to pull the doors and bang out the hinges.
87 Doka 2WD Ej22,
56 Convertible
aa390392
aa390392 is offline
PostPosted: Fri Oct 06, 2023 5:15 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
You know the right thing to do. Could it just be a door adjustment? A smidge?
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
kaieric is offline
PostPosted: Sat Oct 07, 2023 2:07 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
so you did decide to go this way along with the weatherstrip.
when i turned it to and fro and left and right, i found it would better suit the other way not letting a gap between the end of the chrome strip and the door edge. it clearly has a trapezoid shape that fits at its best when aligned to the door end, thus on the driver's side.
and yes, it must be glued in its place before fixing the chrome strip.
kaieric is offline
PostPosted: Sat Oct 07, 2023 2:25 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
2Dokas wrote:
indeed a bigger issue. had the body been modified?
BulliBill
BulliBill is offline
PostPosted: Sat Oct 07, 2023 11:38 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
Okay, while getting my '57 Kabrio cleaned up and having new W.W. pan halves installed (thanks Roy Jonas!!!) I noticed two holes in the horizontal surface of the luggage shelf behind the rear bench seat. The holes were slightly oblong in shape, about the same size and shape as each other and in about the same position on the left and right side of that area. I'm wondering if other 1957 Kabriolett owners noticed this on their cars or if some P.O. drilled these in for some reason. Any ideas after seeing the photos?
The general rear luggage area:
one of the holes:
look hard and you'll see both of the holes:
You don't get to see/check-out Oval Beetle Kabrioletts much in my area of the country, so any advice from Kab owners about these holes would be helpful. I'm eventually gonna need to either leave 'em alone or weld them up. Do they have a purpose?
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
kaieric is offline
PostPosted: Sat Oct 07, 2023 5:55 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
one of the holes:
Bill
these are equally existent on my 6/58 vert as well,covered by a type of bulge underneath the trunk panel. i never figured out for what reason they are in there.
in the pic attached you can perceive this bulge at 9 o'clock in the upper left above the gear bolt in top of the trans.
they seem functionless in every respect.
any idea?
56Cabrio
56Cabrio is offline
PostPosted: Sun Oct 08, 2023 12:23 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
Hey Bill, how are you ? My 56 convertible has them also. I’m pretty sure they are jig holes when the cars were assembled to keep everything in line during welding. I’m almost certain my 56 ragtop has them also, it’s in my garage at my other house or I would check. See if Martha has them ?
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
56Cabrio
56Cabrio is offline
PostPosted: Sun Oct 08, 2023 12:46 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
Here is a pic from valentinesr gallery of Delilah, it’s a 54. I’m pretty sure
Nelson Umana owns the car now. You can see the jig holes.
F#CK CANCER
Make a donation
1963 Hard Top
kaieric is offline
PostPosted: Sun Oct 08, 2023 5:33 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
sounds plausible. i had a slight estimation this way..
AlteWagen
Troll
PostPosted: Sat Oct 14, 2023 3:52 pm    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
Never seen this two tone combo before. Looks like ultra maroon, with body color logos.
kaieric is offline
PostPosted: Sun Oct 15, 2023 1:31 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
beautiful and unique outfit. note the beauty rings and black rims,probably ex factory.
interesting to see that secondary colour reached up beyond trims and met beading. never before payed attention to that.
56Cabrio
56Cabrio is offline
PostPosted: Sun Oct 15, 2023 1:52 am    Post subject: Re: Official Oval Convertibles thread and Registry Reply with quote
I would like see a pic of the dash, beautiful vert.
F#CK CANCER
Make a donation
1963 Hard Top
Page 204 of 206
