Richard Roth Samba Member
Posted: Sat Dec 02, 2017 1:24 pm Post subject: glove box trim clip rubber boots ? |
Does anyone make or have the three small boots used with the clips to mount the chrome trim on the glove box ?
They look just like the boots used to mount the body side trim, only smaller. _________________ The problem with reality is that there's no background music !
1966 Empi GTV MKIV
1954 Kabriolett Beetle
1953 Porsche 356 1500S
1957 Cable brake standard model
1962 cable brake standard model
1956 23 window Samba
1960 Austin Healey 3000
1961 Corvair Greenbrier |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16828 Location: State College, PA
Posted: Sat Dec 02, 2017 2:04 pm Post subject: Re: glove box trim clip rubber boots ? |
I dont remember ever using rubber boots for the dash trim..The clips just go through the holes. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Posted: Sat Dec 02, 2017 2:07 pm Post subject: Re: glove box trim clip rubber boots ? |
There were originally rubber boots in the holes. _________________ The problem with reality is that there's no background music !
1966 Empi GTV MKIV
Posted: Sat Dec 02, 2017 3:20 pm Post subject: Re: glove box trim clip rubber boots ? |
The most likely place to have them is Wolfsburg West, and they dont. So, not sure where you will find them. You don't need them. _________________ D-Dubya Manx clone 1914. Ex wifes car.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11225 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Dec 02, 2017 3:24 pm Post subject: Re: glove box trim clip rubber boots ? |
Originally the dash trim had grommets.
Sometimes the trim will rattle without them.
https://www.thesamba.com/vw/forum/viewtopic.php?t=582279&start=0
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 366 Location: Green Bay, WI
bluebus86 Banned
Posted: Sat Dec 02, 2017 4:47 pm Post subject: Re: glove box trim clip rubber boots ? |
the rubber seals also keep cold air from blowing thru the trunk to the cabin thru the trim holes. so noise, cold air,are reasons the factory used them My 61 had them stock.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sat Dec 02, 2017 7:24 pm Post subject: Re: glove box trim clip rubber boots ? |
Solved the problem back in the day, in 2 ways: prevent drafts by making sure the hood seal is properly fitted; and adjust the wings on the trim clips to make them grip tighter. (You may have to damage them, and the trim, to get them off again, but ...no rattles.) _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
mukluk Samba Member
bluebus86 Banned
hitest Samba Member
Joined: September 30, 2008 Posts: 10332 Location: Prime Meridian, ID
Posted: Sun Dec 03, 2017 10:21 am Post subject: Re: glove box trim clip rubber boots ? |
Thanks for finding these! I'm stocking up to replace the ones I've pieced together from various swap meet finds. _________________
| EverettB wrote: |
FU#5 |
