SGKent  Samba Member
Joined: October 30, 2007 Posts: 43009 Location: at the beach in Northern Wokistan
Posted: Sat Jul 11, 2020 3:14 pm Post subject: Loctite Teflon thread sealant |
Just as an FYI to those who will use it, the white stuff - I think it is Loctite 565. It holds. I used it on case bolts when I built the engine some 10 years and 2200 miles ago. Took the case to Del's Machine Shop here and they washed it for me. The thread sealant did not come off things. No problem, I've got to super clean the oil passages anyway with the pressure washer so I'll hit the remaining thread sealant with a thin pencil beam of water at 2800 PSI. Nope. It still does not come off even under a direct stream of water at it for 15-20 seconds. That water will cut a hole in wood, eat into concrete, take paint off things if you direct it at something painted for too long... . Nope, the thread sealant does not budge. I'll get it off with solvent, a wire brush and scraping but for it not to come off with that kind of water pressure amazes me. It probably would require glass beading to get it off and that isn't smart with an engine block or case. Although the factory sand casts many things, one small piece of sand or a glass bead left in an oil passage could really ruin your day. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Angus II Samba Member
Joined: June 01, 2016 Posts: 724 Location: Mammoth Lakes Ca. 93546
Posted: Sat Jul 11, 2020 4:25 pm Post subject: Re: Loctite Teflon thread sealant |
| Hello, You need to drive that bus more.... built engine some 10 years ago and (only) 2,200 miles? |
Posted: Sat Jul 11, 2020 5:22 pm Post subject: Re: Loctite Teflon thread sealant |
| Angus II wrote: |
My bus got well over than in just over 2 1/2 days a dozen years back. |
SGKent  Samba Member
Posted: Sat Jul 11, 2020 5:38 pm Post subject: Re: Loctite Teflon thread sealant |
Yes - the original plan was to build as bullet proof an engine that I could, and take it on a US tour. That might still happen but not this year, maybe next. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5874 Location: Wamego, Kansas, USA
SGKent  Samba Member
Posted: Sat Jul 11, 2020 8:36 pm Post subject: Re: Loctite Teflon thread sealant |
| vwwestyman wrote: |
| Curious why you're tearing it down again? |
Finally got around to putting the new HAM heads on. Seems a waste to be that far and not split the case. Also have a new t4 case. I have to carefully compare it to the FI case tomorrow and make a decision which one to use. Frankly - this is the engine I wanted to build in 2009 but couldn't find the parts. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
SGKent  Samba Member
Posted: Tue Jan 10, 2023 4:10 pm Post subject: Re: Loctite Teflon thread sealant |
an update, the new case leaked at one of the flywheel gallery plugs. Loctite 567 did not seal the plugs that leaked but it sure was a bitc* to get them out. Had to heat at least one. Going back to the old case. Just sitting here trying to decide on what thread sealant to use. I don't remember if I used 565 originally on the old case or Permatex with PTFE. One thing I noticed was some small pocks and scratches in a couple bearings with 20 minutes run time. The case was super cleaned, as were all the passages. I am a bit concerned that some of the 567 that found its way to the end of any plugs came free and carried into the bearings, hardening along the way because of the activator. This is so draining.
565 w/activator
567 w/activator
Permatex with PTFE
Aviation gasket sealer
yada yada _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
SGKent  Samba Member
Posted: Tue Jan 10, 2023 4:39 pm Post subject: Re: Loctite Teflon thread sealant |
I wanted to add to this. The issue is that for every sealant there is a thread somewhere that says I used 565 and it leaked, or I used 567 and it leaked, or I used 565 and it never hardened even with activator and leaked. Or I put together helicopter engines and have for 30 years - I only use Aviation 800017 etc. Then there is a thread where someone says they used that and it leaked. Then someone else who has assembled Type 4 engines for 40 years as a VW mechanic says just use the Napa or Permatex teflon sealant. Ray comes along with a 3 hour read on the subject with recommendations and someone says - thanks that worked, then someone else uses the same method but gets leaks. It feels like a crap shoot. I would not feel this way but the new case leaked while sitting and no oil pressure using Loctite 567 It is really annoying not to have a definitive answer. Making matters worse, I have never had a leak with anything else like this is my life. I can't afford time and energy wise to go thru this again.
