cmayna Samba Member
Joined: August 18, 2014 Posts: 1173 Location: SF Bay area, CA
Posted: Mon Mar 14, 2016 7:36 am Post subject: Hard start relay for Auto w/cruise |
A local member highly suggest I install a hard start relay but I don't think he realized that I have both an automatic and cruise control. What I've read so far indicates that there is not a hard start relay for my application. What if I keep the cruise control in non working order? LOL. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10459 Location: Orbiting San Diego
Posted: Mon Mar 14, 2016 7:55 am Post subject: Re: Hard start relay for Auto w/cruise |
Your van has an extra relay above the main fuse/relay panel. Pull that relay and then you can add a hard start relay.
Look at Bentley page 97.231
Find relay labeled J60
See next to it a dark black box with a number in it
That number is the relay 'location'
Look at page 97.201
That page shows location numbers on the fuse/relay panel
Hopefully the J60 relay is where it says it is. Never use the cruise again.
Make sure the diagram on the relay matches what the circuit diagram shows it should be.
Mark
EDIT: mistakenly wrote 97.261, now changed to 97.231
Last edited by crazyvwvanman on Mon Mar 14, 2016 11:50 am; edited 1 time in total |
cmayna Samba Member
Posted: Mon Mar 14, 2016 8:05 am Post subject: Re: Hard start relay for Auto w/cruise |
So the J60 relay is for Auto cruise? _________________ '90 Westy / automatic.
Craig |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12175 Location: Port Manteau
Posted: Mon Mar 14, 2016 8:24 am Post subject: Re: Hard start relay for Auto w/cruise |
| Why can't you use a starter relay with an auto and cruise? |
Posted: Mon Mar 14, 2016 8:36 am Post subject: Re: Hard start relay for Auto w/cruise |
Because of how the factory cruise setup was implemented by VW in auto trans vans.
Mark |
Posted: Mon Mar 14, 2016 9:54 am Post subject: Re: Hard start relay for Auto w/cruise |
| Hmmm...I'm having a hard time understanding how the starting, cruise and automatic systems interact, or why they'd be wired differently Guess I'll have to spend some time with my Bentley. |
Posted: Mon Mar 14, 2016 11:11 am Post subject: Re: Hard start relay for Auto w/cruise |
I gave the page number to look at and relay number to look for on that page.
Mark
| Zeitgeist 13 wrote: |
Posted: Mon Mar 14, 2016 11:43 am Post subject: Re: Hard start relay for Auto w/cruise |
| My Bentley doesn't have a page 97.261 and there's no J60 relay on 97.201--weird. It's sort of an academic question anyway, but I'm still contemplating a manual to auto swap, so I just wanted to cover the unknowns. I hadn't heard of this issue before. I'll keep looking |
Posted: Mon Mar 14, 2016 11:56 am Post subject: Re: Hard start relay for Auto w/cruise |
Sorry, wrote the wrong page number earlier.
Page 97.231 and look for J60 on it. This is for 90/91 automatic with cruise.
If you have an older manual look on 97.170 and 97.173 for the "auto trans relay" . These are for auto trans cruise wiring versions before 1990. (not labeled G60 on the earlier version diagrams)
Mark |
Posted: Mon Mar 14, 2016 12:11 pm Post subject: Re: Hard start relay for Auto w/cruise |
| Thanks, I just found it. |
Posted: Mon Mar 14, 2016 12:44 pm Post subject: Re: Hard start relay for Auto w/cruise |
In vans with manual transmissions there is a switch mounted on the clutch pedal to tell the cruise control unit that you have pushed in the clutch. Without this the engine rpm could rapidly speed up to redline if you pushed in the clutch while under cruise control operation.
Auto trans has no clutch pedal but you could still shift into neutral or less likely into park while the cruise control was engaged. Again this could result in the engine rpm rapidly speeding up to redline. Instead of adding a separate switch to the auto shiftlever box VW figured out that they could use the existing starter lockout switch that the auto shiftlever box has. This switch only allows the starter to operate when the lever is in park or neutral. So in the auto version of the cruise there is an extra relay that uses this switch to detect when the shift lever is in neutral or park so the cruise control can turn off. This relay takes the place of the clutch pedal switch function that manual trans cruise uses.
