pushkick Samba Member
Posted: Sat May 23, 2015 3:32 pm Post subject: How much do you torque your lugs? |
on standard steel rims how much do you torque your wheel lugs?
the reason i am asking i am thinking about buying cordless impact tool.
want to make sure it will work. _________________ i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Sat May 23, 2015 3:43 pm Post subject: |
Why would you use/trust an impact tool to torque your lugs?
I remember Bentley as saying 123 ft.lbs., dry.
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Sat May 23, 2015 3:48 pm Post subject: |
Goldilocks tight _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Sat May 23, 2015 3:56 pm Post subject: Re: how much do you torque your lugs |
| pushkick wrote: |
want to make sure it will work. |
A torque wrench is what will work.  |
Posted: Sat May 23, 2015 4:19 pm Post subject: |
This raises a good question.
If you follow Bentley's 123 ft.lbs. on original steel,
what torque do you use on aluminum wheels? |
insyncro Banned
Posted: Sat May 23, 2015 4:23 pm Post subject: |
Going tighter is not better.
Ask your brake rotors/drums. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10307 Location: Mt Lemmon, AZ
Posted: Sat May 23, 2015 5:41 pm Post subject: |
| Steve M. wrote: |
| Why would you use/trust an impact tool to torque your lugs?... |
Perhaps the OP is wondering if the cordless impact wrench will be stout enough to undo a properly torqued lug.
To the OP - in my experience the torque claims made by electric impact wrenches are wildly optimistic. They certainly have their uses but don't expect miracles. |
Pondo Samba Member
Joined: February 22, 2011 Posts: 40 Location: Northern CA
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Sat May 23, 2015 6:13 pm Post subject: |
Peter at Van Cafe advised me 123# on my 15" Carrot Wheels (alloy). _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Sat May 23, 2015 7:30 pm Post subject: |
My thought would be to use the impact to spin the lugs on and off quickly, but use a torque wrench to finish tightening. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
rubbachicken Samba Member
Posted: Sat May 23, 2015 7:37 pm Post subject: |
i always go to 120 ftlbs and go around twice.
i met a van who had new wheels put on, who ever put them on, only went around once 2 of 5 were tight, the rest were loose
same on all the wheels.
the center of the wheel was tight on the rotor, too tight, so they got to torque, but they were not seated on the rotor as the should have been. _________________ lucy our westy
lucy's BIG adventure
meet 'burni' |
Posted: Sat May 23, 2015 7:44 pm Post subject: |
That is about as good an article as I have seen. What it doesn't mention though is that under torquing the lugs can cause the lugs to seize/gall to the wheels from the tiny bit of movement they get from the lug nut working against the seat. When I first took my '91 into my local tire place in a town with lots of Vanagons, they flat out refused to tighten the lugs any tighter than 90ft*lbs because they were having too much trouble removing them at that torque and they believed that if they tightened them tighter they would not be able to get them off at all. Well I stood my ground and forced them to tighten them to 123ft*lbs. They eventually consented to doing so and also tried the higher torque out on some other Vanagons. What they found was that the lugs were easier to remove months or years later when torqued to the proper specs and not harder.
These days and for probably the last decade I have not had to tell them to use the 123ft*lbs spec, they just do it, though I do still routinely quiz them on the specs. |
Terry Kay Banned
Posted: Sun May 24, 2015 7:21 am Post subject: |
Three hammer's on your 1/2" impact will do just fine.
Perfect-- _________________ T.K. |
Gauche1968 Samba Member
Posted: Sun May 24, 2015 8:20 am Post subject: |
Stock steel wheels: 133 ft/lbs front, 123 ft/lbs rear, right? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
Posted: Sun May 24, 2015 9:08 am Post subject: |
| Gauche1968 wrote: |
| Stock steel wheels: 133 ft/lbs front, 123 ft/lbs rear, right? |