I am leaning towards using Chris's suggestion below. Hope he is enjoying his retirement. He dropped by the office unannounced one day when he was in Sacto for some classes and wanted to do lunch but I was committed all the way to the top tier of the Agency to support a critical public meeting at that time and could not get away for lunch that day. Miss him.
| old DKP driver wrote: |
| as far as sealant goes either loctite 565 or 518 |
If indeed you do find that galley plug you pointed to is leaking and it is
threaded just pull it out and reseal it with.
Loctite 518 Teflon sealant or
Napa Teflon sealant which is the same as
Permatex 545
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Tue Jan 10, 2023 5:28 pm Post subject: Re: Loctite Teflon thread sealant |
| Clean both the male and female threads well and use JB Weld. I would probably used JBW on both the male and female threads and then wipe the female threats clean of more than just a very thin surface coat and make sure the male threads don't have any JBW that is going to end up on the oil galleys. |
SGKent  Samba Member
Posted: Tue Jan 10, 2023 6:36 pm Post subject: Re: Loctite Teflon thread sealant |
I decided to use Chris's suggestion which is the Napa Thread Sealant. I may have used that on the original engine 10 years ago, I don't remember but I think so. It looks good. Also Loctite had a suggestion on one of their techpages for stubborn plugs or fittings. Put two small dabs into the female threads 180 degrees apart. It won't be enough to push a mass ahead of the plug, but enough to help seal as it goes in. I set the 3/8 to 25 ft lbs, the 5/16 to 20 ft lbs and the 1/4 to 15 ft lbs. I also used some NTPF 3/8 plugs in the NTPF threads. I bought a package as spares when I found them after the leaking engine was built. These 3/8 were all cut with a NTPF tap also so I don't know why that new case leaks. I have a solution for that in time - weld clean aluminum plugs in the 3 3/8 holes.
The one 1/4 plug was a stainless from one of the well liked vendors but the allen rounded at 12 ft lbs and I had to drive a torx bit into it to get it out. The stainless plugs are soft because the torx bit drove into it like butter. So I ended up reusing one 1/4" black steel plug. 11 plugs total. I am pretty sure this stuff will last. The old shirt I have on has some on it and has been washed maybe 25 times. It takes acetone or equal to dissolve it once it hardens. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
RWK Samba Member
Posted: Wed Jan 11, 2023 7:59 am Post subject: Re: Loctite Teflon thread sealant |
Pipe plugs seal due to distortion (mainly NPTF) of the plugs threads into one another and seal mechanically, the old days a lubricant was used (lead) to reduce the friction of the torque so that this happens easily and fills the gaps not crushed together, no sealant of any kind will be at this point.
In a casting it is not done so easily, excessive torque can break (or flare the hole) in the casting or crack it, also the treads can crack, because you cannot torque plugs enough to do this. What works well is Loctite sleeve retainer, (green, 680?) it fills the gaps and hardens, like the JB comment above.
Sleeve retainer was suggested by Berg for the fittings because sometimes you cannot tap or turn the fittings (main oil galley fitting) to where it needs to be. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5331 Location: Southern AB
Posted: Wed Jan 11, 2023 8:46 am Post subject: Re: Loctite Teflon thread sealant |
most of the Loctite sealants are anaerobic so they won't harden up on outer surfaces. that's the beauty of them if some squeezes into the engine it should wash out with the first start up. Of course, unless you're using activator to artificially harden it, then all bets are off.
The last time I disassembled mine there was no sealant in the case anywhere, I used 515 gasket sealant, and blue thread lock, and 565 thread sealant for plugs.
Now if you want a structural adhesive that works like a superglue on steroids Loctite HY4070 is a great product with a 60 second setup time, Gap filling up to 0.2 in (5 mm). I used it to glue my shortened stacks onto the CB filter housings a couple years ago, they are still stuck solid.
https://www.henkel-adhesives.com/ca/en/product/structural-adhesives/loctite_hy_4070.html
_________________ 1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23600 Location: Oklahoma City
Posted: Wed Jan 11, 2023 12:02 pm Post subject: Re: Loctite Teflon thread sealant |
The problem with ALL...ALL...ALL...sealants (especially thread sealants)...unless they are actually an adhesive and not really a "sealant".....is that all of them have a limitation on what "cross section" of gap they can fill.
This has to to do with a combination of items like solids content, elasticity and tensile strength of the film. You can also add in....how well that product holds up against oil, fuel and solvents.
The wild card(s) on top of all of those items.....are:
1. Whether the sealant is "anaerobic". This goes back to gap size. If these are anaerobic sealants and you have widely varying gap in threads or on sealing surfaces that allow access to air/oxygen....the sealant will be weak and may never fully cure.
