loveevan Samba Member
Joined: September 19, 2014 Posts: 27 Location: San Diego
Posted: Fri Aug 26, 2022 1:32 am Post subject: Bucking L-Jet only on hard acceleration or heavy load |
Hello,
Yes, there are many posts about bucking... ...in this case though, it ONLY happens on hard acceleration or heavy load.
It's a 1981 Vanagon Westfalia, and the bucking is ALWAYS there under ONLY those conditions. Warm or cold doesn't matter. It doesn't even matter if it's in gear driving.
I can just step hard on the accelerator (or push all the way on the throttle body if I'm back by the engine) and the engine, rather than accelerating, will go into a very predictable and very constant wah wah wah wah, as in a second of acceleration followed by a second of deceleration...
...it is so constant that the throttle can be held wide open and the van will never go above maybe 2500 rpm, then down, then up to 2500, then down, etc etc with the throttle held at full open.
When driving it'll do this in every gear if I floor it, or if I'm going up hill or have strong wind resistance... ...but, it also does it in neutral if I floor it, so the issue is in the engine bay somewhere.
meanwhile, if I baby it, ease into acceleration, I can ease right on up to 4000 rpm or more without any issue...
... so it's just a hard acceleration issue (and too much load on hills or against wind)
any thoughts?
thanks,
evan
 _________________ all is well
love-real-estate.com san diego |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 2026 Location: Pittsburgh PA (ish)
jlrftype7 Samba Member
Posted: Fri Aug 26, 2022 5:53 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
I would want to know Fuel Pressure with the Fuel Pressure Regulator vacuum hose disconnected, regular Fuel Pressure with it connected, and a Fuel Delivery Volume Test after that.
Also, make sure the Air Flap inside your Air Flow meter isn't bent or warped from a Back Fire or just age. If the flap sticks at the portion of where you'd be pulling in enough air for a heavy load or acceleration, but can't advance further in movement, you can get some very weird running behavior with L-Jet.
The Air Flow Meter check is super easy, no special tools needed. Just pop it out of the Engine Comp and use your fingers or a screwdriver to push it from the normal closed position to see if you get full travel out of it.
You can often easily see rubbing marks inside the housing where the flap will bind or just stop if warped. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
steve244 Samba Member
Posted: Fri Aug 26, 2022 12:18 pm Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
| steve244 wrote: |
Isn't there a full throttle switch that enriches the fuel mixture? This might not be working. I'm not sure the effect of this not working.
The ignition system might be affected by RPM or vacuum. Don't think he's in high RPM but it might be a vacuum issue. |
There is the WOT switch, but what's interesting about some of their listed details is that they can sneak up to 4000RPM if done at a slower pace, which would seem to suggest Secondary Ignition is not totally to blame or that the points can't keep up with the increased RPMs or Coil output.
Would be easy to see on a Scope if the ignition is just breaking down on that snap load too.
But anyway, checking and testing the WOT switch is yet another good check point to rule out....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Howesight Samba Member
Joined: July 02, 2008 Posts: 3429 Location: Vancouver, B.C.
Posted: Fri Aug 26, 2022 3:45 pm Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
Here are my thoughts, based on the symptoms described:
1. The hose between the Air Flow Meter and the throttle body may be cracked or not fastened well. When you rapidly open the throttle or place a sudden load on the engine, the engine moves slightly (it's rubber-mounted) and this enables a crack in the hose just mentioned to open up to the point a large vacuum leak is caused. To properly inspect this hose, you need to remove it and flex it, looking for cracks.
2. Your deceleration valve may be partly disconnected or otherwise not functioning correctly. The Bentley manual describes the checks and tests.
3. Your full throttle switch may be incorrectly adjusted or malfunctioning.
4. Your distributor rotor and/or cap may need replacing. Some folks incorrectly install the "rev-limiter" VW rotor which fouls things up and does not belong on a late-model Type 4 engine. It looks like the one in this link:
https://www.cip1.ca/acc-c10-5830/
5. Since your Vanagon has to be a California-equipped vehicle, it also has the primitive early EGR system. If the EGR system is not functioning correctly, it can cause problems, but not usually at the same rpm each time, so this is simply a check to eliminate a possible cause.
6. Here is a link to the AFC trouble shooting manual:
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf
7. Here is a link to a thread on Itinerant Air Cooled which deals with the AFC bucking phenomenon more fully than I have above:
http://www.itinerant-air-cooled.com/viewtopic.php?...p;start=15 _________________ '86 Syncro Westy SVX |
Posted: Fri Aug 26, 2022 6:19 pm Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
Thank you all for responding,
I will check all those things again.
The WOT switch itself works, but I was unable to follow the Bentley suggestion of testing it at terminal 18 because the California model doesn't have anything at terminal 18... ...and the switch itself goes through some of the stuff at the left of the engine bay before doing whatever it should do at the ECU.
