Drilling into sloping wall under rear bench - how to do it?
mugford
mugford is offline
PostPosted: Tue May 29, 2018 10:50 am    Post subject: Drilling into sloping wall under rear bench - how to do it? Reply with quote
I want to mount a piece of plywood under the rear bench against the sloping wall in front of the engine bay.
Given its a syncro I suspect that the gas tank is right behind it so how much gap is between it and the sheet metal? Will use Rivnuts in the new holes.
MarkWard
MarkWard is offline
PostPosted: Tue May 29, 2018 10:56 am    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
Others probably can advise you better, but the syncro tank is really right up against the firewall. I would not recommend drilling for even rivnuts with the tank in place. If you can't resist, put a piece of fuel hose on the drill bit to limit the depth the drill can protrude through the sheet metal. Good luck.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue May 29, 2018 11:26 am    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
How about using construction adhesive rather than screws?
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
mugford
mugford is offline
PostPosted: Tue May 29, 2018 11:42 am    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
Adhesive, not a bad idea, because I was planning on using 1" wooden standoffs to clear the bump on the driver's side. I'll probably just glue the standoffs and mount threaded inserts in those instead.
Thanks
dobryan Premium Member
dobryan is offline
PostPosted: Tue May 29, 2018 12:39 pm    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
Look into auto panel adhesive, not home products.
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
vanagonjr
vanagonjr is offline
PostPosted: Tue May 29, 2018 5:07 pm    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
Genius!
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
Zeitgeist 13
PostPosted: Tue May 29, 2018 5:30 pm    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
I regularly use construction adhesive to adhere Mercedes hood pads into place. It works well in a high heat environment, and I think it's just flexible enough to deal with road vibrations.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
Wildthings
Wildthings is offline
PostPosted: Tue May 29, 2018 5:40 pm    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
The polyurethane construction adhesive are really quite good, I have used them for all kinds of projects over the years.
IdahoDoug
IdahoDoug is offline
PostPosted: Tue May 29, 2018 10:20 pm    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
Agree with Wildthings. The mastic and other construction adhesives are crazy strong. I knew of a guy in college who glued shelves to the wall instead of nails (in fact the product may have been Liquid Nails). They were stout. Unfortunately when it came time to take them down, he had to pay for the drywall to be replaced. It would not come off without taking the drywall.
I'le also seen it put between 2X4s and you will not pry them apart. The wood will fail first. So take a look. There are also expanding foam versions that might account for your bump or unevenness of the metal wall.
This has actually been a great thought from you. I have been wanting to add some hooks and small shelving units under there to hold things I always have - axe, place to bungee jumper cables up out of the way, fishing rod brackets, etc. I am thinking of glue-ing all manner of things under their to make my life more simple and organized. I run without the seat panel, so everything's accessible.
mugford
mugford is offline
PostPosted: Mon Jun 11, 2018 5:17 pm    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
Just a big thanks to all who chimed in with suggestions. The gluing and mounting went quite well and having it removable via threaded inserts makes all the difference.
Zeitgeist 13
PostPosted: Tue Jun 12, 2018 2:54 pm    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
Nice work. I like the use of threaded inserts.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
erste
erste is offline
PostPosted: Tue Jun 12, 2018 5:42 pm    Post subject: Re: Drilling into sloping wall under rear bench - how to do it? Reply with quote
x2
mugford, What are you mounting to the plywood? ECU?
