Chilepines Samba Member
Joined: October 11, 2022 Posts: 145 Location: New Hampshire
Posted: Thu Sep 14, 2023 1:47 pm Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
steve244 wrote: |
Great write-up. I see several Dometic CRX-50s listed on their site. Which one is yours? |
I think it is the CRX-50T. I got it from Raney's Truck Parts.
https://www.raneystruckparts.com/truck-fridge-buil...y-dometic/
This model only comes in black. I switched the front panel with Formica and painted the trim. I'm very happy with the fit, and didn't mind needing to get rid of the city water plumbing to get it to install deep enough.
_________________ White 89 Westy with 2004 Subaru EJ25 - Betty |
steve244 Samba Member
Kdj Samba Member
Joined: January 28, 2017 Posts: 148 Location: Naptown
Posted: Mon Sep 18, 2023 4:17 pm Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Had to get the stowaway off before leaving for Gauley fest, then a quick run up to Seneca Rocks. Ended up being tiny bit less the 1000 miles in four day but Westly ran surprisingly well. Just never know with him!
elizer Samba Member
Joined: May 02, 2016 Posts: 1476 Location: Northern Virginia
Posted: Tue Sep 19, 2023 3:57 am Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
That's a great hike up there and great views. _________________ 91 syncro westy fas tdi |
E1 Samba Member
Joined: January 21, 2013 Posts: 6661 Location: Westfalia, Earth
Posted: Tue Sep 19, 2023 5:20 am Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Yes on first thousand, second thousand this week. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
pathao Samba Member
Joined: November 01, 2012 Posts: 293 Location: Montreal, Canada
Posted: Fri Oct 06, 2023 7:22 am Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Around Lac Supérieur : 2738 Miles
Did an oil change before leaving, now it sits 1/4 of the gauge. Had the contact of the front left flasher playing havoc ( a little tapping would temporarly fix it). Eberspacher works. Fridge on propane works, Radio works. Zumo XT's setup works. Apart from having been living (many years) with a slow leak on one tire and never took a look at it. Long story short, that old spare (Agilis manufactdate 1406) didn't hold up.
So I'll say, YES made it.
Now 5 new rubbers on order. I guess that's the price of being lazy. And I have to put on the todo-list : check the play in the steering column. _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
elizer Samba Member
Posted: Fri Oct 06, 2023 7:35 am Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Love the boat pic! _________________ 91 syncro westy fas tdi |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2347 Location: Southeast Kentucky
Posted: Fri Oct 06, 2023 7:54 am Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Pathao, that had to have been an epic adventure.
I've been fortunate to never have a flat on any of my Vanagons since I purchased my first one in 1985.
Ironically, I'm still hauling the OE Continental spare in my 84 Vanagon.
Yes, I need to upgrade....LOL _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7763 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Oct 21, 2023 1:40 pm Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Recently home from my eclipse trip… Lake Superior to CO…NM…AZ…UT & back, 3,250 miles with zero issues…
A few pics, FWIW:
Totality at center line south of Red Mesa AZ. “Ring of fire” not obvious in sun image, but note circular lens flare below bumper:
Totality shown through eclipse viewer glasses:
Campsite same night in Valley of the Gods, UT:
Lunch at Muley Point the next day before heading home:
My first fall road trip since retirement one year ago…see you on the road!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sat Oct 21, 2023 7:39 pm Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
^^^ Indeed.
I suppose the more correct term for my position at this eclipse was annularity, or maximum.
I took great care to view from within meters of the center of the path of annularity.
This was my 2nd…April ‘24 will be my 3rd eclipse trip in the van.
"The WonderVan"
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3114 Location: ABQ NM USA.... Except when not
Posted: Sun Oct 22, 2023 8:56 am Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Coincidentally, this came up for me today MI>OH>TN>FL
3500?lb Boat(2,460lb displacement + stuff/trailer?), standard manual tranny, EJ25, standard brakes.
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Mon Oct 23, 2023 4:12 pm Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Wow that powertrain owes you nothing |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9639 Location: Western WA
Posted: Mon Oct 23, 2023 7:59 pm Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
earlywesty wrote: |
But it's about to make some noise. _________________
....KTMs, GasGas, SPOT mtb |
tbone5 Samba Member
Posted: Wed Nov 01, 2023 10:58 am Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
1. 84’ Westy, 1.9 - rebuilt GW 2.3
2. LA, Ca – Durango, Co – LA with stops along the way - Arches/Brice/Zion, @ 2,300 miles total
3. A qualified made it – Some Vanagon Syndrome Stumble, changed out the coil and all was good
About a month before the trip, Bob (my Westy), had serious stumble issues on the highway…100 degree air temp while climbing the Grapevine (though engine never overheated). Classic symptoms – loss of power, engine died and coasted to a stop. Let Bob sit for about 45min, started right up. Got home and cleaned all the grounds, bypassed the starter to tranny cable, replaced the vacuum hoses, changed out the spark plugs, and for good measure, changed out the fuel pump. Bob ran better than ever and gas mileage was the best I’ve had (@ 18 mpg). Month later thought all was good and embarked upon the “big trip”. Three hours into the first day the engine stumbles (but doesn’t die) Sweating bullets I pull over and let Bob sit. Half hour later the engine starts up and I continue on…but lost my faith in Bob’s ability to complete the trip. At the campground that evening I reread Samba posts covering the dreaded Vanagon Syndrome. I notice that one the piece of the puzzle I missed was the recommendation to replace the coil. The next morning I order a new one from VanCafe to be dropped shipped to my friend’s house in Durango (which UPS delivers as I pull up to his driveway….talk about timing!) Next day we switch out the coil….1300 miles later no problems and my faith in Bob has been restored.
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2324 Location: Adobe Jungle USA
Posted: Wed Nov 01, 2023 6:23 pm Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Just drove 1,500 miles Bonners Ferry Idaho to Santa Fe for the winter, van ran like a top!
Forty Fifth parallel, New Meadows Idaho, halfway between the equator and North Pole. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
elizer Samba Member
Posted: Sat Nov 11, 2023 6:20 pm Post subject: Re: Poll: Long drive, did you make it? 1,000+ miles |
Meandered down to Florida from Virginia. Drove around. Broke the 1000 mile mark. We will start heading back up on Monday so won't know the end miles yet. I wanted to wish the veterans a good one and their loved ones who have the unfortunate duty of putting up with them.
A little unintentional red, white and blue. Had to put the but zapper up after we let in a million mosquitos. The USB rechargable but zippers on Amazon actually work. Anything smaller than a mosquito not so much.
