What TIRES fit? The ultimate tire thread!
Page: 1, 2, 3 ... 56, 57, 58  Next
kamzcab86
kamzcab86 is offline
PostPosted: Sat Feb 08, 2014 3:30 pm    Post subject: What TIRES fit? The ultimate tire thread! Reply with quote
Vanagon Tire Information
[Updated: August 16, 2019]
* * *March 2017: This post is now a truncated version of the original, with just the most basic, pertinent info supplied. For complete tire information and details, and in a more organized, readable format, please download and read the PDF version of this post.* * *
Gross vehicle weight (GVWR) at each corner of a van when fully loaded:
1433 lbs. (2WD Vanagon)
1521 lbs. (4WD Vanagon)
The above is the minimum weight rating you should use when shopping for new tires. The lowest weight-rated tire originally installed on Vanagons by Volkswagen was 1580 lbs. (load index 97, reinforced sidewalls); derated by 9% as required (see Tire Types section), the tire's actual load was 1438 lbs., just over the 1433 full-load van weight above. The 1580-lbs. rating is the preferred minimum weight rating to use when shopping for new tires, especially for campers, so that your van has a safety margin. Furthermore, except for that one 1580-lbs. rated tire, all tires installed on Vanagons at the factory were light truck tires. Use the original equipment list below as a guide while you shop.
Original Equipment (Vanagon 2WD):
185R14C 6PR
Load Index: 99
Load Range: C (6 ply)
Max Load: 1710 lbs.
Max Inflation: 55 psi
VW-recommended Inflation: 39-43 (front); 48-53 (rear)
Revs/mile: 820
Tire: Continental Transport RS771; Continental RT 735 M&S; Michelin XZXT-LRC; Michelin XC; Michelin X
205/70R14 97R
Load Index: 97
Load Range: XL/RF
Max Load: 1580 lbs.
Max Inflation: 40 psi
VW-recommended inflation: 30 (front); 40 (rear)
Revs/mile: 798
Tire: Michelin MXL
Notes: Reinforced passenger car tire
205/65R15
Standard size on South African-built T3's
Original Equipment (Vanagon 4WD):
185R14C 6PR
Load Index: 99
Max Load: 1710 lbs.
VW-recommended Inflation: 40-43 (front); 48 (rear)
Revs/mile: 820
205R14C 6PR/8PR
Load Index: 109
Load Range: D (8 ply)
Max Load: 2270 lbs.
Max Inflation: 65 psi
VW-recommended inflation: 36 (front); 43-43.5(rear)
Revs/mile: 798
Tire: Michelin XC A75; Continental Contrans
205/70R14 97R
Load Index: 97
Load Range: XL/RF
Max Load: 1580 lbs.
VW-recommended inflation: 36 (front); 40 (rear)
Revs/mile: 798
Tire: Michelin MXL
Load Index Rating Conversions
93 = 1433 lbs.
94 = 1477 lbs.
95 = 1521 lbs.
96 = 1565 lbs.
97 = 1609 lbs.
98 = 1653 lbs.
99 = 1709 lbs.
100 = 1764 lbs.
101 = 1819 lbs.
102 = 1874 lbs.
Load Range Conversions with Corresponding Standard Max psi Ratings
B = 4 ply (35 psi)
C = 6 ply (50 psi)
D = 8 ply (65 psi)
E = 10 ply (80 psi)
F = 12 ply (95 psi)
SL (35-36 psi)*
XL (41-42 psi)*
* These ratings are for P-metric tires; SL and XL load ranges are often 40 psi and above for Euro-metric and truck/SUV-branded tires.
Replacement Tire Types
Passenger car/minivan tires:
Passenger car tires come in P-metric and Euro-metric sizes. Volkswagen did install a passenger car tire on Vanagons; however, they had reinforced sidewalls and met their load requirement(s). Modern reinforced passenger car tires will have an XL (extra load) or RF (reinforced) rating, as opposed to SL (standard load, which are 2- or 4-ply tires). These tires must meet or exceed the original equipment (see above), which means few options available today. Furthermore, the load range of all P-metric passenger car tires must be reduced by 9%, even when XL or RF. Be vigilant when shopping for P-metric tires for your van.
