How to install an inlet (i'd say outlet) into a camper
vwuguy
Location: southwestern ontario, on and netherlands and bc
vwuguy is offline
PostPosted: Thu Apr 21, 2016 12:21 pm    Post subject: How to install an inlet (i'd say outlet) into a camper Reply with quote
watch any comments or suggestions are welcome
Smile please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Thu Apr 21, 2016 12:27 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
Robert in Memphis
Engine rebuild thread
Tom Powell
Tom Powell is offline
PostPosted: Thu Apr 21, 2016 1:19 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
Comments:
You forgot this.
Perhaps this will work..
And what about this?
or this?
Aloha
tp
danfromsyr
danfromsyr is offline
PostPosted: Thu Apr 21, 2016 3:30 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
I use one of these for our thru wall connection
Abscate wrote:
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Apr 21, 2016 4:48 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
scrivyscriv wrote:
Applause
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Peabody
Peabody is offline
PostPosted: Thu Apr 21, 2016 4:53 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
Just like the original, but you may have to cut a bigger hole and drill more screw holes.
Hey, you asked for opinions. Fine if you want to do it to your own bus but don't sell that shit to people telling them it's just like the original. Some people don't know better and they may not know your joking.
'71 Transporter "June" (traded a nissan hardbody + some $) (daily)
'76 Westy "Sandy" (traded an ak-47) (on hold)
'77 Westy (parts)
'74 Westy (parts)
busdaddy
busdaddy is offline
PostPosted: Thu Apr 21, 2016 6:03 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
Are you sure he's joking?
Слава Україні!
bsairhead
bsairhead is offline
PostPosted: Thu Apr 21, 2016 6:14 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
Your installation is at best OK. The cut in box is not designed to be sandwiched between its ears and structure. A handy box or masonry box would be a better choice. Your box does have a clamp so the cable is secured. Solid wire, NMB or romex should not be used were subjected to vibration. A fuse or breaker or ground fault interrupter is not a bad idea but should be part of the incoming service.
Tom Powell
PostPosted: Thu Apr 21, 2016 6:57 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
bsairhead wrote:
... Your box does have a clamp so the cable is secured. ...
Looking at 3:36 in the video I don't see a clamp. Correct me if I'm wrong.
Aloha
tp
bsairhead
PostPosted: Fri Apr 22, 2016 4:48 am    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
It shows the clamp screws at the beginning but not at 3:36 so you are correct.
Peabody
Peabody is offline
PostPosted: Fri Apr 22, 2016 5:01 am    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
This is exactly what I'm talking about! Laughing
I was joking about him joking and you didn't know I was joking. Cool
I hope you were just feeding my fire BD Pray
'77 Westy (parts)
'74 Westy (parts)
vwwestyman
vwwestyman is offline
PostPosted: Fri Apr 22, 2016 5:25 am    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
"Uh, you gotta push it in more... Ok, turn it... Ok push it in more... There we go!"
Dave Cook
1973 Wild Westerner
My Thing
busdaddy
busdaddy is offline
PostPosted: Fri Apr 22, 2016 8:06 am    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
Wink Razz
Слава Україні!
Tcash
Tcash is offline
PostPosted: Fri Apr 22, 2016 12:20 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
Do you have a good recommendation?
I found it odd that Westfalia used Romex for their conversions. What would be your recommendation?
Would it be a good idea to use a GFI (ground fault interrupter) duplex plug in receptacle for the first plug in after the supply?
Thank you
Tcash
Tom Powell
PostPosted: Fri Apr 22, 2016 12:41 pm    Post subject: Re: How to install an inlet (i'd say outlet) into a camper Reply with quote
Tcash wrote:
... A fuse or breaker or ground fault interrupter is not a bad idea but should be part of the incoming service.
Thank you
Tcash
In my opinion:
Fuses protect wiring. GFCI's protect people. There may be one or both in the wiring coming to the camper, or there may not.
My '69 camper has an OG fuse box next to the 110V inlet/outlet. I would do any wiring hack the same way. If there is a fuse or circuit breaker in the incoming 110V supply it may be of a higher amperage than what I would want for protection inside my camper. Fuses are cheap.
Using a GFCI plug in receptacle for the first plug after the supply may, or may not, be overkill, but it is a good idea. I'd rather protect myself than depend on someone else.
Aloha
tp
