vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2701 Location: sacramento
Posted: Sun Jun 05, 2011 12:36 am Post subject: cast crank? |
I have a crank out of a friends motor that i tore apart, It was a bone stock 1600 dual port. I've never seen a crank that looks like this one, the texture is strange compared to other stock VW cranks i've seen. Just wondered if it was a cast replacement crank or what, it has a vw stamp on it too. It looks to be in good shape though.
those markings on the side look odd to me _________________ 71 Super
66 Corvair
69 Baja Bug |
modok Samba Member
Joined: October 30, 2009 Posts: 27754 Location: Colorado Springs
Posted: Sun Jun 05, 2011 1:06 am Post subject: |
it is stock forged crank
ugly sucker too, but that does not hurt it any, just don't enter it in any beauty contests
at one point must have been all rusty, that is what the acne scars on the sides of the web are, but it was shot blasted(or similar process) at some point and that got rid of the rust and gave it that matte finish |
nsracing Samba Member
Posted: Sun Jun 05, 2011 5:35 am Post subject: |
Forged w/ acne. Probably reground to 60 under.  |
Posted: Sun Jun 05, 2011 7:06 am Post subject: |
thanks for the info, its not gonna go in anything fancy just a spare 1600. I think the mains are at .020" under _________________ 71 Super
66 Corvair
69 Baja Bug |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Sun Jun 05, 2011 9:03 am Post subject: |
| might not be the best one to try to get a lot of power out of. |
Posted: Sun Jun 05, 2011 12:45 pm Post subject: |
should it ring with the rods on it or do i have to take the rods off to do the bell test? _________________ 71 Super
66 Corvair
69 Baja Bug |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Sun Jun 05, 2011 1:20 pm Post subject: |
Remove the rods. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
Posted: Sun Jun 05, 2011 3:20 pm Post subject: |
No man. Just imprint this crank features in your head. These are the bone-stock VW forgings.
You will be able to tell in the dark which is Chinese and German VW crank shortly. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8857 Location: sound it out.
Posted: Sun Jun 05, 2011 5:30 pm Post subject: |
i just threw out a bone stock vw cast crank... threw out rods and all... _________________
| [email protected] wrote: |
| With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Sun Jun 05, 2011 5:41 pm Post subject: |
| bugninva wrote: |
| i just threw out a bone stock vw cast crank... |
VW only used forged cranks in their air cooled engines. |
Posted: Sun Jun 05, 2011 5:59 pm Post subject: |
| DarthWeber wrote: |
| bugninva wrote: |
i guess you never bought a late model mexican engine.... _________________
Posted: Sun Jun 05, 2011 6:24 pm Post subject: |
| bugninva wrote: |
| i guess you never bought a late model mexican engine.... |
Nope, why am I not surprized the mexi motors went el cheapo. But all the German engines came with forged cranks. |
Posted: Sun Jun 05, 2011 6:27 pm Post subject: |
| Plenty of cast cranks floating around in the USA now. |
Posted: Sun Jun 05, 2011 6:28 pm Post subject: |
| DarthWeber wrote: |
| bugninva wrote: |
yep... _________________
Posted: Sun Jun 05, 2011 9:55 pm Post subject: |
thanks for the replies, the engine it came from was pretty much bone stock but my reason for concern was because the rear main case bore was beat and the bearing was loose in the case. I don't know what would cause the thrust bearing to beat the case other than a crappy line bore/poor bearing crush or a cracked crank vibrating like crazy.
this is one half of the case after a line bore to .060" you can see the ridge in the middle and the beat thrust surface
66 Corvair
69 Baja Bug |
Posted: Mon Jun 06, 2011 1:09 am Post subject: |
| Looks like the next linebore is overdue. Or a 411 mains waiting to come out. |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Mon Jun 06, 2011 7:34 am Post subject: |
Looks like a good argument for the "Heavier Pulley". _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17658 Location: Left coast, Canada
Posted: Tue Jun 07, 2011 12:18 am Post subject: |
| DarthWeber wrote: |
| bugninva wrote: |
Plenty of engines have cast iron cranks that are perfectly reliable for their intended use. Just because the Germans didn't know how to make a quality cast iron crank in the 1930s, doesn't mean the Mexicans couldn't do it in the 1990s. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Tue Jun 07, 2011 10:25 am Post subject: |
| Bruce wrote: |
| DarthWeber wrote: |
| bugninva wrote: |
Plenty of engines have cast iron cranks that are perfectly reliable for their intended use. Just because the Germans didn't know how to make a quality cast iron crank in the 1930s, doesn't mean the Mexicans couldn't do it in the 1990s. |
cast cranks have their place, and each cast and forged have their advantages over the other... _________________
Posted: Tue Jun 07, 2011 11:02 am Post subject: |
| Bruce wrote: |
Now THAT'S really funny!!  |
