orbeas Samba Member
Joined: August 31, 2014 Posts: 18 Location: Gwynedd UK
Posted: Sun Aug 31, 2014 10:20 am Post subject: Which Spark Plug ?? |
What spark plugs are people using in tuned engines - Mine is a 2.1 type 4
any advice welcome |
subhuman Samba Member
Joined: January 22, 2008 Posts: 542 Location: north carolina
Posted: Wed Sep 03, 2014 7:56 am Post subject: Re: Which Spark Plug ?? |
| orbeas wrote: |
i have great results from the ngk br5es gap set at 32. 2110cc type 1, 8.75to1cr, 120 cam, 1.25 rockers, 44 webers, msd 6al, etc. _________________ 63 restomod build
http://s431.photobucket.com/albums/qq37/johnnysubhuman/?albumview=slideshow
you can have everything you want, just don't want so much!
"the wrong way always seems the more reasonable."
george moore
1963 type1
2002 Subaru Wrx
never argue with an idiot, they will only drag you down to their level and beat you with experience!
Mark Twain |
Posted: Wed Sep 03, 2014 7:59 am Post subject: Re: Which Spark Plug ?? |
NGK BP6ET _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Wed Sep 03, 2014 8:07 am Post subject: Re: Which Spark Plug ?? |
any special reason you like that paticular plug in a performace engine? _________________ 63 restomod build
george moore
1963 type1
2002 Subaru Wrx
Mark Twain |
Posted: Wed Sep 03, 2014 8:17 am Post subject: Re: Which Spark Plug ?? |
Yes, it's the best.
| subhuman wrote: |
any special reason you like that paticular plug in a performace engine? |
Posted: Wed Sep 03, 2014 8:21 am Post subject: Re: Which Spark Plug ?? |
| [email protected] wrote: |
Yes, it's the best.
| subhuman wrote: |
just switched over to these, all i can say is they are awsome, chrisper throttle response, better idle, really made an overall huge difference, highly recomended! _________________ 63 restomod build
george moore
1963 type1
2002 Subaru Wrx
Mark Twain |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1418 Location: North Carolina
Posted: Wed Sep 16, 2015 9:25 am Post subject: |
| BP6ET....is this the correct plug for the LN3 heads? I know the heads use 3/4" reach plugs but not sure if they are 12mm or 14mm. Can't find any diffinitive info on the this and just installed engine into bus b4 I verified. |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Wed Sep 16, 2015 9:31 am Post subject: Re: Which Spark Plug ?? |
John, do you use that in all vw engines or just performance? _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23320 Location: Oklahoma City
Posted: Wed Sep 16, 2015 10:48 am Post subject: |
I agree with that...by far. I have been using these plugs and the Bosch W7DTC...same plug by Bosch for about 25 years now on type 4's...and used them before that on water cooled VW.
They are especially good and designed for.... high compression moderate to lean burn engines that see high rpms and/or lots of highway. They have three electrodes...only one of which fires at any given time.....but they all regularly fire.....as can be seen from exact even wear patterns. They last a very long time.
The cage of electrodes allows better interspersing of fuel air inside the cage and this gives a better flame kernel at the start of ignition. Also....the spark will jump whatever gap has the least resistance at the ionization point.
This changes from millisecond to millisecond due to compression pressure, surface temp of electrode etc. In a less tan modern system with no fancy ion-sensing controls to pump the pulses up and down according to sensing of electrode requirements (most modern VW, Audi and others use this)......this works about as good as you can get.
Some think these are only high compression motorcycle engine plugs (many high performance cycles use them for all of these reasons)...but they were also the stock plug of choice on many CIS and CIS-E injected and some digifant injected high compression engines through the 80's and into the 90's....like the GTI golf.
They also like voltage. They work much better with a change as simple as something like a 42Kv coil from Pertronix. Very smooth....very uniform ignition. A noticeable upgrade.