If it comes in contact with oils and fuel before it cures ...usually they will fail.
2. How clean the surfaces are that you are applying the sealant to. Oils are obvious....but if the surfaces are textured and/or have anodizing or an oxide coating like black oxide....those are porous and entrain oxygen. That will either grossly slow down anaerobic sealants or make them fail.
3. Moisture...humidity. If its humid where you are assembling and you have anaerobic sealant ...getting humidity mixed in is the same as oxygen. If you are working on cold parts that are below dew point in the room you are working...you get condensation on the parts. Thats moisture....thats an anaerobic failure waiting to happen.
4. If the sealant you are using happens to be epoxy based....humidity can kill it.
Lastly.....if the adhesive/sealant you are using IS anaerobic....if you do some research you will find that whether they are alkylene glycol based (or similar) or methacrylic based (or similar).....they actually cure fairly slowly just in the "anaerobic" (meaning without oxygen) state. This is why they dry very slowly in the bottle.
They cure MUCH more rapidly when they are applied to METAL....in an anaerobic state (meaning tight gaps that exclude/push out oxygen). The metal ion charges are a catalyst.
And....it matters what type of metal. Some catalyze the sealant faster or slower. For instance....fasteners that are too heavily plated with zinc or parts that are actually galvanized...actually can inhibit- slow down.... the cure of anaerobic sealants.
This does not mean that they will NOT cure....but if they are not cured before you get oil and fuel on them they will fail.
Ray |
SGKent  Samba Member
Posted: Wed Jan 11, 2023 3:27 pm Post subject: Re: Loctite Teflon thread sealant |
all the plugs are in and look good. Cylinder studs are in. I'll give it a day to set then try a little compressed air in the galleries to see if any leaks show up (soapy bubbles at plugs) _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Ry-dog Samba Member
Joined: May 31, 2003 Posts: 494 Location: Lunenburg, MA
Posted: Mon Feb 20, 2023 12:11 pm Post subject: Re: Loctite Teflon thread sealant |
| SGKent wrote: |
| I decided to use Chris's suggestion which is the Napa Thread Sealant. |
Was this the thread sealant you used SGkent? This part number is 54540, could not find the 545. This stuff does not indicate that is has teflon in it. I'm looking for the best thread sealant I can use for my full flow connections.
_________________ '70 Westy
'14 Jeep Grand Cherokee EcoDiesel |
SGKent  Samba Member
Posted: Mon Feb 20, 2023 1:50 pm Post subject: Re: Loctite Teflon thread sealant |
I think it was 565 in a tube. This time I went with sealant from NAPA since that did not leak on the old case. I am hoping it will not leak this time either. I suspect the new case has a flaw in that area that is letting oil around the threads. My fix on the new case when I get around to it will be to have some non-anodized aluminum plugs tigged in.
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Ry-dog Samba Member
Posted: Mon Feb 20, 2023 7:38 pm Post subject: Re: Loctite Teflon thread sealant |
Thx for the info SGKent. Which NAPA sealant? I was at my NAPA today and saw a few NAPA sealants, but wasn't sure if it was the type that was in a tube or in the brush can. Hoping to just pick it up locally rather than order it if possible. Thanks _________________ '70 Westy
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1135 Location: wherever my baywindow takes me.
Posted: Tue Feb 21, 2023 2:30 pm Post subject: Re: Loctite Teflon thread sealant |
I've had good luck with the loctite thread compounds. I can get them through my job so it's convenient as well. But I also use a compound called Rector seal. excellent product and in my opinion better suited for use on engines and automotive systems requiring a thread sealant.
S:Paid:GGL:CSM-2293:99F1R6:20501231&gclid=CjwKCAiA9NGfBhBvEiwAq5vSy6nF3xxQjXyHdJnsnoxFpJHqeSA6wC7T2Wxej-EpS_-Q6qUYf2Q78xoCG0kQAvD_BwE&gclsrc=aw.ds" target="_blank">https://www.grainger.com/product/4YRW3?gucid=N:N ...lsrc=aw.ds
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5573 Location: Holland, MI
Posted: Tue Feb 21, 2023 4:01 pm Post subject: Re: Loctite Teflon thread sealant |
Lately I have really been liking Gasoila soft set for threaded joints.
I also have good luck with anaerobic hydraulic sealants. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
SGKent  Samba Member
Posted: Tue Feb 21, 2023 4:28 pm Post subject: Re: Loctite Teflon thread sealant |
the NAPA in a white can. Made by Permatex I think. I'll take a photo in a while and post it. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
