help with westfalia tag infomation
guystclair
guystclair is offline
PostPosted: Mon Dec 22, 2014 6:04 pm    Post subject: help with westfalia tag infomation Reply with quote
When i got my westy, it only had the Z-bed when i bought it. I'm trying to find out the actual options it came with... when i got it it was a hi-top, from what i can see it might have been a tin top at first. it does have a hole in the floor behind the passenger seat. came anyone help me!?!
1969 bug
guystclair
PostPosted: Mon Dec 22, 2014 6:06 pm    Post subject: Reply with quote
Also, is it true that passengers can legally drink in the back when i'm driving or is this a mith?
1969 bug
Tcash
Tcash is offline
PostPosted: Mon Dec 22, 2014 6:26 pm    Post subject: Reply with quote
Campers
1970 Westfalia
Type 2/Bus Owner's Manuals
Bus Literature
Nice looking camper.
Tcash
force3g
force3g is offline
PostPosted: Mon Dec 22, 2014 6:56 pm    Post subject: Reply with quote
Read Tcash's links. If you are interested in getting some fresh tags on that awesome bus, see below.
http://www.thesamba.com/vw/forum/viewtopic.php?t=614507
Never shoot a large caliber man with a small caliber bullet.
1970 Westy
2010 Jetta
kevhum
kevhum is offline
PostPosted: Mon Dec 22, 2014 7:19 pm    Post subject: Reply with quote
What does the M code say? It will tell you if it was destine to be A westy.The tags are screwed on on your bus .factory they were riveted on.and I haven't seen the westy tag like the one you have put on the side of the bus.If it has A stock sunroof hole in it it could have had A poptop at one time.
BUSBOSS
BUSBOSS is offline
PostPosted: Mon Dec 22, 2014 8:27 pm    Post subject: Reply with quote
Myth.
Show us your M plate and we can help you. Also, I agree with the earlier post that noted that your dog leg tags have been screwed in. They were originally riveted on at the dealership not the factory. Yours could be original and simply used a modified install for a paint job.
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
guystclair
PostPosted: Mon Dec 22, 2014 11:04 pm    Post subject: Reply with quote
this is what I got... (H67 SO67 Westfalia Campmobile interior
67H (1968-1970) - 2x8 000 001 2x0 2 300 000)
M-Plate content
Model Type 2 (T2) mod. 231(0) :
- Kombi
- Sliding door right
- LHD
Chassis number 2302071873
Serial number 071 873
Modelyear 1970
Planned production date Friday, 07 November 1969
Number for production planning (temporary serial number) 7299
Type of engine Type 1 (B5) - 1584cc, 35 kW (47 bhp DIN)
Type of transmission Manual 4-speed gearbox
Paint color L87 - Perl White
Remark : Westfalia
Interior color (doorpanels and seats) - Westfalia Campmobile
Destination USA, Los Angeles
M-CODES
M-CODE Description Concerned models
From chassis number To chassis number 026
With activated carbon container for absorbing fuel vapour 211-274, California 2x2 2 300 000
026 With activated carbon container for absorbing fuel vapour 211-234, Japan
2x6 2 120 000
026 With activated carbon container for absorbing fuel vapour 211-234, Autralia
2x6 2 120 000
507 Vent wings in cab doors 211-235
261-274
517 Factory prepared for campmobile interior - 2x4 2 057 729
D26 Collection of M-codes: M 020/089/102/206/511/524/525 - 2x0 2 000 001 2x0 2 300 000
020 Speedometer and odometer in Miles 211-274
089 Laminated windscreen (1969-1979) - 2x9 000 001 2x9 2 300 000
102 Rear-window defogger 211-268
206 Inner rear-view mirror, anti-dazzle -
511 Padded instrument panel (LHD only) 211-271
524 Sealed beam headlamps, dual circuit brake control, back-up light and side marker reflectors (LHD) without emergency light system 211, USA, Canada
241, USA, Canada
265, USA, Canada
2x9 000 001 2x9 999 999
524 Sealed beam headlamps, dual circuit brake control, back-up light and side marker reflectors (LHD) with buzzer for ignition-starter switch 211, USA, Canada
241, USA, Canada
265, USA, Canada
2x0 2 000 001 2x2 2 000 000
524 Sealed beam headlamps, dual circuit brake control, back-up light and side marker reflectors (LHD) 211, USA, Canada
241, USA, Canada
265, USA, Canada
2x2 2 000 001
525 Three-point safety belts front, left and right and lap belts in passenger compartment 211-265, USA, Canada
H67 SO67 Westfalia Campmobile interior 67H (1968-1970) - 2x8 000 001 2x0 2 300 000
4 285 801
Réalisation : agence web California 68.
1969 bug
moxnix
moxnix is offline
PostPosted: Mon Dec 22, 2014 11:17 pm    Post subject: Reply with quote
At least in MN, yes, when I looked into this about 8/10 years ago - if you have RV plates and some kind of partition between you and your passengers, they can drink.
I have allowed this time to time years ago before I had kids, and trust me the fun/novelty wears off real quick if you're the one driving...
Ritterlich im Kriege, wachsam für den Frieden
guystclair
PostPosted: Mon Dec 22, 2014 11:21 pm    Post subject: Reply with quote
my M plate
1969 bug
guystclair
PostPosted: Mon Dec 22, 2014 11:29 pm    Post subject: Reply with quote
the big question is what interior options did it come with... stove, icebox jump seat behind the driver, closet or sink? ...
1969 bug
kevhum
kevhum is offline
PostPosted: Mon Dec 22, 2014 11:46 pm    Post subject: Reply with quote
yours had A wesy kit ,came with A closet,jump-seat behind drivers seat,the fold out bed and A cabinet with A icebox and sink.the hole in the floor was from the sink drain.Most likely had A poptop but I'm not sure if it states that in the Mcode. you can tell buy seeing if the hole in the roof is A factory sunroof hole.Someone could have replaced the poptop with A hightop.
kevhum
kevhum is offline
PostPosted: Mon Dec 22, 2014 11:53 pm    Post subject: Reply with quote
this link shows what your interior should be,68 to 71 are all similar to each other with little changes http://john-perry.com/vw/gallery.html
richparker
richparker is offline
PostPosted: Tue Dec 23, 2014 12:08 am    Post subject: Reply with quote
I would look at campers link Tcash posted, I bet there is a campmoblie in there.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
guystclair
PostPosted: Tue Dec 23, 2014 7:20 am    Post subject: Reply with quote
buy the looks of the sunroof hole, it looks like someone cut it with tin snipes and on the sides, it looks like the roof supports were cut haft assed tot making me thing it was a tin top! wow, thanks for all your inputs !
1969 bug
Opossum
Opossum is offline
PostPosted: Tue Dec 23, 2014 8:26 am    Post subject: Reply with quote
It must be registered as a "housecar". Your registration will have "HSCR" under body type model.
"You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner
williamM
williamM is offline
PostPosted: Tue Dec 23, 2014 8:27 am    Post subject: Reply with quote
Sounds like adventure wagon - mine looked like a Hack- It was also cut way back to the the rear and had a support bar under the head banger panel designed to really "get you" when ever you got out of the back seat. The westfalia stuff could have been added later.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
