jasoncvw Samba Member
Joined: August 27, 2024 Posts: 7 Location: central Ohio
Posted: Tue Jul 29, 2025 5:06 pm Post subject: All lights on fuse 2 not working |
Hi group!
We recently brought this 1976 bus home. None of the lights on fuse two are working, but the lights on fuse one work fine. I tried swapping fuse one and two and it made no difference. Looking for advice on what to check next.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53262 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jul 29, 2025 6:02 pm Post subject: Re: All lights on fuse 2 not working |
Welcome!
After you clean up the tabs in the fuse box the fuses clip in to (especially the inner edges of the olse in them) report back, it should make a difference. But I also see what might be some funny business with the wire connections that are visible through the gap in the fuse box plastic, let's see the back of it please. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jul 29, 2025 6:48 pm Post subject: Re: All lights on fuse 2 not working |
| Thanks, I’ll clean the tabs and take a photo as soon as I can get out to the garage again. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42999 Location: at the beach in Northern Wokistan
Posted: Tue Jul 29, 2025 7:10 pm Post subject: Re: All lights on fuse 2 not working |
also buy a vom if you haven't gotten one. That way you can measure voltages. Or make a 12V light tester so you can chase voltage. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Posted: Tue Jul 29, 2025 8:17 pm Post subject: Re: All lights on fuse 2 not working |
I recommend junking the fuses that look like they have zinc strips and buying ones that have brass strips. Use a tiny amount of dielectric grease on the ends where the fuses contact the fuse holder. Spinning the fuses several revolutions once every year or so can cut down on problems as well.
The wiring from the #2 fuse to the marker lights runs near the starting battery and is thus subject to corrosion. You need to make sure the grounds for the lights are functioning well. |
Posted: Mon Aug 04, 2025 6:35 pm Post subject: Re: All lights on fuse 2 not working |
| busdaddy wrote: |
Welcome!
After you clean up the tabs in the fuse box the fuses clip in to (especially the inner edges of the olse in them) report back, it should make a difference. But I also see what might be some funny business with the wire connections that are visible through the gap in the fuse box plastic, let's see the back of it please. |
We got them working. I thought it was due to cleaning, but I wonder if it’s because there was a wire loose to the positive terminal on the battery. I was hoping to link the photos you requested of the fusebox, but I’m having trouble with the upload on samba. |
Posted: Tue Aug 05, 2025 5:12 pm Post subject: Re: All lights on fuse 2 not working |
| Wildthings wrote: |
There was a loose cable to the positive terminal of the battery. I believe that’s what sorted the parking lights. They are working again. Thank you. |
SGKent  Samba Member
Posted: Tue Aug 05, 2025 5:51 pm Post subject: Re: All lights on fuse 2 not working |
glad you found it. Perseverance paid off.  _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
