teamasr Samba Member
Joined: August 04, 2009 Posts: 159 Location: SF Bay Area
Posted: Fri Jan 01, 2016 11:14 pm Post subject: Carb/fuel tuning Bay Area? |
Anyone local in Nor Calif who has a snail sync tool to help tune carbs?
My pressure is low, using a carter electric pump, showing around 1psi. No change when turning the adjustment bolt on the Holley regulator, so will replace it, but also getting some pops from one of the carbs which may have gotten out of sync during install of new motor.
Let me know if you can help. |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Fri Jan 01, 2016 11:52 pm Post subject: Re: Carb/fuel tuning Bay Area? |
Where are you, and what carbs? I'm not a huge expert, but may be able to help, or at least have a look.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Posted: Sat Jan 02, 2016 8:28 am Post subject: Re: Carb/fuel tuning Bay Area? |
That would be great, I'm in Dublin. |
cjsuner Samba Member
Joined: January 04, 2013 Posts: 476 Location: Bay area CA
Posted: Sat Jan 02, 2016 1:09 pm Post subject: Re: Carb/fuel tuning Bay Area? |
Ya, I'm the same as Stan, Im no expert, but i do have Weber 40's that run smoothly, and i tuned them myself, so i may be able to help as well. Im up in Pleasant Hill.
Maybe all 3 of us could meet _________________ 71' Super Convertible (Orange)
74 Super Beetle (Red) |
74 Thing Samba Member
Posted: Sun Jan 03, 2016 3:25 pm Post subject: Re: Carb/fuel tuning Bay Area? |
Is NAG still around? https://www.facebook.com/NAGVW/
They used to have a meeting the second Friday of the month in Pleasanton at the In and Out Burger. |
Posted: Sun Jan 03, 2016 4:18 pm Post subject: Re: Carb/fuel tuning Bay Area? |
Dublin is a bit far to swing by without planning, but maybe we can plan a small meet.
1psi won't do it, you need closer to 3psi. I have Carter pumps on Beetle with 40IDFs with a Holley regulator, and on Fastback with ICTs without a regulator. It should work fine without a regulator, maybe your fuel line or sock in gas tank are clogged?
Jansen Enterprise
My 1835cc build
Posted: Mon Jan 04, 2016 9:29 am Post subject: Re: Carb/fuel tuning Bay Area? |
I am also running webers.
I have new Holley FPR and will install this week to see if I can get a better read on pressure. Given the rain this week, I'll coordinate a time to meet the following week. |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Tue Jan 05, 2016 11:42 pm Post subject: Re: Carb/fuel tuning Bay Area? |
im in pittsburg, keep me in the loop as to when you all gtg, i can help.
and yes NAG is still around, they meet at the In & Out in Pleasonton every 2cd friday of the month. _________________ 67 bug x3
67 ghia
64 bug |
Posted: Wed Jan 06, 2016 8:12 am Post subject: Re: Carb/fuel tuning Bay Area? |
Hey Jason, is BLTN meet still active, do you go to it?
Jansen Enterprise
My 1835cc build
Posted: Wed Jan 06, 2016 8:52 am Post subject: Re: Carb/fuel tuning Bay Area? |
stan_tichomirov wrote: |
Stan |
BLTN is still sorta active. I haven't gone to the meets regularly in years due to my work. usually 3-10 guys still show up sometimes. It is certainly not what it used to be however. _________________ 67 bug x3
67 ghia
64 bug |
Posted: Wed Jan 06, 2016 10:40 am Post subject: Re: Carb/fuel tuning Bay Area? |
I wouldn't mind meeting up sometimes. I remember your bus from BLTN meets. I haven't gone since 2007, I was out of it for a while.
Jansen Enterprise
My 1835cc build
Posted: Wed Jan 06, 2016 10:17 pm Post subject: Re: Carb/fuel tuning Bay Area? |
Stan |
ya the old shitbox!! PM sent _________________ 67 bug x3
67 ghia
64 bug |
Posted: Tue Jan 26, 2016 6:42 pm Post subject: Re: Carb/fuel tuning Bay Area - Solved - but Low Pressure |
Solved the carb problem, now a different issue.
Carbs 3 and 4 had no response to accelerator using snail sync. Took the idle jets out, cleaned them and reinstalled. That solved the problem. Idle was smooth, air flow to carbs were at 6 on sail sync and both sets of carbs respond to accelerator equally.
After about 3 minutes of idling can hear small pops in the exhaust. Noticed the fuel pressure dropped to zero from 3psi. Took gas cap off to check for pressure in tank, none there.
Using the Cb performance electric pump with holley fuel pressure regulator.
Clogged screen at gas tank? Fuel filter just outside of tank is clean. |
Posted: Tue Jan 26, 2016 8:51 pm Post subject: Re: Carb/fuel tuning Bay Area? |
You can put one of those clear filters in line before your pressure gauge and carbs, if you are not getting fuel you'll see it. Check the sock. I've also run a throttle cable through hardline after the tank to make sure there is no gunk.
Jansen Enterprise
My 1835cc build
