Vanagon fire at gas station - Portland OR
thatbaldwinlife
thatbaldwinlife is offline
PostPosted: Thu Jun 11, 2015 1:28 pm    Post subject: Vanagon fire at gas station - Portland OR Reply with quote
anyone on here?
http://www.kptv.com/story/29298001/crews-respond-t...start=true
eek
nate
TequilaSunSet
TequilaSunSet is offline
PostPosted: Thu Jun 11, 2015 1:44 pm    Post subject: Reply with quote
Another syncro bites the dust... change dem fuel lines...
Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me
BlueGrasser
BlueGrasser is offline
PostPosted: Thu Jun 11, 2015 1:46 pm    Post subject: Reply with quote
NOOOO!!!
Man that sucks Crying or Very sad
Going to where the grass is bluer...
1985 Vanagon Westfalia Camper with 1.8T
elecakvan
elecakvan is offline
PostPosted: Thu Jun 11, 2015 1:52 pm    Post subject: Reply with quote
bummer...
61Scout
61Scout is offline
PostPosted: Thu Jun 11, 2015 1:55 pm    Post subject: Reply with quote
That does suck, but at least it sounds like no people or pets were hurt. Things could always be worse. Does remind me to check my shop and westy extinguishers, and to purchase a new one for the tintop.
-Kevin
1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu
Steve M.
Steve M. is offline
PostPosted: Thu Jun 11, 2015 2:10 pm    Post subject: Reply with quote
Well what can you say...if their Samba members that's just TFB because it has been over stated enough to change fuel lines and check electrics. Not to be that unsympathetic. Hope no one was hurt, but dammit -it is a known issue among Samba members.
If their not a Samba member then you can say ignorance on their part, but if they did not do the work on it themselves then there is a shop somewhere to blame for not pushing fuel line replacement as a preventive. Or they were told and pooh-poohed it ...who knows!
Loving my "Blazecut" even more!
Steve M.
Steve M. is offline
PostPosted: Thu Jun 11, 2015 2:20 pm    Post subject: Reply with quote
One would think there was a fire extinguisher in the gas station...
thatbaldwinlife
Maybe it wasn't fuel lines?
Steve M.
Steve M. is offline
PostPosted: Thu Jun 11, 2015 2:24 pm    Post subject: Reply with quote
yeah true too, that's why I said electrics.
BlueGrasser
PostPosted: Thu Jun 11, 2015 2:31 pm    Post subject: Reply with quote
The article states:
Workers at the station tried to stop the fire with extinguishers but were unsuccessful.
The guy (or lady) has my sympathy either way. I'd be devastated. Sad
mr white
mr white is offline
PostPosted: Thu Jun 11, 2015 2:41 pm    Post subject: Reply with quote
I saw this bus on the tow truck near Cedar Hills. This bus is no longer with us! Glad nobody was killed!! It looked really bad
Wildthings
Wildthings is offline
PostPosted: Thu Jun 11, 2015 3:16 pm    Post subject: Reply with quote
Sadly one shouldn't need to be a Samba member to know that these thing are unlit torches. This has been know for day one. VW should have been required to do a recall on the fuel system or at least voluntarily put stickers on the engine lids warning of the dangers of their poorly engineered system.
40 years ago, I changed out the fuel lines on my carbureted rigs every two year or less, and fought poor quality fuel line for years as a mechanic or maintenance supervisor. On seemingly every used rig I bought I removed the added inline filter between the pump and the carb to get rid of that ridiculous aftermarket fire hazard. Only steel between the pump and the carb for me. Then I got into VW and found out they came from the factory with rubber hose between the pump and the carb and about freaked because of how unsafe they were. Next I got into VW vans and found out they were an order of magnitude worse than Type 1's were and not surprisingly had a well deserved reputation for burning from one end to the other.
Then the Vanagon showed up on the scene after VW had been building fire traps for decades and they still didn't come close to getting it right. Lots of plastic line between the engine and the tank and no automatic valves or other precausions to prevent the tank from draining into the engine bay once a fire starts. Obviously tens of thousands of Type 1's and various model Transporters have burned over the years yet VW turned a blind eye to their engineering SNAFU's. I would hate to think what it will cost them if there is ever a class action suit over this issue.
Merian
Merian is offline
PostPosted: Thu Jun 11, 2015 3:23 pm    Post subject: Reply with quote
I agree on the recall.
The bright side is that now a bunch of syncro parts will be there to convert a 2wd...
Slimvest
Slimvest is offline
PostPosted: Thu Jun 11, 2015 3:54 pm    Post subject: Reply with quote
This is my friend's syncro. I rarely see him and can't say anything beyond his van was less than two years into a gowesty motor that was installed by a local shop.
He is very sad, to say the least. Has had the van for over 10 years.
'87 GL w/ Reimo top (sold Aug '21)
syncrodoka
syncrodoka is offline
PostPosted: Thu Jun 11, 2015 4:13 pm    Post subject: Reply with quote
Sorry to hear that slimvest. Sad
Hope his insurance does him a solid when it comes time to cut the check so that he can find a replacement.
Merian
Merian is offline
PostPosted: Thu Jun 11, 2015 4:26 pm    Post subject: Reply with quote
Tell him we all feel for him. Do you know anything about the maintenance on the fuel hoses, electrical system, etc.?
It seems like some hoses must have been new if the motor is new...
He can start over with a 2wd and use this Van for parts, or rebuild this one, depending on how damaged it is.
VWinVT
VWinVT is offline
PostPosted: Thu Jun 11, 2015 4:42 pm    Post subject: Reply with quote
How awful...glad no one was injured...
1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground.
IdahoDoug
IdahoDoug is offline
PostPosted: Thu Jun 11, 2015 6:27 pm    Post subject: Reply with quote
Wow, bummer. Funny the smoke color doesn't scream gasoline fire to me, but I don't know if that was after things calmed down or flames died down or what. It kinda looks electrical-ish. Fuel fires generally end MUCH worse.
Glad nobody was hurt.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
DAV!D
DAV!D is offline
PostPosted: Thu Jun 11, 2015 6:51 pm    Post subject: Reply with quote
2 years is on modern rubber lines with ethanol fuel is like 30 years with the original lines. The fuel we use today absolutely destroys the rubber hoses.
My last van when I swapped the motor I used fuel line from the big box auto stores and it wasn't even 6 months before the lines were cracking.. I had to replace them at that time with better quality hose.
86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion
bluebus86
Banned
bluebus86 is offline
PostPosted: Thu Jun 11, 2015 6:53 pm    Post subject: Reply with quote
Maybe it can be fixed. I don't see any evidence from the photos that fire extinguishers were used but maybe they tried that after the photos were taken. you got to act quick with an extinguisher, wasted time can make the difference between a successful fire fight and loosing it.
Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
Page 1 of 7
