Weber issue
sen2two
sen2two is offline
PostPosted: Sat Jun 25, 2016 4:49 pm    Post subject: Weber issue Reply with quote
When shutting my fuel pump off to kill the car. The car continues to run until it drains the entire fuel bowl. I have an exrernal fuel bowl sight glass from JayCee and I can watch it drain from there while it's idling with all the power shut down.
It's a single 51mm IDA Weber with a Mallory 140 pump. Mallory 4309 return regulator. Has 4psi while fuel pump is on with car off and 3.5psi with car idling. -6 fuel feed and return.
This is a 12a Rotary engine, but I don't think that makes a difference.
HRVW
HRVW is offline
PostPosted: Sat Jun 25, 2016 5:38 pm    Post subject: Re: Weber issue Reply with quote
I can understand turning the fuel pump off but there is still pressure after the pump to the Carb and the float will still allow the fuel to enter the bowl.
If your Ignition is still on to the coil the engine will continue to run until the fuel in the bowl is Kaput (gone) like going Dry.
I have a Turbo 1776 engine with a glass filter between the pressure regulator and the Weber DCOE Carb to verify the pump is working.
The pump is a Facet and my pressure to the Carb is at 2.5 lbs....Webers like that.
modok
modok is offline
PostPosted: Sat Jun 25, 2016 6:11 pm    Post subject: Re: Weber issue Reply with quote
I think you forgot to mention what the problem is.
sen2two
sen2two is offline
PostPosted: Sat Jun 25, 2016 8:15 pm    Post subject: Re: Weber issue Reply with quote
I did. Maybe I wasn't clear.
When I shut the car down. It continues to idle for about 20-30 seconds as is draws the fuel from the bowl until it is empty.
[email protected]
john@aircooled.net is offline
PostPosted: Sat Jun 25, 2016 8:16 pm    Post subject: Re: Weber issue Reply with quote
your spark plugs are likely too hot. Try a couple steps colder.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
modok
modok is offline
PostPosted: Sat Jun 25, 2016 8:33 pm    Post subject: Re: Weber issue Reply with quote
Idling with ignition off.
That's called dieseling. Dieseling might be a problem or it might not. sometimes they will diesel when there is no actual problem. This is why the majority of carbs have anti-diesel solenoids.
IDA is a racing carb and does not have idle cutoff solenoid, because you don't need one. How do you stop it from dieseling?
Put it in high gear and release the clutch.
ps2375
ps2375 is offline
PostPosted: Sat Jun 25, 2016 8:34 pm    Post subject: Re: Weber issue Reply with quote
Turning off the fuel pump won't stop the carb from working, it works until there is no more fuel in it, then it stops working.
earthquake
earthquake is offline
PostPosted: Sun Jun 26, 2016 12:33 pm    Post subject: Re: Weber issue Reply with quote
Does it have a MSD 6 box on it by chance? If it does it might need the diode in line to kill the power from the alternator.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