Does anyone know how to test the WOT circuit on a California air cooled vanagon?
The switch itself is good (it's just and on off switch, easy to test by itself)... ...but I do wonder sometimes if the circuit is not giving extra gas as it should.
The air meter is "rebuilt", though apparently that doesn't mean it has a new wiper board, so there's that.
It was good enough to pass emissions and to drive highway speed with a light foot.
I have sprayed all over for vacuum leaks, though not exactly at the moment of the problem.
I did remove and test the bypass thing, and it did what it was supposed to do.
I had a gage on the gas pressure and it was just as it should be... ...though i didn't watch right at the moment of the issue. It gives plenty of gas to go 4000 rpms on the highway though, and the wah wah wah wah thing doesn't even go 2500 rpms at most while going up and down forever until i let go of the accelerator.
I bought the van with this issue (and other issues I've been able to fix) so I don't know anything about how slowly or quickly the issue came on.
It is serious though, while driving it bucks hard in every gear if I floor it and it does not go away by staying in it, only by backing off, then I can drive normally as long as I don't ever ask it for any real acceleration.
The engine itself is totally rebuilt just 2000 miles ago and very strong other than not being supported by the air, fuel, or spark it needs in those situations.
Please let me know if you know how to test the WOT circuit on a California vanagon, or anything else you can think of.
Thanks,
Evan _________________ all is well
Posted: Sat Aug 27, 2022 4:56 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
I knew your post sounded familiar once you mentioned you have the complications of the Califonia system enrichment setup.!!!
Read this thread, sounds exactly like your issue .There was a parallel thread on the same issue where one poster had to resolve Altn wiring issues as well since the signal wire to the Speed Relay of their Califonia system wasn’t seeing the voltage drop correctly , and they also found their cat was clogging with too much back pressure.
The exhaust back pressure check should also be done for this OP’s system since it could be adding to their poor hard acceleration attempts, or be the actual main cause.
https://www.thesamba.com/vw/forum/viewtopic.php?t=659727&highlight=california+wot+switch _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
RawUmber Samba Member
Posted: Sat Aug 27, 2022 6:20 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
As I understand it, the 'OXS relay' prevents the WOT signal from affecting the ECU while the engine is running <3000 RPM. When running >3000 RPM, the WOT signal is allowed to affect the ECU. And when it does, ECU exits its closed loop, O2 sensor regulated fuel injection function, typically increasing enrichment.
For troubleshooting, you should be able to disconnect the OXS relay and see if the problem persists. WOT signal cannot affect ECU while the OXS relay is disconnected, but the AFC system should perform normally otherwise.
To test the OXS relay in situ, connect one volt meter probe to ground, the other to OXS relay terminal 8. Meter reading should toggle when crossing the ~3000 RPM threshold.
Posted: Sat Aug 27, 2022 11:09 pm Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
I tested the OXS the way you said with the terminal 8 and ground...
... I went over 3,600 rpm, and still nothing, no signal from terminal 8 of the OXS
... which would mean no power to the WOT switch, and thus no signal to ECU to add time to the fuel injection and get more gas
So, i guess that could be it...
... could I just jump this thing and power up the WOT switch and see? _________________ all is well
oceanair Samba Member
Joined: June 09, 2013 Posts: 724 Location: Victoria, BC
Posted: Sun Aug 28, 2022 7:57 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
Definately refresh the ignition system -- all tune up items, so why not?
New Coil, wires, cap, rotor and if you have points, new -- but go electronic and be done with it... Under loads is when you'll feel any weakness in the system. Be sure to buy QUALITY parts! not cheap or non-name brand stuff. Eliminate this system and have it refreshed... _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
Posted: Mon Aug 29, 2022 12:26 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
| steve244 wrote: |
After mulling it over, I don't think the symptoms you have resulted from the WOT switch not working.
The extra fuel would be to cool the incoming mix to lessen knocking.
Switch might be bad but there is another or multiple causes.
Sunday morning armchair mechanic. |
Ya, after thinking about it, if the California WOT only kicks in after about 3k rpm, then my problem must be from something else because it kicks in immediately on hard acceleration at any rpm
Maybe I should have a good look at that catalytic converter, even though it's only 6 months old... ...the PO did way overfill the oil
hmmmmm _________________ all is well
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 647 Location: Lodi, CA
Posted: Mon Aug 29, 2022 10:22 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
I had this issue because my points were wide open. _________________ 83 Air-cooled 2.0 Tin Top |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 853 Location: Tucson, AZ
Posted: Mon Aug 29, 2022 11:09 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
If you replace your points, don't forget to wipe the contact surfaces clean. I used to just open them against the spring tension, insert my button down work shirt between the contacts, let the points close and rub up and down a few times.
