Rippers Samba Member
Joined: September 08, 2011 Posts: 255 Location: London, England
Posted: Wed Jul 15, 2015 3:18 pm Post subject: Bolting the Steering column Bracket and Speedometer |
My bus was a shell when I got it so a lot was missing and I have no idea how it should have been. I've search at parts diagrams but this seems to be eluding me .
How does the steering column bracket with the knee protector rubber bolt to the dash? At the moment I have a single bolt through it but there is a smaller hole next to it so if someone can help that would be great.. pics would be even better
I am right in assuming this bracket then bolts to the parcel shelf when fitted with simple bolts and washers through the long slots?
Next the Speedo has two hooks that to me looks like you push it up and twist. There are treaded holes for this so can someone show /me tell me would should be here.. just a couple of bolts or are there special washers etc?
crofty Judas of the North
Joined: August 09, 2000 Posts: 19673 Location: Land of Whine and Phonies
Posted: Wed Jul 15, 2015 3:23 pm Post subject: |
Three bolts. One through the dash pod and the other two go through the bracket into the parcel tray from underneath. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Wed Jul 15, 2015 6:04 pm Post subject: |
IIRC the screws/bolts (technically they are machine screws) are roughly the same size as engine tin screws. You just don't need the chaser slot that those have. Install two of them in the brackets a little bit, install the speedo and then tighten up the screws! You might want to chase out the threads first and use anti-seize on the screws so they will come out easy next time. Oh, and don't forget washers. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
EverettB Administrator
Joined: April 11, 2000 Posts: 69838 Location: Phoenix Metro
Posted: Thu Jul 16, 2015 1:05 am Post subject: |
Thanks guys |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Jul 16, 2015 7:04 am Post subject: |
EverettB wrote: |
My '61:
The small screw you see there is the mounting screw for the ignition |
Everett, your bus is upside down! _________________ regards
Uli
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Fri Jul 17, 2015 6:34 pm Post subject: |
mandraks wrote: |
EverettB wrote: |
My '61:
Everett, your bus is upside down! |
HAHA! That made my night!! _________________ 77 Westy - Cape Cod Sage
LLAP |
sandtrooper747 Samba Member
Joined: July 14, 2015 Posts: 32 Location: Raleigh, NC
Posted: Thu Feb 09, 2017 7:44 pm Post subject: Re: Bolting the Steering column Bracket and Speedometer |
Does anyone know what size bolts those are? |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Tue Feb 14, 2017 7:34 pm Post subject: Re: Bolting the Steering column Bracket and Speedometer |
Thanks mate!
70bus Samba Member
Posted: Fri Mar 01, 2024 12:08 am Post subject: Re: Bolting the Steering column Bracket and Speedometer |
I didn’t see this asked or answered anywhere- does the bolt holding this bracket to the speedo pod have a captive nut in the speedo pod, or do you just put a washer and nut on the bolt to hold it all together? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
"If Von Dutch was alive, he'd walk in there with a pistol and shoot these people."
-Robert Williams |
mdege Samba Member
Joined: January 16, 2018 Posts: 943 Location: Niederkruechten, Germany
Posted: Fri Mar 01, 2024 12:51 am Post subject: Re: Bolting the Steering column Bracket and Speedometer |
70bus wrote: |
I didn’t see this asked or answered anywhere- does the bolt holding this bracket to the speedo pod have a captive nut in the speedo pod, or do you just put a washer and nut on the bolt to hold it all together? |
I assume the pod is the same on European busses which have the steering column lock. With the steering column lock the screw gets screwed in from the top, therefore you can't have a captive nut there. _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
Posted: Fri Mar 01, 2024 8:20 am Post subject: Re: Bolting the Steering column Bracket and Speedometer |
70bus wrote: |
Nut, as seen here
_________________ How to Post Photos
campingbox Samba Member
Joined: November 14, 2000 Posts: 10200 Location: Petaluma, CA
Posted: Fri Mar 01, 2024 10:31 am Post subject: Re: Bolting the Steering column Bracket and Speedometer |
70bus wrote: |
It varies by year. Early ones have a weld but installed.
I expect it’s related to when the later steering locks were introduced - so maybe ‘62ish if I had to guess. |
70bus Samba Member
Posted: Fri Mar 01, 2024 10:44 am Post subject: Re: Bolting the Steering column Bracket and Speedometer |
Thanks Everett and mdege - I don't have a steering lock, but I also do not have a captive nut! I'll look at it further; apparently it either broke off cleanly or someone cut it.
Yes, the washer is too small, just test fitting; they should be large and dished IIRC.
Also curious if that angle looks right, or if the bracket is bent too far at column. Or column holder is just up too high...
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Mar 01, 2024 2:02 pm Post subject: Re: Bolting the Steering column Bracket and Speedometer |
Let's see a shot of how well your parcel tray fits up in the notch of the steering pod. Do you have a thin lip of fat lip tray there? |
70bus Samba Member
Posted: Fri Mar 01, 2024 9:24 pm Post subject: Re: Bolting the Steering column Bracket and Speedometer |
Fat lip. Not the tray from the truck but should be identical. Pod had to be shoved up a bit to get it in, and seems something is tweaked a bit from left to right (right side was about 3/4” lower). Hope thats the tray and not the truck!
Anyways, bit of a gap.
70 Neunsitzer
65 Pritschenwagen
-Robert Williams |