I just wish VW had labeled the extra relay something that tells what it does, like "shifter position safety relay" or "neutral/park safety relay".
Next it where it all gets tricky..............
Mark |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15407 Location: Syracuse, NY
Posted: Mon Mar 14, 2016 1:03 pm Post subject: Re: Hard start relay for Auto w/cruise |
SOooooo I'll bypass the key-start wire directly to the starter and skip the lockout in the auto shifter.. really don't pull it into drive THEN hit the key anyways..
and sometimes (say if stalls in traffic) it's nice to just hit the key you know like a standard trans is allowed to do.
still seems it'd been cheaper/easier to have a new parking switch with a second set of pins than a relay and related wiring. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
Terry Kay Banned
Posted: Mon Mar 14, 2016 1:27 pm Post subject: Re: Hard start relay for Auto w/cruise |
You don't need a relay at all.
Run the starter trigger wire to a starter button , run the other side to the feed side of the neutral safety switch.
Direct drive, no hassles figuring out what will work with the cruise, or the automatic set up.
Used this set up for years, It's easy & bullet proof, direct amps & voltage to the solenoid.
The only caveat is you have to make sure it's in park or neutral, which should be a no brainer. _________________ T.K. |
Posted: Mon Mar 14, 2016 2:23 pm Post subject: Re: Hard start relay for Auto w/cruise |
Back to the OP's question, can't you just put a relay back by/on the starter? That's how we used to wire them up on the old Beetles _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17289 Location: Brookeville, MD
Posted: Mon Mar 14, 2016 2:34 pm Post subject: Re: Hard start relay for Auto w/cruise |
No, you can't. Not if you have a factory cruise setup on a van that came with an automatic trans. That is the whole point.
Mark
| Back to the OP's question, can't you just put a relay back by/on the starter? That's how we used to wire them up on the old Beetles |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10293 Location: Mt Lemmon, AZ
Posted: Mon Mar 14, 2016 2:46 pm Post subject: Re: Hard start relay for Auto w/cruise |
| Back to the OP's question, can't you just put a relay back by/on the starter?... |
As noted, the issue here is that the auto w/cruise doesn't play nice with a relay on the starter circuit.
But otherwise you are quite right - Jay's kit is a great convenience for those who cannot or do not know how to add a start relay - but the same thing can be accomplished with an off-the-shelf automotive relay for a couple of bucks. That's how I did mine years ago when there were no kits on offer. |
Posted: Mon Mar 14, 2016 3:16 pm Post subject: Re: Hard start relay for Auto w/cruise |
Yes, many of us have put our own relays into many VWs over the years. Jay's kits are basically the same thing only built to a professional level. I have ton's of new relays and new wire but I still buy Jay's kits because he builds them better than I can myself.
The issue isn't that the added start relay won't start the car. The issue is that the VW auto tranny cruise system has a relay that puts a weak voltage into the starting circuit whenever the key is on and the shift lever is in park or neutral. This voltage is too weak to directly activate the big starter solenoid. But it is strong enough to activate an added start relay and that activates the starter when you don't want the starter! Even if the engine is already running. Even if you just want to sit there with the key on and engine not running.
Mark |
Posted: Mon Mar 14, 2016 3:29 pm Post subject: Re: Hard start relay for Auto w/cruise |
Got it. I became confused during the discussion of the fusebox, and wasn't sure whether the "hot start" relays were installed up front ahead of the lock-out circuit, so I just assumed a bypass might work back near the starter. I've never owned/worked on a Vanagon auto. Very enlightening _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2677 Location: Bay area CA
Posted: Tue Mar 15, 2016 8:06 am Post subject: Re: Hard start relay for Auto w/cruise |
Caveat - I don't have the Bentley in front of me:
One of the main points of an extra start relay is to hugely reduce the current that flows through the ignition switch. I'd have thought it possible to add a relay up front just to accomplish this, even if it doesn't provide the added benefit of bypassing most of the original solenoid wiring. _________________ Jim Crowther
Vespa GTS 300 |
