Really stupid question
srobinson
srobinson is offline
PostPosted: Tue Apr 29, 2014 7:27 pm    Post subject: Really stupid question Reply with quote
So I have a 69 Ghia and I shaved the gas door off and now put a older style gas tank in it. (So I have to open the "trunk" to put gas in now)
Anyway, with that style of gas tank since it is made for earlier ghia's does the stock gas gauge in a 69 work with it? My brain says yes, but curious.....
I know...really stupid question....sorry Embarassed Embarassed Embarassed
KGCoupe
KGCoupe is offline
PostPosted: Wed Apr 30, 2014 7:42 am    Post subject: Reply with quote
As I understand it, the gas gauge must match the gas tank sending unit.
So if you are transferring in the working pair from your old gas tank, it should be fine.
Someone please correct me if I'm wrong on that.
srobinson
PostPosted: Wed Apr 30, 2014 7:47 am    Post subject: Reply with quote
I bought a new sending unit but may have bought the wrong one. Not sure. guess I will post some pics here in couple days then someone can tell me for sure.
djkeev
djkeev is offline
PostPosted: Wed Apr 30, 2014 9:26 am    Post subject: Reply with quote
If it fits in the tank and seals, use the one for your year.
The earlier gauges, 1966 and earlier, were mechanical, a cable from the sender to the gauge.
Or, just plug it in and see if it registers, just move the float, it doesn't need to actually be in the tank, just wired and grounded properly
Dave
Ghia
Vanagon
Beetle
sactojesse
sactojesse is offline
PostPosted: Wed Apr 30, 2014 10:00 am    Post subject: Reply with quote
I did the same modification to my former 1969 ghia coupe 20 years ago after it was hit by an uninsured motorist. I simply took my existing fuel gauge sending unit and transferred it to the older style filler-in-trunk fuel tank.
1966 Karmann-Ghia convertible
c21darrel
c21darrel is offline
PostPosted: Wed Apr 30, 2014 11:08 am    Post subject: Reply with quote
If you can find a mechanical gauge...Its just a cable and float. I think its the eaisest way to solve if your current elec setup doest work. I used the Wolfsburgwest repop mechanical sender and got a mechanical gauge at a swapmeet cheap. Foolproof.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113919049C
GhiaBuild
1967 DC build
scottkrough
scottkrough is offline
PostPosted: Thu May 01, 2014 8:57 am    Post subject: Re: Really stupid question Reply with quote
Buddy there is no stupid questions...
I would change to a mechanical guage if I were you. They just scream coolness...LOL
Or put your sending unit from the '69 in the earlier tank... Providing it will fit of course... I have never tried anything from a 68 or later fuel tank in an earlier version but I know you can do this..
Good luck and post some pics of where your at in the process..
Scott
Check out our 63' Ghia Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=519643
sactojesse
PostPosted: Thu May 01, 2014 9:29 am    Post subject: Re: Really stupid question Reply with quote
It fits. As discussed in my earlier post, I've done it before.
scottkrough
PostPosted: Thu May 01, 2014 11:06 am    Post subject: Reply with quote
Thats great... It fits...
BTW
Nice looking vert Sactojesse
Scott
sactojesse
PostPosted: Thu May 01, 2014 11:23 am    Post subject: Reply with quote
BTW
Thanks! Smile