Euro-metric passenger car tires:
If the tire has no letter designation it is a Euro-metric tire. Euro-metric tires, like their P-metric counterparts, including XL/RF tires, are to be derated by 9% when rated below the C/D/E/F load range. A Euro-metric tire load rated at 99, has a max load rating of 1709 lbs., has a max psi rating of 50, and is an extra load (XL). If we reduce the max load by 9% we get 1555, which is just below the recommended 1580 lbs., but is above the minimum 1433 lbs. This tire can be used.
To recap: Any tire that is not designated as LT (light truck), or does not have a C or higher load range, must undergo the 9% reduction in max load weight. However, it is unclear at this point whether a P- or Euro-metric SUV-branded tire (such as the Yokohama Geolandars) with an SL or XL rating must also undergo the 9% reduction.
For the math-challenged, the equation for reducing a tire's load rating: max load x 0.91 = reduced load rating. From the example above: 1709 x 0.91 = 1555.
Commercial Tires:
Speaking of C, don't confuse C with C. What? When a tire is designated as 205/65R15C, that C is not a load range indicator; it is a tire designation meaning it is a commercial-grade tire.
Trailer Tires:
While trailer tires can meet van specs, they are specifically for trailer applications and, according to experts and manufacturers, are not to be used on drive axles. Trailer-specific tires will be designated with "ST" (such as ST205/60/15).
It should be noted that some tires are actually multi-purpose, but are labeled as trailer-only tires by tire stores, despite the tires not being designated ST. These types of tires are often described by their manufacturers as trailer tires, but are "also suitable on light trucks and vans"; not all tire stores will provide this information so be sure to visit the tire manufacturer's web site. Two tires falling into this category are Hankook RA08 and Kumho Radial 857.
Light Truck (LT) tires:
These are the tires that are preferred on vans, with a load range of C or D (or higher), and a load index of 97 or higher (if going by Volkswagen's specifications). Light truck series tires will be designated LT (such as LT205/65R16).
Currently Available & Recommended Tires
Notes:
1) A tire that can easily fit a 4WD may not fit a 2WD, and vice versa.
2) Before you recommend your particular tire in this topic, please ensure that it is, in fact, still produced by the manufacturer.
3) This will be an ever-evolving post as tires come and go from the marketplace. If you are certain a tire on the list is no longer manufactured, please PM me to have it removed.
4) Again, please download the PDF version of this post for complete tire details including sizes, load ratings, diameters, types, etc.
14" Tires
Cooper Weather Master S/T2
General Tire Grabber AT2
GT Radial Champiro VP1
Hankook Vantra LT (RA18)
Kenda Klever A/T
Kumho Road Venture MT KL71
Maxxis Bravo MA-751
Maxxis Bravo UE-168
Nexen SV820
Nokian cLine Van
Omni United/Radar RLT 71
Yokohama Y356
14" discussion: http://www.thesamba.com/vw/forum/viewtopic.php?t=499636
15" Tires
Achilles Radial Multivan
BFGoodrich All-Terrain T/A KO2
Continental Vanco 4 Season
Falken Espia EPZ II
Falken Sincera SN250 A/S
Falken Ziex ZE950 A/S
Firestone Destination A/T
General Grabber AT2
Kumho Road Venture AT 51
Michelin Agilis CrossClimate
Michelin Defender LTX M/S
Michelin X-Ice XI3
Nokian eNTYRE 2.0
Nokian cLine Cargo
Nokian cLine Van
Nokian WR C3
Pirelli Scorpion ATR
Sumitomo HTR A/S P02
Thunderer Ranger R402
Vredestein Comtrac
Vredestein Comtrac 2 All-season
Yokohama Geolandar A/T G015
Yokohama Geolandar H/T-S G051
15" discussion: http://www.thesamba.com/vw/forum/viewtopic.php?t=488282
16" Tires
Bridgestone Dueler 422 Ecopia
Continental ContiProContact
Continental Extreme WinterContact
Continental 4x4 Contact
Falken Espia EPZ II
General Grabber AT2
Goodyear Assurance Tripletread All-season
Hankook Dynapro ATM RF10
Hankook i*Pike RW11
Hankook Ventus V2 H457
Kumho Crugen HT51
Nankang Cross-Sport All-Season SP-9
Nitto CrossTek 2
Nokian eNTYRE 2.0
Nokian cLine Cargo
Nokian cLine Van
Nokian WR C3
Toyo Versado Noir
Vredestein Comtrac
17" Tires
Nokian eNTYRE 2.0
Discontinued Tires
BFGoodrich All-Terrain KO
Continental Vanco 2
Continental Vanco 8
Cooper Discoverer M+S (14")
Firestone Destination AT (14")
Firestone TransForce HT (15")
Hankook RA08
Hankook i*Pike RS
Hercules Power CV
Goodyear Assurance Tripletred All-season
Kumho Radial 857
Kumho Road Venture AT KL78
Michelin Agilis
Nexen CP321
Nexen CP521
Nokian eNTYRE (16")
Nokian Hakkapeliitta C Van
Nokian WR G3 (15", 16")
Vredestein Comtrac All-season (14")
Additional tire information:
http://www.roadhaus.com/tires/guideline.html
http://www.busdepot.com/details/tires/
http://www.ratwell.com/technical/Tires.html
http://www.moderntiredealer.com/article/story/2008...age/2.aspx
http://www.tirereview.com/tire-types-and-load-capacity/#
Tire topics: http://www.thesamba.com/vw/forum/search.php?search...=titleonly
If anyone has a tire to recommend (ensure it is still available!), tire questions to ask, or general information to add/correct, feel free to post. Consider this the new official van tire FAQ topic.
