tires/rims
redlinedave
redlinedave is offline
PostPosted: Wed Dec 11, 2013 2:26 pm    Post subject: tires/rims Reply with quote
Hi all
It seems you can not get 14 inch snow tyres (LT) in Canada or they are next to impossible to find.
would these work? Would I need spacers? Id like to find something plug and play.
regards
and yes I did search and read through alot of tyre threads and i just got more confused
1985 Country Homes VW van 1.9L
joseph928
joseph928 is offline
PostPosted: Wed Dec 11, 2013 2:39 pm    Post subject: tires Reply with quote
Blue Bay Bus Photo would help a lot! Or a few lines on the tire and rim kind & model . Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
redlinedave
PostPosted: Wed Dec 11, 2013 3:16 pm    Post subject: Reply with quote
sorry
linj to add
http://ontario.kijiji.ca/c-cars-vehicles-auto-part...Z550103856
redlinedave
PostPosted: Wed Dec 11, 2013 3:23 pm    Post subject: Reply with quote
found this add but a litltle too much $
http://toronto.kijiji.ca/c-cars-vehicles-auto-part...Z549238462
Christopher Schimke
PostPosted: Wed Dec 11, 2013 3:35 pm    Post subject: Reply with quote
These wheels would require spacers and lugs. If you purchased from me, the parts total would be between $129.78 and $289.56, depending on your hardware choices.
These wheels could be nearly a bolt-on if you use 205 or narrower tires. Wider tires will require spacers. Center caps won't fit without spacers but custom caps are available to solve that issue. You will need to drill the lug holes to 37/64" and you will need lugs front and rear. Parts for these wheels can range from $$49.80 to $409.52, depending on your choice of hardware and whether or not you include the custom center caps.
redlinedave
PostPosted: Wed Dec 11, 2013 5:41 pm    Post subject: Reply with quote
thanks
Jon_slider
Jon_slider is offline
PostPosted: Wed Dec 11, 2013 6:21 pm    Post subject: Reply with quote
195/R14 106/104S
http://www.nokiantires.com/tyre?id=11889&group=3.01&name=Nokian%20Hakkapeliitta%20CS
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Dec 11, 2013 7:44 pm    Post subject: Reply with quote
Jon_slider wrote:
195/R14 106/104S
These tires are available in Canada at Kal Tire.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
redlinedave
PostPosted: Wed Dec 11, 2013 9:24 pm    Post subject: Reply with quote
thanks Jake and Jon
redlinedave
PostPosted: Thu Dec 12, 2013 11:01 am    Post subject: Reply with quote
Called Kal tire
It seems the tire is discontinued
nemobuscaptain
nemobuscaptain is offline
PostPosted: Thu Dec 12, 2013 12:09 pm    Post subject: Reply with quote
Fairly often, IMO "it's discontinued" means "Why the F#@% won't just buy what I have in stock already".
Maybe double check it with some other vendors.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
Jake de Villiers
PostPosted: Thu Dec 12, 2013 2:05 pm    Post subject: Reply with quote
redlinedave wrote:
Called Kal tire
If it was discontinued it wouldn't be on the Nokian website.
www.thebassspa.com
Jake de Villiers
+1
www.thebassspa.com
Jon_slider
PostPosted: Sun Dec 15, 2013 10:13 am    Post subject: Reply with quote
they might be discontinued. I would ask Van-cafe.com and trust what they say.
an alternate choice could be the General Grabber AT/2 in 27x8.5x14, but its not ideal, the load rating is marginal, though I have used the tire on a syncro myself. The tire is snow rated, but the Nokian is much more snow capable.
http://www.tirerack.com/tires/tires.jsp?tireMake=G...;tab=Specs
