Notching mahle 94's
bug66
bug66 is offline
PostPosted: Sat Feb 04, 2012 5:28 am    Post subject: Notching mahle 94's Reply with quote
I've searced but can't find what I'm searcing for.
How much can you notch a set of forgeed 94's?
I need to cut 3,25mm on the exhaust (0,128")
and 2,75mm on the intake (0,108")
Is it enough material to o cut this?
catbox
catbox is offline
PostPosted: Sat Feb 04, 2012 8:01 am    Post subject: Reply with quote
I just had mine machined at Jaycee and Jack said that you can go as deep as 0.220" on the Mahle's.
These have all been notched to 0.160" to remove 6cc's from the chamber.
Smile
"...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume.
mark tucker
mark tucker is offline
PostPosted: Sat Feb 04, 2012 9:25 am    Post subject: Reply with quote
hmm why the smetrickle notches?just tryen to get most cc's?
modok
modok is offline
PostPosted: Sat Feb 04, 2012 3:00 pm    Post subject: Reply with quote
.125 deep should be no problem, long as you don't drill the bottom to balance
the thickness of the crowns is usually .220-.250
Eaallred
Eaallred is offline
PostPosted: Sat Feb 04, 2012 5:24 pm    Post subject: Reply with quote
Ugh, I cringe when I hear of people balancing pistons this way...
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
mark tucker
PostPosted: Sat Feb 04, 2012 5:27 pm    Post subject: Reply with quote
or putting a .220 deep pocket in a .220 thick piston top.
modok
modok is offline
PostPosted: Sat Feb 04, 2012 5:33 pm    Post subject: Reply with quote
yeah, I agree Shocked
raymon covey
raymon covey is offline
PostPosted: Sat Feb 04, 2012 6:56 pm    Post subject: Notches Reply with quote
If you will notice the notches fall very close or within the piston boss area which is much thicker. I have notched 180 without any problem. You should not have a problem with the notches you propose.
catbox
catbox is offline
PostPosted: Sun Feb 05, 2012 10:38 am    Post subject: Reply with quote
Yup just needed the CC's to make the chamber larger.
Smile
