Crankcase Pressure Q.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Fri Oct 13, 2017 6:26 am    Post subject: Crankcase Pressure Q. Reply with quote
There being crankcase pressure in any engine but more so in a stroker and/or a wornout one, is there a practical way to actually measure the pressure to determine what is "okay" versus it being too much? Confused
I'm looking for an actual psi figure besides the obvious puking oil all over the engine! Wink
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Fri Oct 13, 2017 6:50 am    Post subject: Re: Crankcase Pressure Q. Reply with quote
Do a leak down test on rings. If they're good them you're good. Strikers need more breathing....stock breathing won't do it.
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
nsracing
nsracing is offline
PostPosted: Fri Oct 13, 2017 7:22 pm    Post subject: Re: Crankcase Pressure Q. Reply with quote
Why don't you hook up a pressure gauge and see what pressure the oil starts to climb out. Laughing
modok
modok is offline
PostPosted: Fri Oct 13, 2017 7:26 pm    Post subject: Re: Crankcase Pressure Q. Reply with quote
Sure. hook up a map sensor and data log it or use oscilloscope.
You should be able to see the individual pulses.
But, since nobody else ever does that, I don't know what you will find or if it's normal or not. I don't seem to have a problem with it so you can come over and measure mine for comparison Razz
To measure the blow by volume you can use a fixed orifice on the breather and measure the case pressure. That's done on large engines sometimes but rarely on cars. Once again, it would have to be comparative tho. (no specs for it)
modok
modok is offline
PostPosted: Fri Oct 13, 2017 7:50 pm    Post subject: Re: Crankcase Pressure Q. Reply with quote
Far as 'case pressure"....it's not that simple.
There are multiple things at work
-Windage, due to the moving parts creating airflow inside, which will create an oil mist as well as general chaos inside. The air needs to move around in the case to account for the pistons moving, so that's internal air FLOW
-volume change, due to the rod ratio, at half stroke the internal volume is smaller that at TDC/BDC. This creates pulses, and the pulses and can induce harmonic pumping of some form in the breather system at certian RPMS.
-blow by, which I don't have to explain
chrisflstf
chrisflstf is offline
PostPosted: Fri Oct 13, 2017 8:39 pm    Post subject: Re: Crankcase Pressure Q. Reply with quote
You can get a pretty good feel just by putting your hand over the breather cap. Hard to measure with more than a relative feel. Changes with rpm also.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Mon Oct 16, 2017 7:16 am    Post subject: Re: Crankcase Pressure Q. Reply with quote
That's why I asked, "nobody does that"! Laughing
Thought maybe some crazy dumbass like me had attempted it. Maybe using some sort of flow meter might give some idea of the pressure. Also, I do get that the rate will substantially increase at higher rpms. Just wanted to "establish" a measure to compare a stock engine versus a stroker, at idle should show a difference!?! It was the kind of thought that comes up while sipping on a beer or two. Cool
chrisflstf
PostPosted: Mon Oct 16, 2017 9:46 pm    Post subject: Re: Crankcase Pressure Q. Reply with quote
U need to invent something to measure it
pyrOman
Fire Master
pyrOman is offline
PostPosted: Tue Oct 17, 2017 6:11 am    Post subject: Re: Crankcase Pressure Q. Reply with quote
"Wait, hold my beer..." Laughing
66brm
66brm is offline
PostPosted: Tue Oct 17, 2017 8:01 am    Post subject: Re: Crankcase Pressure Q. Reply with quote
Just use one of those carb sync snails..............
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
jason
jason is offline
PostPosted: Tue Oct 17, 2017 7:10 pm    Post subject: Re: Crankcase Pressure Q. Reply with quote
I’d think not much air is from moving parts. As one piston moves in one moves out. Mostly back and forth. 10% leakdown on an 86mm piston is less than 10% of a 94. Do the math. I’d say do a leak down.
chrisflstf
PostPosted: Tue Oct 17, 2017 7:19 pm    Post subject: Re: Crankcase Pressure Q. Reply with quote
It would be nice to know if there is a correlation between poor leakdown numbers and excess crankcase pressure. We can measure 1 but not the other
Maybe a MAF sensor?
slalombuggy
slalombuggy is offline
PostPosted: Wed Oct 18, 2017 9:27 am    Post subject: Re: Crankcase Pressure Q. Reply with quote
Maybe a MAF sensor?
There definitely is a correlation, the more the cylinders leak, the more crank case pressure is created from escaping combustion gasses.
brad
mikedjames
mikedjames is online now
PostPosted: Thu Oct 19, 2017 1:21 pm    Post subject: Re: Crankcase Pressure Q. Reply with quote
And another inverse correlation with the total area of all crank case breathers.
And effects from how the breathers are filtered or connected to the air intake system or to outside air.
Which will be different on every engine except for totally stock.
It is probably a measurement you can make on your own engine when it is newly built and then measure it changing..
But the measurements at the source of the leakage are more repeatable - compression/ leakdown tests can be performed and more easily measured with a single connection to each spark plug hole - and it tells you which cylinder has the problem.
Ancient vehicles and vessels
