Difference in 6mm and 8mm oil pumps
jonnypink
jonnypink is offline
PostPosted: Mon Apr 27, 2009 5:06 pm    Post subject: Difference in 6mm and 8mm oil pumps Reply with quote
Does anyone know the difference in the oil pumps other than the stud size. I believe that the 6mm does not go in as deep, but want to verify.
66 Type I
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Apr 27, 2009 6:03 pm    Post subject: Reply with quote
I "think" the 6mm have 21mm gears and the 8mm have 26mm gears.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
AlteWagen
Troll
AlteWagen is offline
PostPosted: Mon Apr 27, 2009 6:48 pm    Post subject: Reply with quote
stock pumps are 21mm
Heavy duty pumps are 26mm
Pumps that are too big for most have 30mm
Official Dual Carb Thread
AlteWagen
Troll
PostPosted: Mon Apr 27, 2009 6:51 pm    Post subject: Reply with quote
I forgot, early pumps have a shorter shaft that engages the cam and are called "flat cam" pumps, you can tell if it is a flat cam if it has a bolt on gear or only 3 rivets. Later cams with 4 rivets are "dished" and need a longer shaft.
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Sat Jul 19, 2025 1:52 pm    Post subject: Re: Difference in 6mm and 8mm oil pumps Reply with quote
I’m swapping engines in a bug with auto stick. Going from flat to dished cam. So I exchange the short gear/shaft in the oil pump for the dished cam part?
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
Mr. 010
Glenn is offline
PostPosted: Sat Jul 19, 2025 1:59 pm    Post subject: Re: Difference in 6mm and 8mm oil pumps Reply with quote
I guess that's your only option since autostick oil pumps are NLA.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
zerotofifty
zerotofifty is offline
PostPosted: Sat Jul 19, 2025 3:17 pm    Post subject: Re: Difference in 6mm and 8mm oil pumps Reply with quote
Use some clay on the end of the driven pump shaft and do a mock up assembly then remove and look at the clay impression so you can see how much the drive engages. you want enough engagement, but dont wont zero clearance between the pump drive shaft and bottom of the cam gear slot. clay can be used for this purpose, clay aint only for Gumbie.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Cusser
Cusser is offline
PostPosted: Sat Jul 19, 2025 5:14 pm    Post subject: Re: Difference in 6mm and 8mm oil pumps Reply with quote
I did similar like 3 decades ago on a non-auto oil pump; actually it was a Claude's Buggies/CB Maxi2. I needed a Maxi2 for an engine with a dished camshaft gear, and would've ordered brand-new but CB was out of them/backordered at the time. So I took out the 26mm too-short gear and bought locally a 26mm VW oil pump for a dished cam gear, and used its long gear in the Maxi2.
3 decades, and it' been OK so far !!!
