Kflyer Samba Member
Joined: August 14, 2009 Posts: 62 Location: Central, IL
Posted: Wed Apr 06, 2011 7:40 pm Post subject: The Next Golden Rake? 72' standard project |
Well, after owning my 72' for a little over a year and not driving it I guess it's time to start fixin it up. I had alot of interest in the "Golden Rake" project and liked the look of that car so I think I'll do something similar! Don't be fooled by the pics, this car needs ALOT of work. The pans are shot, the drivers side heater channel is rusted thru, wiring junk, needs brakes, etc....So up on the jacks she goes.
The official "before" photos.
[/img] |
cookrw Samba Member
Joined: June 09, 2009 Posts: 873 Location: Augusta, KY
Posted: Wed Apr 06, 2011 7:43 pm Post subject: |
What is your time frame for this?
Good luck! _________________ '71 Super 'Vert
'84 Vanagon GL (w/ Sunroof!)
'96 Jeep Cherokee |
Kflyer Samba Member
Posted: Wed Apr 06, 2011 7:57 pm Post subject: |
| cookrw wrote: |
Good luck! |
I hope to have her finished before summers end! It's gonna be alot of work but I'm up for it. As soon as the body comes off it's going to the body shop. I'll work on the frame/pans while it's there. |
Kflyer Samba Member
Posted: Sat Apr 09, 2011 7:57 pm Post subject: |
Ok, fenders off, carpet mostly out running boards off. The only bad rust on the heat channels is the DS front. The rest is just surface rust as far as i can tell. The pans are SHOT! The metal in front of the dash under the hood has been cut up by the PO. I will weld in patch panels there. More progress hopefully tomorrow. On a side note I picked up a sweet 59' today! Not sure what I'm gonna do to it yet. Pics below
Previous owner really goofed this up. Not sure why he did this?
Holes cut-out of dash area?
New to me 59'
Kflyer Samba Member
Posted: Tue Apr 12, 2011 8:49 am Post subject: |
Update: Body is almost ready to remove from pan. I hope to have it off before the weekend as I'm headed to Bugapalooza Friday. The dash cover is off and revealed the gaping hole with absolutely NO support. I'm not sure what to do with this? Any idea's would be great.
_________________ 72' Standard Beetle
59' Beetle
59' Piper Comanche 250
'72 Build- https://www.thesamba.com/vw/forum/viewtopic.php?t=458816 |
Joey Samba Member
Joined: August 12, 2005 Posts: 5376 Location: Nova Scotia - Canada
Posted: Tue Apr 12, 2011 3:53 pm Post subject: |
- not much support for the windshield is there? I would get a donor dash and weld it in. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Tue Apr 12, 2011 5:36 pm Post subject: |
| Kflyer wrote: |
The PO probably cut that for more tie rod/body clearance.
You can go ahead and patch it up and flip the tie rod ends instead. _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
| Dr OnHolliday wrote: |
| As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Kflyer Samba Member
Posted: Tue Apr 12, 2011 6:22 pm Post subject: |
| Joey wrote: |
- not much support for the windshield is there? I would get a donor dash and weld it in. |
Ya, that's kinda what I'm thinking or maybe weld in some vertical bracing and reinstall the fiberglass dash. _________________ 72' Standard Beetle
59' Beetle
Kflyer Samba Member
Posted: Sun Apr 17, 2011 5:29 pm Post subject: |
Just got back from Bug-a-palooza in TN and picked up a donor dash cheap. Body ready to come off but couldn't get the help before the show. Will have it off this week.
59' Beetle
SLO-N-LO-69 Samba Member
Joined: July 06, 2006 Posts: 645 Location: Central Florida
Posted: Sun Apr 17, 2011 5:36 pm Post subject: |
Wow someone needs to take the saw from that PO and not give it back. Mine had similar holes in below the dash like yours but not as big. I believe they were speaker holes in mine but with them open trunk fumes came right in the cab.  |
Kflyer Samba Member
Posted: Sun Apr 17, 2011 6:40 pm Post subject: |
Ya, I don't know who the bigger fool is....him for hacking up the dash area or me for buying the car! Oh well it's my problem to fix now.  _________________ 72' Standard Beetle
59' Beetle
christiancarpenter Samba Member
Joined: June 08, 2010 Posts: 192 Location: edmond, ok
Posted: Sun Apr 17, 2011 7:04 pm Post subject: |
| that's a fantastic looking car to me. i really like the first 2 pics. very unique. what do you do for lights in the back? |
Rome Samba Member
Joined: June 02, 2004 Posts: 10806 Location: Pearl River, NY
Posted: Sun Apr 17, 2011 9:01 pm Post subject: |
Kflyer, since you asked for opinions I'd like to present mine. Even for a weekend/hobby car I find the stock dash layout practical (switch+radio location plus glovebox). Yes, go ahead and weld in your dash purchase to regain stiffness in the body.
Since your car does not have the air box, you could consider using the space below the radio opening for extra gauges. Maybe even moving the radio upwards slightly to make room for gauges. Or, smooth out the area left and right of the stock speedo with a filler panel to place your smaller gauges evenly- either 2 vertically next to the speedo, or two across on the left and on the right sides. Another possibility is to fit a Porsche 914 tachometer next to the speedo, which is the same size as a stock Beetle speedo and has a very similar style to the 100mph later Beetle speedos. See my gallery for a photo on my '77's layout. You do need to cut out and reposition the stock speedo surround section, then find another one for the tach. Having the two big gauges in direct sight thru the steering wheel, with two smaller gauges in between is helpful. |
Kflyer Samba Member
Posted: Thu Apr 21, 2011 2:48 pm Post subject: |
Rome, I agree. The factory dash needs to be re-installed for structual reasons if nothing else. _________________ 72' Standard Beetle
59' Beetle
Kflyer Samba Member
Kflyer Samba Member
Posted: Thu Apr 21, 2011 3:00 pm Post subject: |
| christiancarpenter wrote: |
The lights will probably remain factory style, not really sure yet. _________________ 72' Standard Beetle
59' Beetle
Kflyer Samba Member
Posted: Sat Apr 23, 2011 7:22 pm Post subject: |
Update: Started stripping the pan down for new floors. I hope to be ready to weld by next weekend.
New narrowed and adjustable beam.
Can anyone tell me what size the CV attachment screws are? They look like 12pt torx?
59' Beetle
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4610 Location: Central Maryland
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6544 Location: Northern Illinois
Posted: Sat Apr 23, 2011 8:17 pm Post subject: |
Nice to see someone else from Illinois bringing a bug back from the dead. Love the '59 too ! _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
Maxdog2 Samba Member
Joined: August 06, 2009 Posts: 208 Location: Grand Junction, Colorado
