gfmccann Samba Member
Joined: June 04, 2023 Posts: 7 Location: Vancouver BC, Canada
Posted: Tue Jul 01, 2025 9:12 pm Post subject: Needing help in BC Caribou region (100 Mile to Prince George) |
Clutch barely disengaging. I can clearly see fluid weeping from the slave cylinder so I'm assuming that's the culprit.
So...
1. Where is the best place to get a slave cylinder (meaning, the shortest wait possible)?
2. Anyone have a good spot they can share with me where I can do the replacement? (Naturally, I'm on a long road trip.)
Thanks in advance for your help and suggestions.
- Gord |
Van den Broke Samba Member
Joined: May 20, 2012 Posts: 207 Location: Victoria, Canada
Posted: Tue Jul 01, 2025 9:36 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
I can't help physically, but check the brake reservoir fluid level, it may be low causing the problem.
The leak at the slave cylinder might the cause, but if you keep the reservoir topped up you might be okay for a while. |
Posted: Tue Jul 01, 2025 9:45 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
Maybe you could find a newer rig in a wrecking yard you could get replacement cups for the master cylinder from. No clue how universal such things are. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17127 Location: Brookeville, MD
Posted: Wed Jul 02, 2025 2:43 am Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
As mentioned check the 'brake' fluid level. It also supplies the clutch and should be at the full mark.
Leaking slave certainly could be the problem. I assume you've tried pumping the clutch pedal to see if that helps.
I'd try calling the parts supply places in Canada and see if anyone can quickly ship a replacement (slave and master) to the nearest town post office for you.
I hope you get this resolved soon. _________________ Dave O
The Western Syncro build
jlrftype7 Samba Member
Posted: Wed Jul 02, 2025 11:14 am Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
While not close, they are at least IN British Columbia, and if called, can offer more help than I can from my keyboard...
Dr. Bjorn Auto 1-250-929-2277
3380 Kilipi Rd Cobble Hill BC V8H 0J9
appox 11 hours South of you Via Cariboo Hwy BC-97N, according to Google _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
harvgwen Samba Member
Joined: February 11, 2021 Posts: 291 Location: Okanagan Valley, British Columbia
Posted: Wed Jul 02, 2025 11:51 am Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
Werke 1 in Vancouver (maybe Richmond). Barry is very helpful.
https://www.werke1.com/ _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Okanagan Valley, British Columbia |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2621 Location: Southeast Kentucky
Posted: Wed Jul 02, 2025 12:31 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
I had the same problem in 2017, a weeping Clutch Slave. No amount of bleeding would help the issue (clutch taking almost on the floor). We were on a long road trip. The issue began showing it's ugly face just south of Saskatoon, Saskatchewan.
So, I tend to agree that if the Clutch is taking near the bottom of the pedal travel and the Slave is leaking fluid, that's the issue. When bleeding the Clutch Slave, on the rebound it will suck air back into the system.
And, as others have suggested, make sure the Fluid Reservoir is on the full mark. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10210 Location: Mt Lemmon, AZ
Posted: Wed Jul 02, 2025 12:41 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
It is quite possible to shift without using the clutch.
You need to either use the clutch to start moving or else start in gear lurching forward.
Once moving you shift by taking it out of gear -- easiest to do if you find a combination of engine speed and road speed where everything matches - neither the engine nor the vehicle are being pushed.
Then ease the shifter against the gear you want to select. Apply gentle pressure to the shifter and try to find the new (lower for an up shift) RPM that matches the gear you're wanting. You may have to hunt up and down with the accelerator to find the sweet spot. Suddenly, it will slip smoothly into gear.
It's a technique worth learning and practicing in advance but it really does work even if you haven't practiced before.
Edit - Okay here's a video that may be instructive:
https://youtu.be/4JnK6k1pl8I?si=O9NViE6RSkl6-aU5 |
Posted: Wed Jul 02, 2025 1:06 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
UPDATE:
NAPA Auto Parts in Prince George actually has one in stock. That's 2½ hours in the right direction. I can get just enough travel to be able to stand still without stalling (after starting in gear). After that I'll be practicing my rev-matching / clutchless shifting.
I appreciate all of the responses. |
Posted: Wed Jul 02, 2025 1:28 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
The clutch less shifting worked well for me on a rear wheel drive car with floor shifter, but was really tough on my car with a "three in the tree" when my clutch linkage broke a hundred miles from home.
With the ten foot long Vanagon shift linkage it might be pretty difficult to feel for the right synchronization.
Unless it's a Syncro!  |
Posted: Wed Jul 02, 2025 2:58 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
gfmccann wrote: |
UPDATE:
YOU CAN MAKE IT !!!!!
We're all pulling for you..  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Wed Jul 02, 2025 10:30 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
Update #2
Problem solved. The slave cylinder was indeed the culprit. Once removed I could see that the piston was hanging up a full inch down the bore. Not the happiest repair exercise squeezing under the van in the parts store parking lot, but it's done. And so the adventure to the Arctic continues. |
sanchius  Samba Member
Posted: Thu Jul 03, 2025 4:07 am Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
gfmccann wrote: |
Update #2
Awesome OTR fix! You just graduated to become a steely-eyed vanagon mechanic. Nothing can stop you now.
With that out of the way, it's time to start posting the pictures and write-up of your adventure for us so we can tag along with you on your travels. _________________ The Syncro years (2005-16) - The 2WD years (2017-23) - In Hoosierland (2023-now)
Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going! |
joetiger  Samba Member
Joined: January 27, 2005 Posts: 5235 Location: denver
Posted: Thu Jul 03, 2025 7:15 am Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
gfmccann wrote: |
Update #2
Awesome. A story you'll tell forever. Safe travels! _________________ Joe T.
'02 Baja-ish Beetle "Bubbles"
Justice for Megan: https://linktr.ee/justiceformegantrussell |
Posted: Thu Jul 03, 2025 9:20 am Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
gfmccann wrote: |
Update #2
Wonderful. You got er dun! _________________ Dave O
Shonandb  Samba Member
Joined: January 12, 2019 Posts: 2030 Location: Vancouver, BC
Posted: Thu Jul 03, 2025 11:15 am Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
Good to hear that you got it sorted out. There are quite a few Vanagon and Bus owners in the PG area so I'm not surprised that Napa had one in stock.
I'm sure that you have it on your agenda already but Liard River Hot Springs is worth stopping at on your way North along the AlCan Hwy. _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
CdnVWJunkie  Samba Member
Joined: February 01, 2004 Posts: 1133 Location: Sarnia, Ontario, Canada
Posted: Thu Jul 03, 2025 12:06 pm Post subject: Re: Needing help in BC Caribou region (100 Mile to Prince George) |
Shonandb wrote: |
I'm sure that you have it on your agenda already but Liard River Hot Springs is worth stopping at on your way North along the AlCan Hwy. |
Good suggestion. |
