36hp Land Speed Challenge & Other VW Bonneville Classes
John Moxon Premium Member
John Moxon is offline
PostPosted: Fri Apr 01, 2011 5:16 am    Post subject: 36hp Land Speed Challenge & Other VW Bonneville Classes Reply with quote
This topic will provide quick links to general information relating to the 36hp Challenge.
It's not intended to cover everything written on the subject in The Samba's "Vintage Speed" forum, just a reference point on up to date regulations, results from previous years and video links to give you a taster of what it's all about.
If you require clarification on current 36hp Challenge regulations then I suggest you contact Burly Burlile either here by PM (36hplandspeedracer) or through his website: http://burlyb.com/
If you have technical questions you can probably find an answer by searching The "Vintage Speed" forum posts. If you can't find an answer in an existing topic post a fresh one.
Thanks.
36hp Challenge regulations: http://www.burlyb.com/
Utah Salt Flats Racing Asociation: http://www.saltflats.com/
Australia Dry Lake Racers: http://www.dlra.org.au/index.htm
2012 36hp Challenge and Bonneville World of Speed: http://www.thesamba.com/vw/forum/viewtopic.php?p=6248071
2012 36hp Challenge Specification Guidelines: http://www.thesamba.com/vw/forum/viewtopic.php?t=496963
2012 36hp Challenge Topic: http://www.thesamba.com/vw/forum/viewtopic.php?t=482895
2012 Big Block Bonneville Classes: http://www.thesamba.com/vw/forum/viewtopic.php?t=491927
2011 36hp Challenge Topic: http://www.thesamba.com/vw/forum/viewtopic.php?t=455822
2011 Australian LSR Topic: http://www.thesamba.com/vw/forum/viewtopic.php?p=5181008
36 hp Challenge Results 2010: http://www.thesamba.com/vw/forum/viewtopic.php?t=432481
2010 Larry Monreal's Bonneville record: http://www.thesamba.com/vw/forum/viewtopic.php?p=5068408
If you'd like to catch up on interviews from Rick Herity and Gene Pustovyk of the 2010 36hp Land Speed Challenge runners you'll find them here: http://www.youtube.com/user/jrvolks#p/u
Blackline Racing's 36hp Challenge Videos: http://www.youtube.com/user/blacklineracing
Vintage Bonneville Video: http://www.thesamba.com/vw/forum/viewtopic.php?p=4465520&highlight=bonneville#4465520
2009 Bonneville Speed Week: http://www.thesamba.com/vw/forum/viewtopic.php?p=4989281
John.
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Vintage Speed All times are Mountain Standard Time/Pacific Daylight Savings Time
