twixerella Samba Member
Posted: Sat Mar 27, 2010 8:47 am Post subject: Is converting your bus's engine to a subaru engine worth it? |
I haven't gotten a VW bus......yet, but lately I've been looking around this site and others. I've read wonderful things about the vans, and also heard some common complaints. One that stood out to me was the mediocre gas mileage. If I get a van, it would most likely not be a daily driver, but i would want to plan a few cross country road trips. I was reading about rebuilding engines. My main concern is the gas mileage, I'm not concerned about the vehicles value declining because of an unorginal engine. Has anyone done the subaru conversion and found that it greatly increased your gas mileage? Was it really expensive? Any other ways you have rebuilt the engine that have affected your gas mileage? I would like to get at least 25 mpg, but from other forum posts I understand that this is pushing it, and fantastic mileage for one of these buses. I would like to get a 1972-1979 bus, but definitely not in the 80's.
Thanks for all your help  |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3069 Location: Portland, Oregon
Posted: Sat Mar 27, 2010 8:57 am Post subject: |
If mileage is a concern then go diesel. You'll get that low end power our Buses like and good mileage  _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
iratehippie Samba Member
Joined: April 21, 2002 Posts: 401 Location: high on southern oregon mountaintop...
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1414 Location: Cambridge, MA
Posted: Sat Mar 27, 2010 8:59 am Post subject: |
Bay window buses are not really great candidates for Subaru conversions because of the need to mount a radiator somewhere. It's a difficult conversion and if you've never even owned a bus I think you'd be way over your head. Most people who convert to other engines do so for performance or reliability reasons. Or just because they're bored and want something to do. I doubt you will see enough of an improvement in gas mileage to justify the cost. VW engines are pretty efficient already and the mileage a VW Bus gets is comparable with the mileage you get from a modern minivan.
You can get 25 mpg from a well-tuned stock bus if you keep it light and drive it very conservatively... 55 mph. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
rcnotes Samba Member
Joined: July 09, 2005 Posts: 641 Location: Ann Arbor, MI
Riguy718 Samba Member
Joined: November 27, 2008 Posts: 370 Location: Nampa, ID
Posted: Sat Mar 27, 2010 9:13 am Post subject: |
WhirledTraveller wrote: |
You can get 25 mpg from a well-tuned stock bus if you keep it light and drive it very conservatively... 55 mph. |
So true...just get your bus as close to stock as you can. German engineers designed it right the first time..no need to hack it up to put a bigger engine and a radiator. _________________ First Vehicle:
Bil(bo) 1970 Westy Stock [1600DP]
Take life slowly and enjoy it, especially in a VW bus!!! |
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Sat Mar 27, 2010 9:19 am Post subject: |
Whirled gives great advice. We put a Toyota 3TC 1.8 in a '76 Riveria. I would have preferred the Sube flat 4 1.8 ( I used to be a member of USMB). Lots of work, proper cooling, rewiring, flywheel change kits, etc, not to mention fabricating new engine hangers....Not worth it unless you're into a great learning experience. Stick with a well running stock Bus. _________________ '66 Beetle
2011 Hyundai Elantra Touring |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2924 Location: San Antonio, Nuevo Mexico
Posted: Sat Mar 27, 2010 9:25 am Post subject: |
a heater and defroster that works is tempting. If I want them bad enough I'll get a vanagon.
look at Jeeps, Harleys, Globe Swifts ( airplane that looks like a hot rod and flies like a bread truck in stock form ). Almost impossible to find a stock one after the warranty expires. the few unhacked originals are in museums
some people get to a place where they decide they are not the owner of a commodity; they are the custodian of an increasingly rare item. keeping it intact for the next generation.
I'm at that place with VW vans, says the guy with a baja bug.... _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
chabanais Samba Member
Posted: Sat Mar 27, 2010 10:43 am Post subject: |
You're not going to pay a lot for a Bus nor will you be driving it every day. So even if the mileage is 20 and you get 28 with a Subbie engine do you not think all the money you "save" in gas you would not spend 10x more doing the engine conversion?
Doesn't make any cents. _________________ "I spud therefore I yam." |
calebmelvin Samba Member
Joined: July 19, 2006 Posts: 3140 Location: Seattle, WA
Justin Samba Member
Posted: Sat Mar 27, 2010 12:48 pm Post subject: |
I tend to be in the "busdaddy's signature" school of thought:
"Rust NEVER sleeps and stock never goes out of style."
[emphasis added by me]
I am not a true purist but I generally don't like the idea of swapping out original design for something else. Could be laziness, could be the comfort of knowing how to work with stock components. Either way, it's just my opinion. |
TheShane Samba Member
Joined: September 19, 2008 Posts: 356 Location: Lexington, Ky
Posted: Sat Mar 27, 2010 12:54 pm Post subject: |
Caleb Melvin wrote: |
^-- agreed 100%. How much is one of these conversions going to cost? $2K? $5K?
You would be saving $.04 a mile (20 vs 28mpg @$3 gal).
So if the conversion costs $2K, it would take you 50,000 Mi to break even cost wise.
If it costs, $5K it would take you 125,000 MI  |
Economists...
Just kidding.  _________________ '78 Sunroof Bus
Central KY VW Club
NASkeet wrote: |
I suppose that's what happens when one drives a passion wagon, which comes factory-fitted with a double bed. |
Posted: Sat Mar 27, 2010 1:07 pm Post subject: |
Corvair or Porsche would be fine by me but generally I agree.
