NewTechnicIan Samba Member
Joined: May 28, 2013 Posts: 367 Location: Burlington, VT
Posted: Sun May 01, 2016 8:02 am Post subject: 1679 First Startup Issues |
Hi all, been reading about the some similar cases but I figure I should put mine out there. I'm rebuilding my old dp 1600 case and upping it to 1679. You can check my engine build thread in my signature for a lot of details there, but I got it all put together for a first start last night and it was having trouble turning over
Electrical:, I think we're in good shape. Fresh battery (495 Cold Cranking Amps), fresh starter that was bench tested at advance auto ahead of time and looked great. I looked at the starter bushing ahead of installing the starter and it didn't look pounded out into an oval or anything so I don't THINK it's the starter getting a bad crank on the flywheel. Oh, also I'm just using an alligator clip from the starter to the coil rather than a thicker gauge wire and a spade connection if that is a factor for people.
Bearings: When I put the case together, I was SUPER CAREFUL to make sure the bearings were well seated, since I pinched a bearing during mockup earlier in the year. When I plastigaged my mains and cam bearings, they all came back as the low side of spec but within spec (Main bearings .002", cam bearings .002-.0025").
Assembly: When I put the case together, the crank spun smoothly, although with a little effort. It was easy with the pulley or flywheel but just turning the nose by hand took a little effort.
Then I put the whole thing together. Obviously it got a bit tighter when I put the cylinders on, and I need a wrench on the pulley to spin it now. It takes about 20 ft-lbs without the spark plugs to rotate the assembly and it takes up to 35 ft-lbs when building pressure with the plugs in.
I was reading some other articles that also made it sound like the engine should be loose enough that rotating the alternator pulley when it's adjusted correctly should rotate the engine. Is this a good measure? If so, it doesn't work for me.
I spun it up last night to see if I could get it going, and I got some sputtering but it didn't seem like it was spinning everything fast enough to really get going. The plugs were pretty dry even after trying to get it going for a while.
This being my first rebuild, maybe I missed something or maybe this is normal. Advice from all you fine folks would be great!
So do some engines on their first start just need to get going so they can seat everything and loosen up or is there more to worry about here?
Should I just hook up a big battery or a hard start relay to the starter to get it over that hump?
Thanks!
Ian _________________ My 73 Standard build - It's painted! It drives under its own power! Time to get it wired and upholstered!
My 1679 Engine build. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11225 Location: Oregon
Posted: Sun May 01, 2016 8:39 am Post subject: Re: 1679 First Startup Issues |
Follow this word for word to get your engine started.
http://www.speedyjim.net/htm/eng_strt.htm
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Sun May 01, 2016 9:16 am Post subject: Re: 1679 First Startup Issues |
As long as you checked all the clearances, you should be fine. It'll loosen up after start-up. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Sun May 01, 2016 9:20 am Post subject: Re: 1679 First Startup Issues |
what did you do to the pistons&cylinders?
allso if it's spudering you may need to addvance the timing a tad. you should always spin the engine with sparking bolts out befor trying to start it the first time to get good oil pressure everywhere. and remember not all parts are pressure fed so asembly oil/lube is very importaint. be sure carb is good.dont wory about dry plugs. |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Sun May 01, 2016 9:44 am Post subject: Re: 1679 First Startup Issues |
If plugs are dry you obviously aren't getting enough fuel. Mechanical pump? Nice thing about electrical pumps is they'll deliver fuel without having to spin the engine. Spray some starting fluid in the carb(s). May have to tweak the distributor orientation. Also, check the plug wires for being in correct order, I crossed 1/2 wires last week -- still make those mistakes sometimes.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
toomanytoys Samba Member
Posted: Tue May 03, 2016 10:42 am Post subject: Re: 1679 First Startup Issues |
Whats your endplay set at? |
Posted: Tue May 03, 2016 7:43 pm Post subject: Re: 1679 First Startup Issues |
Holy cow, she started!!!!
In order to test compression, I ganged my car's battery and the new battery for the bug together to give the starter some more juice and I put some WD 40 in the cylinders to make sure they were travelling on some lubricant. That all started rotating so well as I was testing compression that I figured I should try starting her up again, just for grins.
There were some hiccups, like I accidentally had the fuel pump hoses reversed the first time it started so it only ran for 30 seconds or so, but once I got that figured out, she started up and ran!! With just the header and no muffler it sounded like a dirtbike
Unfortunately I had to hold the throttle way open to keep her running which I was worried by, and I saw the headers were getting really hot and I could even see some orange down the pipe on my header. This is a bugpack hideaway exhaust, btw, but I left the muffler off for the test run, so it was just the header. Anyway, I let up on it around 7 minutes in and it died, and now I'm not sure what to do next.
So what do I do now? I always heard to run it for 20 minutes, change the oil and adjust the valves and you were golden. I'm pretty sure it was my carb throwing me off with the mixture screws so I'd like to get those squared away and run it in correctly. Is it best to run it with the oil it has now or should I change the oil before that? Any tips for adjusting the carb or anything else I should know at this point? _________________ My 73 Standard build - It's painted! It drives under its own power! Time to get it wired and upholstered!
Posted: Wed May 04, 2016 5:44 pm Post subject: Re: 1679 First Startup Issues |
could be leen, could be vac leek ,could be ignition tyming. could be you need to find out. |
Posted: Thu May 05, 2016 2:26 pm Post subject: Re: 1679 First Startup Issues |
Mark, I'll definitely find out, I just want to make sure while I'm finding it all out that I'm being safe on the engine.
Since it's run for about 7 minutes at this point should I change the oil and filter or do I just keep the oil where it is until I have the thing tuned well enough for a fast-idle run in?
I want to make sure that during this fragile stage in its life my delicate lobes and lifters and cylinders, etc are well cared for
Thanks! _________________ My 73 Standard build - It's painted! It drives under its own power! Time to get it wired and upholstered!