OH....and they come precisely gapped from the factory. they can be regappped but you must be precise. The electrode gaps need to be even. You will need this gap tool.....best I have ever found.
http://www.europaparts.com/spark-plug-gap-tool-098...aQod7_ADQQ
Ray |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4277 Location: deepest, darkest Switzerland
Posted: Wed Sep 16, 2015 2:05 pm Post subject: |
| To me, he interesting part in BP6ET is the "P". That means that the plug and center electrode protrudes into the chamber where it gets cleaned by the gas flow. The "P" plugs don't foul easily. The 3-electrodes business is good for longevity. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3661 Location: Paradise, Ca
Posted: Wed Sep 16, 2015 2:52 pm Post subject: Best Plugs |
Just fyi you can get the Bosch W7DTC plugs on closeout right now from Rockauto for $1.53 each. I just bought 16 of them. With shipping worked out to be $2.10 each for me.
These are same as what NGK's that John mentioned but better, with the nice nickel rolled threads.
https://www.rockauto.com/catalog/raframecatalog.ph...plate=true
They are available from multiple suppliers on ebay also.
Jeff _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Wed Sep 16, 2015 3:35 pm Post subject: Re: Best Plugs |
| jpaull wrote: |
Jeff |
Thank you for that heads up. I started my own hoard about last year whenever I find them cheap.....I have three boxes of 10 plugs. Always room for a, few more at that cheap. Ray |
jpaull Samba Member
Posted: Thu Sep 17, 2015 12:21 am Post subject: Re: Best Plugs |
| raygreenwood wrote: |
| jpaull wrote: |
Jeff |
Thank you for that heads up. I started my own hoard about last year whenever I find them cheap.....I have three boxes of 10 plugs. Always room for a few more at that cheap. Ray |
Yes stock up now! Its hard to get even standard cheap plugs for under $3 anymore _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
maui Samba Member
Posted: Thu Sep 24, 2015 10:16 pm Post subject: |
| Denso Q20PR-U ,40 gap |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri Sep 25, 2015 9:50 am Post subject: |
Anyone have a suggestion upgrade plus with extended prong 12mm, 3/4"? Currently running d8ea-9s. _________________ 2276 IDA's 86C 11-1 DD
| Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Tue Sep 29, 2015 4:18 pm Post subject: Re: Which Spark Plug ?? |
Went to Advance Auto this weekend to pick up a few of these plugs. Why did the guy tell me that they would not fit in my car? Maybe because mine is a type 1? _________________ -Jared
jpaull Samba Member
Posted: Tue Sep 29, 2015 5:22 pm Post subject: Re: Which Spark Plug ?? |
| jpjohns wrote: |
Went to Advance Auto this weekend to pick up a few of these plugs. Why did the guy tell me that they would not fit in my car? Maybe because mine is a type 1? |
Remember that most the parts guys got hired straight from Burgerking. There computer screen tells them BR6HS is the only NGK you can use so anything else to them will be wrong. If your asking them to think and cross reference a better plug that fits and might work better your going way above their pay scale.
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2916 Location: Virginia
Posted: Tue Sep 29, 2015 6:38 pm Post subject: |
In thinking of the NGK BP6ET that Aircooled Jon spoke of, they are a 3/4" Reach Plug that may fit my 2180. Thing is from what I read they pertrude some, or is it just the way I read it? Why, I am thinking of trying them out with my CB Street Eliminator Heads to see what happens, or is this plain dumb, thing is I am looking for a good all around plug, my compression is not sky rocket, but I am running an Engle 120 Cam w/1 to 1 Ratio Rockers.
What is yalls take, like to hear from Jon on this if he is around? RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Posted: Tue Sep 29, 2015 9:50 pm Post subject: |
Whats unique about the BP6ET and the Bosch W7DTC....is the electrode configuration.
Pay attention.....to the fact that they are 3/4" reach. Stock style tyoe 1 hwads cannot use them unless you have aftermarket heads set up for 3/4" reach like a type 4.
That being said.....i would bet that ir i looked at the Bosch or NGK identifier chart....i could pull up a part # for the triple electrode for type 1 heads and thread reach. Now....whether its in stock anywhere...who knows. Ray |
vince1 Samba Member
Joined: December 14, 2003 Posts: 841 Location: Burgundy, France