Justin wrote: |
Posted: Sat Mar 27, 2010 1:11 pm Post subject: |
TheShane wrote: |
Economists...
Just kidding.  |
I hated economics, too many shaded triangles trying to show oversimplified concepts.
I do like to know what things are going to cost me though. This one does not make sense to me. Its like those people who trade in their civic for a prius. You spent $10K more for a car that only gets 10mpg more? Really?
If you think about it here, a bus driver only drives max 10K a year, that would take him 5-12 years to just break even! _________________ Caleb
'68 Tagged Manx | My Wanted Ads
Posted: Sat Mar 27, 2010 4:33 pm Post subject: |
I sell cars for a living and there are a lot of math morons out there. Usually it is passion or want is the motivating force but logic (better gas mileage, etc...) is the excuse given. They are lies people tell themselves because they want to believe it.
I dropped $4,500 into a new motor, etc. for my Bus and have been dumping money into it for 15 years but I don't plan on getting rid of it and am emotionally attached to my car so that's my 'excuse.'
TheShane wrote: |
Economists...
Just kidding.  |
If you think about it here, a bus driver only drives max 10K a year, that would take him 5-12 years to just break even! |
chazz79 Samba Member
Posted: Sat Mar 27, 2010 6:21 pm Post subject: |
To answer the op's question- hell now it ain't worth it. Survey the options out there and the math just won't add up. Think about being in the middle of nowhere looking for parts. Subaru crap is going to be just as hard to find as the stock vw parts. Power from the subaru is going to be in the 90-150hp range and the fuel miliage will be 20-25. The hp increase will be nice but the availability of parts would be a little rough. I have yet to see a well sorted out subaru conversion done to a bay. The route I'm taking made the most sense to me. I have a rebuilt 2.3l that will make 120+hp. All told this cost nearly 2000.00. That price includes the 6 rib trans I needed to make it happen. _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
Posted: Sat Mar 27, 2010 7:29 pm Post subject: |
Hmmm, so it seems that it wouldn't be worth it. Ok, well i thank everyone for giving me their advice and experience on the matter. I would like to have better mileage, but i suppose the authenticiy of the hippie van makes up for its sucky mileage.  |
busboy25 Samba Member
Joined: July 27, 2007 Posts: 97 Location: Rochester Hills, MI
Posted: Sat Mar 27, 2010 8:01 pm Post subject: |
If you do it for performance then it a good idea, A lot of work though.
They do it a lot in Australia cause vanagons were nver imported there so their is a lot of info on this just not here, do a google search on it. After you put a raditor in the bus its really no different from a vanagon and that is still a bunch of work. And you are looking at $10000 to put one in with a good 2.2l.
Oh and if you are bad at or don't like electrical work then do not do it and don't think about. _________________ 76 Bay - 2056 Type four |
greenbus pilot Samba Member
Joined: March 14, 2008 Posts: 1285 Location: Wisconsin: Rustbelt, USA baby!!
Posted: Sat Mar 27, 2010 8:48 pm Post subject: |
Well, I put a water cooled (Golf) in my '76 Westy, but from the start I had NO intentions of any type of fuel mileage or horsepower payback,I simply wanted the challenge, and maybe bragging rights. I (now) have a stock looking Bus, with a very reliable engine, which gets about the same mileage as stock.
But, I am very emotionally attached to the Bus, and I had no intentions of EVER breaking even with all the countless hours I have into it.
But I gotta say, it sure is fun!
This type of endeavour is NOT for the faint of heart stock nazi, no way. It is a big challenge, and you had better be good at mechanical work and more importantly electrical work, as YOU are the one who will have to troubleshoot and fix it. Its all a new challenge then, but you have to be very patient and open minded when the damn thing does not work out like you wanted. There is a large learning curve AFTER the Bus is running, as cooling issues and others pop up.
BUT, YMMV. I like thinking outside the Bus.  _________________ Sent from a white van down the street. |
Klaussinator Samba Member
Posted: Sat Mar 27, 2010 9:18 pm Post subject: |
My bus has a 1.8 engine w/ dual Solexes and the 009 w/ no advance - as old-school as it gets. No, it is not a "daily driver" but it doesn't get much down-time either. It's fun to drive! I built my engine from three incomplete motors that came with the bus. All I bought new were jugs, pistons, rings, and a few seals. I kept it low-budget and figured that If I can get a year out of it, I'll be doing good, then I'll put the money into rebuilding it the right way or look into a conversion kit (and yes, I grew up with Subarus - LOVE EM!) Well, that was three years and many miles ago.
We have family in PA and have taken the bus on many round trips up & back. In fact, just got back from another one where I spent two nights in the bus. Good times! This bus has never left us sitting, although there were a few late starts, due to adjustments or quick fixes that needed to be made. Just the naure of the beast.
My point is this: With every mile logged, I realize just how fun and reliable this noisy old air-cooled machine can be. My thoughts of converting to a modern engine have faded -- why should I , when this one is doing so good? It keeps up with traffic, and yes, the heat works! My mileage on a trip has never averaged below 21 mpg. That's about the same as our new minivan, except that it wasn't lugging around a full kitchen, water tanks, and all the other stuff we keep in the bus.
No, it's not for everyone, and if it's not your flavor, that's fine.
But it is mine!!!
-Klauss _________________ I have taken a vow of poverty. To annoy me, send money!
____________________________________________
the Klaussinator - `73 hardtop Bay custom-built camper |
