IoWesty Samba Member
Posted: Tue Oct 10, 2017 9:14 am Post subject: RMW Aluminum Expansion Tank |
I'm thinking about upgrading to the aluminum expansion tank offered by Rocky Mountain Westy. Can I get any feed back on how easy it is to install, coolant loss, etc?
How about some owners' observations. Would you do it again if given the opportunity? Thanks. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32646 Location: Reading Pennsylvania
Posted: Tue Oct 10, 2017 9:42 am Post subject: Re: RMW Aluminum Expansion Tank |
The downside of this tank is that you give up the ability to monitor coolant level at a glance
The translucent tank will be gone.
But so will the worries of and the reality of cracked tanks, failed caps (even new ones) and leaky or popping out level senders.
I did it and I'm not going back!
Easy to install, I may have lost a few teaspoons of coolant.
Not cheap but you do it once and done.
I documented my tank swap but can't look for the link right now.
EDIT:
I can't find it, however it was super easy,
I clamped off all of the hoses to the tank.
Suctioned out all of the coolant in the old bottle,
removed the old bottle.
Bolted in the new tank,
hooked up the hoses,
filled the new tank,
released clamped hoses,
modified the level sensor wire and done!
I lost very little coolant.
Ghia
Vanagon
Beetle
Posted: Tue Oct 10, 2017 10:14 am Post subject: Re: RMW Aluminum Expansion Tank |
Thanks, Dave. I was looking for a thread on doing the tank swap, but couldn't find it. |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Tue Oct 10, 2017 10:27 am Post subject: Re: RMW Aluminum Expansion Tank |
The swap is super easy. I no longer have the tank, as I did an engine swap, but I really liked the product while I had it. _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
thatbaldwinlife Samba Member
Joined: August 01, 2011 Posts: 777 Location: Out exploring
Posted: Tue Oct 10, 2017 10:51 am Post subject: Re: RMW Aluminum Expansion Tank |
I have the tank and the swap is easy. I did have to send the first on back as the plastic level sensor started leaking and a replacement did not fix it. It is now just weeping again so I snugged it down just a little. We will see if it stops. _________________ 1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel |
Westaru Samba Member
Posted: Tue Oct 10, 2017 10:58 am Post subject: Re: RMW Aluminum Expansion Tank |
Really like mine as well.
My level sensor started weeping as well - pulled it out and gave it a few wraps of yellow teflon tape per RMW's instructions and it seems to have solved the issue. They have great customer service! _________________ 1984 'Westaru' Vanagon Westfalia EJ22
@UtahWestfalia on IG |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Tue Oct 10, 2017 11:14 am Post subject: Re: RMW Aluminum Expansion Tank |
I installed one early on when they were using the OEM sensor. It has been trouble free. As to the inability to see the level I do not view that as a problem. The sensor sits higher in the tank than the original and is therefore more sensitive to a low coolant level. The flashing red led in the temp gauge is hard to ignore. RMW also sells a nice mounting bracket if you don't want to make one yourself. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6602 Location: Westfalia, Earth
Posted: Tue Oct 10, 2017 12:03 pm Post subject: Re: RMW Aluminum Expansion Tank |
How much is this thing? _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16510 Location: Brookeville, MD
E1 Samba Member
Posted: Tue Oct 10, 2017 12:17 pm Post subject: Re: RMW Aluminum Expansion Tank |
Not in my database under "friends."
But THANKS! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Tue Oct 10, 2017 12:20 pm Post subject: Re: RMW Aluminum Expansion Tank |
E1 wrote: |
How much is this thing? |
only 10 times more than the plastic one, for the late model, on the same site... Its a steal vs. a bad breakdown or complete disaster. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Tue Oct 10, 2017 3:21 pm Post subject: Re: RMW Aluminum Expansion Tank |
I like mine. Came with the van when I bought it. I have a clear plastic overflow so I can monitor level of antifreeze. |
trip'n Samba Member
Joined: April 27, 2009 Posts: 78 Location: springfield mo
Posted: Tue Oct 10, 2017 6:53 pm Post subject: Re: RMW Aluminum Expansion Tank |
direct replacement.....defiantly glad that i updated.
had been through a cple of the new who knows where they come from plastic tanks.
i have not not had any coolant problems since installed...2/3 years now.
probably just jinxed myself.
plus it looks cool _________________ 1990 vanagon gl/tintop....2nd owner
rocky jennings 2.3 & throttle body
rocky jennings transmission
10c/rmw exhaust
10c oil cooler
tires/wheels/grill..parts..and cookies..
van cafe
2 loons at roy rogers in springfield mo
paul blandford... wrench n skills |
E1 Samba Member
Posted: Tue Oct 10, 2017 7:42 pm Post subject: Re: RMW Aluminum Expansion Tank |
bobbyblack wrote: |
E1 wrote: |
only 10 times more than the plastic one, for the late model, on the same site... Its a steal vs. a bad breakdown or complete disaster. |
Yep, hear that. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
E1 Samba Member
(Sorry, dipstick attack, out of oil) _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman
Having come dang close to loosing an engine because a plastic tank ruptured when the van was idling unwatched for a few minutes in the driveway, the aluminium tank is a great upgrade. I would like to improve the mounting a bit as it is not as well supported as the plastic tank was.
I do like that I can readily buy a 7 psi cap, as I have found that low pressure and ancient cooling systems tend to go well together. I can't help but believe if I had been able to run a 7 psi cap originally I would probably have had far few problems with hose and various plastic piece failing over the decades. In 500K plus miles of driving these things, I have had coolant tanks blow (2), level sensor blow, coolant manifolds blow (3), the ends blow off the plastic coolant pipes (2), hoses split, heaters leak(many), and probably things that I can no longer remember. As noted many of these failures happened more than once. |
E1 Samba Member
Posted: Tue Oct 10, 2017 7:46 pm Post subject: Re: RMW Aluminum Expansion Tank |
That's a lot of blowing.
Feeling luckier now (but only 50K here, so all in time) _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed Oct 11, 2017 4:52 am Post subject: Re: RMW Aluminum Expansion Tank |
It works as advertised. Yet, I wish it had a larger capacity, at least the same as the original tank. I have not measured capacities, just the visual of it.
If your system is all working well it should not make any difference. _________________ This free advice is worth exactly what you paid for it.
