Timwhy Samba Member
fxr Samba Member
Joined: December 07, 2014 Posts: 2635 Location: Bay area CA
Posted: Tue Jul 05, 2022 5:35 pm Post subject: Re: Propane tank drain, replace, rebuild questions |
As far as I can make out, propane gas is far less of a greenhouse gas than the CO2 it would produce if burnt - so perhaps just let it go... _________________ Jim Crowther
Vespa GTS 300 |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Tue Jul 05, 2022 2:25 pm Post subject: Re: Propane tank drain, replace, rebuild questions |
is there another (better) way to empty the propane tank rather than just running the stove burners until the tank is empty? _________________ -- 1987 Westfalia automatic (Captain Vino) |
a2wolfsburggli Samba Member
Posted: Fri Apr 03, 2020 1:53 pm Post subject: Re: Propane tank drain, replace, rebuild questions |
baltik wrote: |
How did your paint hold up? |
I was under there the other day for a brake line replace. Was going to take pics and forgot. It's still white. Don't see any rust or chips. It's dirty but that's to be expected. Zero complaints.
I'll get some pics next time I pull it out of the garage. _________________ Current: '74 Type 181 | '16 Audi Q5 3.0T S-Line Chipped to ~460hp
Past:'87 Westfalia | '09 CC 3.6L 4motion "R36 wannabe" | '02 Audi TT "ALMS Edition" | '84 Jetta GLI with Autotech Supercharger | '89 Helios Jetta GLI 16v's (x2) | '95.5 URS6 | and the list goes on.
Never underestimate the entertainment value of OCD overruling Common Sense |
baltik Samba Member
Posted: Fri Apr 03, 2020 1:48 pm Post subject: Re: Propane tank drain, replace, rebuild questions |
Posted: Fri Apr 03, 2020 1:44 pm Post subject: Re: Propane tank drain, replace, rebuild questions |
That's my thread.
Your options are:
1. Hook it up to a grill or heater with an adapter hose.
B. Run the burners in the camper till it's empty.
III. Disconnect from the regulator and open it up in a deserted field. Propane is heavier than air so it WILL settle to the ground. I DO NOT recommend or endorse this in any way.
As I sated in my thread, I have a propane garage heater that I connected it to. _________________ Current: '74 Type 181 | '16 Audi Q5 3.0T S-Line Chipped to ~460hp
fishgo Samba Member
Joined: June 21, 2018 Posts: 152 Location: Madison, WI
Posted: Fri Apr 03, 2020 1:20 pm Post subject: Re: Propane tank drain, replace, rebuild questions |
Thanks for the tip. I've been poking around more and I think the smell was coming from the vent valve, which wasn't fully closed tightly. Hopefully that's the quick fix, but I still plan to replace one tank and rebuild another. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17122 Location: Brookeville, MD
Posted: Fri Apr 03, 2020 8:53 am Post subject: Re: Propane tank drain, replace, rebuild questions |
Those tanks are very robust and often just need surface rust cleaned up and the hardware replaced. You likely do not need to buy a new tank unless yours lived in the salt belt and is very crusty.
When I replaced the hardware on mine I dropped the tank off the bus and waited for a breezy day and opened the valve and let the propane come out free into the air. I am on 2 acres so I could find a place well away from any structure. The advantage of dropping the tank is you get to decide where it is safe to empty it... _________________ Dave O
The Western Syncro build
fishgo Samba Member
Posted: Fri Apr 03, 2020 8:48 am Post subject: Propane tank drain, replace, rebuild questions |
I've got dual tanks on an '83, the factory original and another unit added at some indeterminate past. Due to the age and poor appearance of the tanks, I've been thinking of replacement / rebuild of these as a summer project. However, recent events have accelerated this time frame.
I had my empty original driver's side tank filled a few days ago. This tank never had a fill problem nor leak problem but it was a trouble to fill for the first time this year (gasket on fill valve went bad and had to be replaced). Now there's a light odor of propane around that tank occasionally that I cannot locate (soapy water spray test). Odor comes and goes. I can occasionally hear a small hiss leak around the valves but cannot isolate it. The hard copper lines to the stove, fridge and Propex seem to be OK.
Passenger side tank has a propane odor when opening the operation valve. No leak when fully open or fully closed, but when turning the valve or left partially open.
I ordered a new tank already and was going to order valve parts and rebuild one of the two older tanks when I pull them off and inspect them. The better tank will get parts and paint.
Are there good rebuild threads like this one that I can also read: https://www.thesamba.com/vw/forum/viewtopic.php?t=711958&highlight=propane+tank ??
I've got one tank that was just filled. How do I "drain" the tank either before I pull it off or after I remove it from the van? Running the stove is going to last a long time to drain those 3 gallons.
Thanks in advance for your suggestions. |
