mbvanagon Samba Member
Joined: December 19, 2008 Posts: 19 Location: Augusta, Missouri
Posted: Thu May 21, 2009 11:11 am Post subject: Fuel Filler Check Valve? |
I was doing the fuel tank re-seal thing today and after I pulled the filler-neck and got the tank out from under the van I noticed this little white plastic ball on the ground under there, kind of like a small ping-pong ball. The end of the filler neck that goes in the tank has a little cage on it so I popped the ball into the cage and I assume it's a checkvalve to keep gas from going up the neck. I hadn't noticed anything like this in the Bentley or on the posts I've been reading to help me with this job. Van's an '89. Any thoughts?
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19161 Location: Retired South Florida
Posted: Thu May 21, 2009 11:21 am Post subject: |
| When I worked at the dealer, there was a recall to add a flapper device to the fuel tank neck where the filler neck attached to prevent fuel from rushing up the neck when pressure was present on rabbits. I suppose it could have been introduced in production to other VW models once they knew there was a problem. |
allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Thu May 21, 2009 3:27 pm Post subject: |
When I took mine apart I assumed that was what it was for. Makes sense really. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
greebly Samba Member
Joined: August 27, 2009 Posts: 973 Location: Here and now
Posted: Wed May 11, 2016 12:24 pm Post subject: Re: Fuel Filler Check Valve? |
| What a waste of time. I found the ball inside my old tank as well. Does not serve much purpose if it does not remain in the cage. |
joetiger  Samba Member
Joined: January 27, 2005 Posts: 5276 Location: denver
Posted: Fri May 13, 2016 6:55 am Post subject: Re: Fuel Filler Check Valve? |
The filler ball was added in '88, apparently. I thought I'd gotten lucky at U-pull-it once and pulled a filler neck from an '89, only to find that the ball was gone.
I thought about trying a ping-pong ball but I'm pretty sure they're not gasoline resistant...
Here's a good thread on the subject.
http://www.thesamba.com/vw/forum/viewtopic.php?t=396064&highlight=fuel++filler++ball _________________ Joe T.
'02 Baja-ish Beetle "Bubbles"
Justice for Megan: https://linktr.ee/justiceformegantrussell |
bluebus86 Banned
Posted: Fri May 13, 2016 9:14 am Post subject: Re: Fuel Filler Check Valve? |
ping balls where used in wwii to fill the hulls and floats of seaplanes so that a bullet hole in the float or hull would not flood and cuase the aircraft to sink. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
