motersickle Samba Member
Joined: July 02, 2007 Posts: 12 Location: possum kingdom texas
Posted: Mon Jul 02, 2007 1:44 pm Post subject: trailer hitch |
i'vw got a 69 with T-bar style bumpers. I am looking for an trailer hitch that will work with this style bumper. if anyone knows how to build one that does not have to tie into the bumper i would like to know. any comments and or observations will be welcomed.
thanks |
ampegboy1 Samba Member
Posted: Mon Jul 02, 2007 2:09 pm Post subject: |
Hi motersickle,
My Peka/VW towbar is essentially a big A-frame which attaches with U-bolts around the rear torsion tube to do the pulling, then clamps to the frame forks and bolts to the bumper to share the vertical load.
I reckon you could rig up a similar affair with a bracket that attaches to the bumper mounts instead of the bumper itself.
HTH,
Michael |
Posted: Mon Jul 02, 2007 3:19 pm Post subject: |
ampegboy1
is it made out of flat stock or square tubing??
thanks |
Vedauwoo Samba Member
Joined: May 20, 2007 Posts: 188 Location: Boulder, Colorado
bugninva Samba Member
Joined: December 14, 2004 Posts: 8857 Location: sound it out.
Posted: Tue Jul 03, 2007 6:48 am Post subject: |
| Vedauwoo wrote: |
Hmmm, a trailer on an Air Cooled VW......
No Better way to ruin the Transmission! |
hmm...so by that way of thinking, passengers is a big no-no?
(when pulling a trailer with a type one, the brakes are your main concern, not the transaxle, which is fairly robust.) _________________
| [email protected] wrote: |
| With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Scott H Samba Luddite
Joined: August 15, 2003 Posts: 3026 Location: NorthCarolina,USA
Posted: Tue Jul 03, 2007 6:56 am Post subject: |
| Vedauwoo wrote: |
It hasn't ruined mine. _________________ Scott
| oc92 wrote: |
| I like the soul of an old car to be visible... |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5225 Location: Richmond, VA
Posted: Tue Jul 03, 2007 10:48 am Post subject: |
I can't see why the transmission would care unduly about towing a trailer. Surely a load is a load is a load to the transmission. My dad used to tow his boat trailer all day with his GT Beetles and never once had the transmission complain. I can see why applying the load brutally can upset it, but I tend to shy away from racing launches with a trailer
Anyway, the A-frame of the Peka hitch is made from L-section, with the flat part 'against' the car and the downward part towards the outside. I tried to take a picture, but even my widest lens wasn't man enough! It's more or less identical to the version for the Ghia:
http://www.thesamba.com/vw/archives/manuals/misc.php
The design brings two nice bonus features - since it passes under the sump, it offers some protection from large things like speed bumps. Believe it or not, it also stiffens up the back end a little, resulting in a slight but noticeable improvement in 'chuckability'!
Michael |
Posted: Tue Jul 03, 2007 12:23 pm Post subject: |
Folks will say, and probably have towed all sorts of things....but....one thing I have learned when it comes to trailers and weights and such is that most folks have no clue and/or never check the actual weight...they just assume they are ok....many do not even consider the weight of the trailer it self in that 882 lbs. Depending on what you have, you may be ok or you may be overcapacity with the trailer hooked up alone. _________________ 1974 Beetle
Beetle's Big Brother
Junkwaffle-181 |
Posted: Tue Jul 03, 2007 2:39 pm Post subject: |
I've got a trailer that is a diamond plate aluminum tool box that is mounted on torsion bar axles. I have pulled it all over the country with my stock HD motorcycle. The tongue weight isn't over 60# so i think it will pull all right. I appreciate everyone's input. I came up with a plan and started putting it together today. I'll let ya'll know hwo it turns out. Once again thanks everyone.
G |
GA_Boy Samba Member
Joined: October 10, 2006 Posts: 1405 Location: Jefferson, GA
Posted: Tue Jul 03, 2007 4:33 pm Post subject: |
| motersickle wrote: |
G |
I wouldn't worry about the tranny as long as it is properly lubricated, but I would keep the RPM's up on long uphill pulls to keep the heads as cool as possible. If I were going to add any one gauge it would be a CHT gauge.
Marvin |
Posted: Tue Jul 03, 2007 8:22 pm Post subject: |
G |
Have any pictures of the trailer? _________________ Scott
| oc92 wrote: |
Posted: Wed Jul 04, 2007 8:23 am Post subject: |
| i can email you some pictures of the trailer if you would like. I don't know how to insert them in to this reply or if it can even be done. Send me an address and i would gladly forward some pics. |
Posted: Wed Jul 04, 2007 7:33 pm Post subject: |
PM sent. Thanks! _________________ Scott
| oc92 wrote: |
Posted: Fri May 08, 2015 12:14 pm Post subject: |
only 8 years later but here are the pics
[/img] _________________ "You may all go to hell and I will go to Texas" Davy Crockett |
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 1010 Location: Sacramento, CA
Posted: Fri May 08, 2015 9:56 pm Post subject: |
| I'd like to see how you have that mounted underneath. |
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 928 Location: los angeles
Posted: Fri May 08, 2015 11:10 pm Post subject: |
| You da man! |
Posted: Mon May 11, 2015 7:01 am Post subject: |
| mikeonthebike wrote: |
Next time i have it up in the air i'll take a pic and post it
i promise it will not take me 8 years this time _________________ "You may all go to hell and I will go to Texas" Davy Crockett |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5874 Location: Wamego, Kansas, USA