Note: I'm no tire expert. This post (and PDF) is simply a culmination of the thousand tire topics in the Vanagon Forum. Wink
2016 Golf GTI S
DAV!D
DAV!D is offline
PostPosted: Sat Feb 08, 2014 4:24 pm    Post subject: Reply with quote
Looks good you should add the Hankook DynaPro ATM RF10 for 16 inch. 225/70/16 and I can confirm they will fit a syncro as I have them mounted on mine. Higher weight rating than the General Grabbers as well.
http://www.discounttire.com/dtcs/tires/hankook/pro...ruck%2FSUV
There is also a 215/85/16 but can't say how they fit.
86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion
ThankYouJerry
ThankYouJerry is offline
PostPosted: Sat Feb 08, 2014 9:04 pm    Post subject: Reply with quote
Excellent! Thanks Kamz. I know that took a ton of work/hours. Please add to the FAQs.
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
vwhammer
vwhammer is offline
PostPosted: Sat Feb 08, 2014 9:24 pm    Post subject: Reply with quote
I also have the 225/70R16 Hankook Dynapro ATM that I am attempting to squeeze under an 85 tin top.
I am excited to see what I need to do.
Anyway this is a good list.
View user's profile Send private message Yahoo Messenger Instagram Classifieds Feedback
childofthewind
childofthewind is offline
PostPosted: Sat Feb 08, 2014 9:26 pm    Post subject: Reply with quote
This is very helpful. Thanks, Kamz!
1987.5 wolfsburg hardtop; 2.1
“As for me, I am tormented with an everlasting itch for things remote." - Melville
jimeg
jimeg is offline
PostPosted: Sat Feb 08, 2014 10:57 pm    Post subject: Reply with quote
Great to see the facts laid out, and the 14" tire options - which there are many
Interesting. The 14" 195 was not a factory size tire?
Here is one I've been curious about. Anyone using these?
Radar RPX 878 LT195R14C D/8PR
Radar RPX 878
LT195R14C D/8PR
Type of TireCommercial
$76.10
http://www.tires-easy.com/cgi-bin/rshop.pl?dsco=13...p=R-197244
1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490
luVWagn
luVWagn is offline
PostPosted: Sun Feb 09, 2014 12:34 am    Post subject: Reply with quote
I nominate for sticky!!!
'91 Double Door Transporter
1621
1621 is offline
PostPosted: Sun Feb 09, 2014 12:46 am    Post subject: Reply with quote
Kam, excellent post. Another great tire to add is the Nokian WRC Cargo. It's got a higher ply-rating than similarly constructed WRC Van, with a unidirectional tread, lots of siping, and is still listed as all-weather. Very stout tire with a high load rating. I run the tall/narrow 205/75-16, Load Rated E, and they also offer other comparable sizes in 16", plus one wider 15" model. They are carried by Tires By Web, among others.
http://www.nokiantyres.com/tyre?id=10360798&group=3.01&name=Nokian
'85 Westy
regis101
regis101 is offline
PostPosted: Sun Feb 09, 2014 6:11 am    Post subject: Reply with quote
PM me your land address. I'll buy ya lunch.
Peace, ~R
Tobias Duncan
Tobias Duncan is offline
PostPosted: Sun Feb 09, 2014 9:02 am    Post subject: Reply with quote
For a super cheap alternative in 14 inch you might look at these.