Cheers,
BK _________________ 1991 tin top GL
Some BMWs. |
Posted: Mon Aug 29, 2022 5:45 pm Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
The California version is electronic ignition, so no points, but it there are some shavings in there from the center piece being touched by the plastic pieces at both sides.
Still, the wah wah wah comes immediately and at any rpm, so the distributor isn't even doing high rpms when the issue happens.
It's basically dependent only on throttle position, which is to say sudden massive air flow...
... so if i gun it at 1000 rpm, it does it, if i gun it at higher rpm it does it...
... it basically goes into A-fib if it's asked for acceleration or if, while driving, it comes to a hill or something that would require more power to stay at the same drive speed
Does anyone know exactly what should happen in all areas when the throttle is suddenly wide open?
My friend's vanagon just accelerates at the speed it is able to when suddenly opened up, no bogging or anything, not impressive acceleration really, but it does it without fighting back.
So it is not a high rpm thing because it actually bogs so bad it never goes to high rpm...
...plus, if i just ease into it I can go high rpms no problem...
... so it is just the engine not doing the right thing when suddenly given a wide open throttle...
... I would think it would need more gas, right? to even out the ratio... ... and if that is correct (seems logical) then why would it not be getting more gas when it gets more air?
Is this a California version problem, or is it just this particular California vanagon?
Only other thing I can think of is maybe a clogged cat, but wouldn't that show up at high rpm too? Any reason that type of issue would only be at low rpm with a suddenly wide open throttle?
I am open to any and all suggestions and ideas,
thanks.
ohhorob Samba Member
Joined: September 26, 2013 Posts: 217 Location: Santa Cruz
Posted: Mon Aug 29, 2022 10:37 pm Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
| loveevan wrote: |
I didn't see any mention of timing being checked up-thread.
It could be running on the lean side of good.. when you open the throttle quickly the combination of lean mix and off-spec timing gives it a stutter until lambda feedback compensates.
Slow change in throttle isn't getting ahead of combustion so it's not stuttering.
Why lean? Might be an unmetered air leak that is worse under vacuum? Worn throttle body? If you've tinkered with the AFM spring settings the ECU is under-measuring the actual metered air?
Try a tiny change in all-in advance (10 cent timing method) and see if that helps.
Use a smoke tester on the air intake to find and fix leaks. _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet |
Posted: Tue Aug 30, 2022 12:17 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
| ohhorob wrote: |
| loveevan wrote: |
Use a smoke tester on the air intake to find and fix leaks. |
Interesting, I thought I knew a lot about cars and engines until I met this vanagon...
...now I'm full of questions...
...What is "lambda feedback" and how and when would that normally compensate?
...Also, on this engine, which way do I turn the distributor to advance it? I did check timing with a Harbor Freight adjustable timing gun (set to zero) and it appeared that the timing was jumping between 6 and 12 to the right side of the 0... ...I think the crank pully turns clockwise so that should be 6 to 12 After TDC... ...which is more than the 5 ATDC that it should be, and why was it not stable?
I also noticed that the idle, with idle stabilizer plugs hooked to each other, was very low, as in about 450 rpms... ...so i backed the idle screw way out until it was near 950, but then it started staying higher than 950 after accelerations, so i screwed it back in some to get it to stay around 950 when it came down from accelerations above that...
...the problem still persisted after this idle adjustment
Please let me know about the lambda thing and thoughts on the timing issues.
thanks,
Wellington Samba Member
Joined: September 21, 2004 Posts: 2024 Location: Montreal
Posted: Tue Aug 30, 2022 2:33 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
| Have you changed your fuel filter, checked flow and pressure? |
Posted: Tue Aug 30, 2022 7:22 am Post subject: Re: Bucking L-Jet only on hard acceleration or heavy load |
| loveevan wrote: |
ooo oooo pick me! pick me! can I answer?!!!
I googled it just to be sure, but it's feedback from the O2 sensor. Some frat-boy must've coined the term.
EFI uses this value from the exhaust to modify the fuel mix appropriately. It's called closed-loop as data (lambda) from the output (exhaust) is used to modify the input (fuel/air mix). GIGO applies when the sensor goes wonky.
But, I thought (maybe this is later EFI systems) when this happened, an out of bounds error is thrown (check engine light comes on, or Check O2 sensor) and it goes to an open-loop map for figuring out fuel mix which is good enough to run but not great for emissions.
Non-CA L-jet doesn't have the O2 sensor and relies just on open-loop logic.
No bucking in back of my van (yet). _________________ 82 AC vanagon approx 200K miles (3K are mine).
DD is a 2015 Leaf
Road Trip to Hell (FL 2023)
The Vanagon's drivetrain and chassis restomod thread. Best sung to the tune of I Did It My Way... |
