KD90815 Samba Member
Joined: February 07, 2016 Posts: 44 Location: Long Beach
Posted: Sat May 26, 2018 9:15 am Post subject: Door storage |
| How does everyone store their doors when not on the car? I got some hooks to hang on garage wall but now I am thinking that's not the best option. I was toying with the idea of building a wood rack with carpeted slots for the doors and maybe an extra slot for the side curtains. Any thoughts or pics would be appreciated. I'm sure I am not the first to do this so I would like to see how others have done it. Thanks. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Sun May 27, 2018 11:40 am Post subject: Re: Door storage |
I have had thoughts on this issue, but nothing I've acted on. I thought a good storage space would be the unused space between the open garage door and the ceiling. A carpeted shelf there would be one solution.
Another idea would be a rack on casters in which the doors would sit vertically, which could be wheeled around the car while the doors are being removed or installed. |
FatBuoy Samba Member
Joined: May 17, 2018 Posts: 19 Location: Grapevine, TX
cma68 Samba Member
Joined: May 05, 2015 Posts: 103 Location: Batavia, IL
Posted: Tue May 13, 2025 3:38 pm Post subject: Re: Door storage |
I’m planning on converting a door storage cart made for a Jeep. I will likely need to change the position of the pin brackets and add pins.
For pins I found stock on Amazon.
uxcell 6mm x 200mm 304 Stainless Steel Solid Round Rod for DIY Craft - 2pcs
I purchased the cart on eBay.
VEVOR 4 Doors Jeep Door Storage Cart for Jeep Wrangler JK JKU JL Gladiator
I’ll post pics when completed. |
Semper_Dad Samba Member
Posted: Wed May 14, 2025 9:33 am Post subject: Re: Door storage |
I put together a rack of sorts with PVC pipe, fittings and some pool noodles.
Everything is friction fit so that it can be broken down and used at events. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2321 Location: Texas
Posted: Fri Dec 12, 2025 9:20 am Post subject: Re: Door storage |
That's pretty sweet! It seems you can make just about anything with PVC pipe & pool noodles these days... _________________ Dave
1966 Bug project
1973 Thing project
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
