gringoloco2000 Samba Member
Joined: August 15, 2013 Posts: 156 Location: Debary, FL
Posted: Tue Apr 21, 2015 7:31 pm Post subject: Header melting the engine seal |
| I have a bugpack ceramic 1 5/8 header that I cannot keep from touching the back engine seal (closest to the bumper). I just fired up the engine in the car for the first time and it was smoking pretty badly as the rubber screams for mercy. I thought maybe it would just melt, harden and stop smoking at some point. I only drove a block so far, so not much of a test. It was smoking quite a bit. I can't see how I can prevent it from touching it without cutting some of it maybe. Is there something I could use to insulate it? maybe wrap something around the header at the point of contact to reduce the heat? |
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Tue Apr 21, 2015 7:48 pm Post subject: Re: Header melting the engine seal |
| gringoloco2000 wrote: |
I have the same problem. My header has also burnt through my fresh air hose. I'm going to try some header wrap and see if that helps. |
Hilbilyrocker Samba Member
Joined: November 19, 2016 Posts: 34 Location: Colfax, Ca
Posted: Sun Oct 27, 2019 8:55 am Post subject: Re: Header melting the engine seal |
| I’m experiencing the same thing. Did anyone find a remedy to this issue? |
beetlenut Samba Member
Posted: Sun Oct 27, 2019 9:46 am Post subject: Re: Header melting the engine seal |
I just went through this with a newly rebuilt motor and a 1 1/2 inch SS exhaust. Burnt right through the first seal! New motor running hot during break-in with new engine seal fitting tight is not a good combo. Since I have a removable rear apron, I only had to replace the part on the apron. I got some header wrap for motorcycles from Autozone which is supposed to reduce the heat transfer by 50%. I wrapped the primaries coming off 2 and 4 with 2 full layers of the wrap. I also rejetted my carb because I feel I was running lean, went to a cooler plug, and changed oil viscosity from 15-40 to 5-30 weight. With only 150 miles on the engine at that point, it significantly cooled things down. No more engine seal problems, and I can handle the dipstick after running for a good while. While searching on here for remedies, more than a few people felt running a thicker oil would cause heat issues having to do with the bypass to the oil cooler. I'm inclined to agree after my experiences. _________________ scrapyards are for quitters
| Wetstuff wrote: |
| ... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80571 Location: Sneaking up behind you
Posted: Sun Oct 27, 2019 9:48 am Post subject: Re: Header melting the engine seal |
This is all related to the quality of aftermarket parts. They are all not made the same. Also if your car was ever hit in the back.
My Berg 1-5/8" clears the apron and seal. I've seen many other brands not and burn the seal. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sun Oct 27, 2019 1:40 pm Post subject: Re: Header melting the engine seal |
| Glenn wrote: |
My Berg 1-5/8" clears the apron and seal. I've seen many other brands not and burn the seal. |
True! My car had a little tap in the rear....
| Wetstuff wrote: |
Posted: Sun Oct 27, 2019 8:03 pm Post subject: Re: Header melting the engine seal |
Thanks for all your input. Great to have this forum to get help.
It’ll be a couple weeks, but I’ll post an update. 👍 |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5583 Location: Lefty, CA
bluebus86 Banned
Posted: Tue Oct 29, 2019 10:26 am Post subject: Re: Header melting the engine seal |
Maybe the motor sits too high in the engine bay, thus allowing the header to touch the seal. This maybe a motor mount issue? Mount too tall?
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Tue Oct 29, 2019 10:59 pm Post subject: Re: Header melting the engine seal |
| I thought about that. I replaced the old ones. Maybe I need to use a different year motor mount w/ this rebuilt 2160 motor. Any suggestions? |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Wed Oct 30, 2019 4:30 am Post subject: Re: Header melting the engine seal |
| Hilbilyrocker wrote: |
The mounts do not change for engine size, just for the trans year. How many miles are on the engine? It will run hot until it's fully broken in. |
Posted: Wed Oct 30, 2019 12:32 pm Post subject: Re: Header melting the engine seal |
Brand new, maybe 5 miles.
I ordered heat warpath last night. |
Posted: Thu Oct 31, 2019 4:30 am Post subject: Re: Header melting the engine seal |
That will be part of the issue. It's going to run hot until it's broken in. |
Posted: Wed Dec 18, 2019 2:10 am Post subject: Re: Header melting the engine seal |
Update on high heat headers.
I wrap the header around the area which press up against the seal.
So far so good. It really helped to keep from melting the seal.
Thanks |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13960 Location: White Mountains Arizona
Posted: Wed Dec 18, 2019 6:44 am Post subject: Re: Header melting the engine seal |
I wrapped mine prior to install never an issue. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