I have been running a set on my 90 2nd westy since mid summer.
Excellent on windy mountain highways but not much traction off road.
http://m.discounttire.com/dtcs/tires/gt_radial/product/submitProductSize.do?r=AZPINT&pc=12415
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sun Feb 09, 2014 12:38 pm    Post subject: Reply with quote
Nice work, Kam! Wink
The Continental ContiPro Contact and Extreme Winter Contact in 225/55-16 XL have a 99H rating. 1709 lbs. at 51 PSI
I have a set of each for my van. They are really good tires and are exactly the same diameter as stock.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
insyncro
Banned
insyncro is offline
PostPosted: Sun Feb 09, 2014 12:41 pm    Post subject: Reply with quote
Thank you for taking the time Kam Cool ...awesome work Exclamation
dobryan Premium Member
dobryan is offline
PostPosted: Sun Feb 09, 2014 1:34 pm    Post subject: Reply with quote
Dancing Dancing Applause
Maybe call this "What TIRES fit? The ultimate tire post" And place it as Sticky so it complements the "what wheels fit..." one.
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
geo_tonz
geo_tonz is offline
PostPosted: Sun Feb 09, 2014 3:13 pm    Post subject: Reply with quote
Very nice compilation!! Can't imagine what motivated you on this one!!! Rolling Eyes Make sure to sticky yourself!!
Red Vanagon "Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper
syncroid
syncroid is offline
PostPosted: Sun Feb 09, 2014 3:59 pm    Post subject: Reply with quote
I've got the 225/70/16 dynapro atm rf10s on my syncro. Very tough but quite loud. Noise is partly due to my worn out shocks making them wear in a way that's made the blocks have a sloped instead of flat surface on the front pair.
Would love to compare noise levels, but not an easy figure to quote.
Good post.
kamzcab86
PostPosted: Sun Feb 09, 2014 6:05 pm    Post subject: Reply with quote
Tires and more info added. Cool
Done (although, at least one sticky has to go... it's getting a bit out of hand; think I'll merge a few together eventually).
2016 Golf GTI S
ThankYouJerry
PostPosted: Sun Feb 09, 2014 8:56 pm    Post subject: Reply with quote
Again, thank you so much Kamz.
Now, what I'd appreciate from the rest of the forum members would be real life reviews of these tire options (handling wet/dry, longevity, road noise, etc). For example: I have a new set of Nokian WRG3s and will be happy to report back after I've logged enough miles to have a credible opinion.
Ever get the feeling that Tire Rack's "surveys" are total BS Laughing ? I'd trust the collective wisdom of The Samba over Tire Rack ANY DAY!!!
DAV!D
DAV!D is offline
PostPosted: Sun Feb 09, 2014 9:14 pm    Post subject: Reply with quote
Good post.
Sadly I didn't get to drive mine much with the new tires as I tore it apart for a engine swap. I never really had it out on a highway or really over 45mph but I didn't notice any excessive road noise from mine.
I was toying with seeing if I could squeeze them on my 2wd westy just for kicks while the syncro is tore apart. If I do, I'll report back on road noise.
Wildthings
Wildthings is offline
PostPosted: Sun Feb 09, 2014 11:37 pm    Post subject: Re: What TIRES fit? The ultimate tire thread! Reply with quote
kamzcab86 wrote:
The above is the minimum weight rating you should use when shopping for new tires. However, the lowest weight-rated tire originally installed on Vanagons by Volkswagen was 1580 lbs. (load index 97, reinforced sidewalls), which gives you a safety margin when your van is driven fully loaded.
As you pointed out elsewhere extra load passenger tires must be derated, which mean the stock 205/75r14's would have been rated at just over 1433 pounds for use on a MPV.
big toe
big toe is offline
PostPosted: Mon Feb 10, 2014 10:46 am    Post subject: Reply with quote
Helpful info, thanks. Any way to list it in a spreadsheet? It might be easier to digest and cross compare that way.
I can't find the Kumho KL78 for sale anywhere, not even on the Kumho site. Anyone have a link?
27x8.5R14 LT
Load range: D
Load index: 101Q
Max load: 1820 lbs.
Max psi: 65
57 R50, 60 R60, 65 Tempest, 66 Bul, 67 R69, 72 Combat, 73 Eldo, 91 SS, 91 Westy, KTM 950A, etc
Page 1 of 58
