tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Wed Apr 25, 2018 5:55 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Damn son, for 18 years old you have some skills. I love it when people dive right in and discover it's not all that hard if you have patience and an eye for detail and don't mind a few frustrations. Of course, it helps tremendously to have the correct tools at hand. Anyway, good job and congrats on the bus, I got my first one at 16; 20 years ago! _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Ericlottaallthat Samba Member
Joined: February 07, 2016 Posts: 138 Location: McCune, Kansas
Posted: Thu Apr 26, 2018 9:32 am Post subject: Re: 1977 Sportsmobile/Westfalia Build |
I do kinda like that wild westerner color combo. Looks pretty awesome.
Definitely a contender for the color of the bus.
Just to clear it up I did cut out the windshield piece before I welded in the new one. Just forgot to take any pictures of it. Thanks for the tips though! |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Apr 26, 2018 9:36 am Post subject: Re: 1977 Sportsmobile/Westfalia Build |
what welder/setup are you using? looking great so far! |
Posted: Thu Apr 26, 2018 11:32 am Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Using a Millermatic 141 with .023 wire and argon/CO2 mix.
Just tested the fridge and seems to be working.
Anybody know if they came stock with them?
It is a norcold DE-251B |
Posted: Thu Apr 26, 2018 6:50 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Getting some more welded
Split the case on the engine, Measured the crankshaft and it measured like new (well within spec) Pistons and cylinders also looked pretty good. Couldn't feel any lip on them. Need to measure but probably just a hone and new rings for them.
Camshaft could have looked better? What do you guys think? A couple of the lifters had a little bit of pitting on them so probably just going to get a new cam and lifters.
I had the fridge turned all the way down and it was definitely getting cold enough.
Posted: Tue May 01, 2018 7:57 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Pretty much done welding those pieces.
This valve seat looks worn out right?
And has anyone had experience with these heads from bus depot?
Trying not to break the bank here.
http://www.busdepot.com/022101061lx |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu May 24, 2018 8:07 am Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Haven't updated in a while so there is a decent amount of stuff.
Almost done with the welding part of the body work.
Repairing the front end and planning on making a bumper like below to get the tire off of the front end.
Cleaning out the transaxle and replacing the plastic shift ball.
Cleaned, sandblasted and painted the beam along with new Lemforder ball joints.
SGKent Samba Member
Posted: Thu May 24, 2018 8:16 am Post subject: Re: 1977 Sportsmobile/Westfalia Build |
might be an optical illusion but that valve looks like it was stretching at the hottest point. Might have been running lean for an air cooled engine. If you don't replace the valve seats or heads at least stake them to help hold them in. Use a blunt punch and not a pointed one to reduce stress that might start a crack.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu May 24, 2018 8:17 am Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Ericlottaallthat wrote: |
I like this! I would kind of like to get the spare out of the Westy cabinet at some point, but don't want to do the traditional front nose mount. Can't decide if I'd prefer something on front like this, or on some kind of swing away rear carrier. But I have a lot of other things to do with the Bus before I get to that project. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Thu May 24, 2018 8:31 am Post subject: Re: 1977 Sportsmobile/Westfalia Build |
I ordered AMC Heads as i have read that they don't have the best hardware but they should last me a long time. |
Posted: Tue May 29, 2018 5:36 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Wet sanded the nosecone down on a piece of glass to get rid of the groove.
Stripping the paint, I have a little bit of welding to do underneath and then I’m going to POR15 the underside and the floor.
Posted: Sat Jun 02, 2018 6:38 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Had a friend help me bend up the bumper today.
Still have to add a bar and the spare tire mount
Posted: Sun Jun 03, 2018 6:20 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Finished the bumper.
Posted: Fri Jun 08, 2018 7:07 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Had the bus sandblasted today.
Posted: Tue Jun 12, 2018 7:30 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Painted underneath the bus
Also painted the wheels. Hopefully will get the General grabbers mounted up sometime this week. Anyone know how long I should let the clear coat cure before I get tires mounted?
Posted: Sun Jul 01, 2018 3:29 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Got all new brake lines and brake parts put on. Also all new suspension and steering bushings and bearings all around. Along with the new tires mounted.
Tcash Samba Member
Posted: Sun Jul 01, 2018 7:21 pm Post subject: Re: 1977 Sportsmobile/Westfalia Build |
Looking good!
Tcash |
Posted: Wed Aug 01, 2018 8:48 am Post subject: Re: 1977 Sportsmobile/Westfalia Build |
I got the interior and engine compartment painted.
I also got the outside of the bus in primer so the next step is to block sand/flat the primer and then I will be on to painting.
