DSVW Samba Member
Posted: Wed Aug 05, 2020 9:10 pm Post subject: Tail Light Lenses |
Hi, I am looking for a set of tail light lenses for my 1974 Thing. Anyone have any recommendations? Thanks. |
Semper_Dad Samba Member
Posted: Thu Aug 06, 2020 3:20 am Post subject: Re: Tail Light Lenses |
DSVW wrote: |
The tail lights are the same found on 73-79 Beetles. Affectionately referred to as "Elephant feet". Stock or repro, they pretty much look the same outside. The insides can be quite different and are probably not interchangeable between manufacturers. Lens shades can also vary between manufacturers. I suggest buying a matching pair at the same time.
Depends on what you want to do. Original stock tail lights were side specific. Had to do with the side reflectors I believe. Check both theSamba's Thing and Type 1/Bug - 1968-up classifieds.
Plenty of aftermarket sources with varying levels of quality. There are the 4 bulb styles and there are the 3 bulb styles where two of the circuits are combined into a dual bulb. Some of today's repos are no longer side specific. Hella has the reputation of being the better of them all. Some aftermarkets have a problem where lens fade or prematurely crack.
I ended up purchasing a set of 4 bulb, side specific lights from CIP. It's an all plastic model that includes the wiring. CIP calls it their "good quality" version.
There was a time when a flat or dome version (low profile) was being produced. Looks nice if you are going for a cleaner look. I don't haven't seen them advertised for a while. I mark it down as a passing fad. Many suppliers discontinued tham due to customer complaints.
Example of flat tail light (Stolen from G.I. Joe's Photobucket)
_________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 483 Location: Grove City, OH
Posted: Thu Aug 06, 2020 5:45 am Post subject: Re: Tail Light Lenses |
The low-profile or flat elephant foot style tail light assembly looks cool and is certainly more sleek however when you replace the original elephant foot style with the flat you completely lose the side marker functionality that the original style provides since it protrudes from the rear so much. _________________ '74 Thing
'83 Westfalia |
DSVW Samba Member
Posted: Thu Aug 06, 2020 3:27 pm Post subject: Re: Tail Light Lenses |
Thanks. I am looking for the lenses only. So I can buy 73-79 Super Beetle lenses and they should fit right on? |
Posted: Thu Aug 06, 2020 3:29 pm Post subject: Re: Tail Light Lenses |
DSVW wrote: |
Yes, but....some lenses may require a little modification to fit. I notice a disclaimer on some of them that the lens deflectors need to be trimmed or removed to fit the stock 1973 & 1974 tail light bases. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
DSVW Samba Member
Posted: Thu Aug 06, 2020 5:45 pm Post subject: Re: Tail Light Lenses |
OK Thanks. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76977 Location: Sneaking up behind you
Posted: Thu Aug 06, 2020 5:53 pm Post subject: Re: Tail Light Lenses |
Semper_Dad wrote: |
They filled with with water and were not as visible a stock.
If you only need the lenses and still have the original bases... these are used and cheap.
https://www.thesamba.com/vw/classifieds/detail.php?id=1925065
These are complete.
https://www.thesamba.com/vw/classifieds/detail.php?id=2388033 _________________ Glenn
Member #1009
#BlueSquare |
obus Samba Member
Joined: March 08, 2001 Posts: 11073 Location: just off Garden State Parkway Exit 81
Glenn Mr. 010
Posted: Fri Aug 07, 2020 5:54 am Post subject: Re: Tail Light Lenses |
obus wrote: |
it sucks trying to find good used original us style elephant ear tail lights |
NOS... even better
Member #1009
#BlueSquare |
obus Samba Member
DSVW Samba Member
Posted: Fri Aug 07, 2020 11:09 pm Post subject: Re: Tail Light Lenses |
Is the lens deflector that needs to be trimmed or removed part of the actual lens or is it part of the other component that holds the bulbs. I see 2 fins that look aluminum that are attached to the socket side (non lens side). The tail light lens actually slides over them almost like a guide. Is that the part that needs to be trimmed? I would rather not have to cut anything but if it is my only option than so be it. |
Thing68 Samba Member
Joined: December 14, 2019 Posts: 71 Location: California
Posted: Sat Aug 08, 2020 7:51 am Post subject: Re: Tail Light Lenses |
I just installed some new after market lenses and had to trim the tin work that is on the lens. After trimming they fit great. |
DSVW Samba Member
Posted: Sat Aug 08, 2020 9:26 am Post subject: Re: Tail Light Lenses |
Thing68, Did you have to trim much off? Also, were did you pick up your lenses? Thanks. |
Posted: Sat Aug 08, 2020 10:15 am Post subject: Re: Tail Light Lenses |
I got them from SoCal auto parts. I just snipped of a little at a time until they fit. I took off about a 1/2 inch, maybe a little less. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6627 Location: Houston, Texas
Posted: Thu Sep 03, 2020 8:58 pm Post subject: Re: Tail Light Lenses |
Hella was making Universal Elephant lenses a while back in Mexico. I haven't heard that they stopped yet. You can get the usual color or smoke lenses. They are all available in the classifieds. _________________ www.vwnos.com [email protected]
jakokombi Samba Member
Joined: August 15, 2010 Posts: 779 Location: Milwaukee
Posted: Fri Sep 04, 2020 12:23 pm Post subject: Re: Tail Light Lenses |
I got these:
http://vwparts.aircooled.net/Euro-Flat-Tail-Light-Assembly-Clear-1973-Type-1-p/euro-flat-clear.htm
I sanded the edge of the lenses on a piece of flat glass to help them seal better, also I removed the silver paint around the frame with paint thinner.
I then painted the upper clear portion yellow on the inside with Krylon Stained Glass paint, the outside got a UV protective coating.
This winter I may coat the red portion too, as they seem a little pink to me when lit.
_________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
kenj06 Samba Member
Posted: Sun Oct 08, 2023 7:16 am Post subject: Re: Tail Light Lenses |
Recently ran across the last post with the Krylon stained glass spray paint and decided to give it a try on my heavily faded lenses.
I should have taken before pictures but take my word for it, the lenses only had a little orange left in them on the edges.
I washed the lenses down with soap and water and let them dry for a few hours and taped up any areas I didn't want to spray. I must have put around 12 light coats on them, letting each coat dry anywhere from 5 to 15 minutes, I kept checking the outside of the lenses to check the coverage and color. I let them dry fully and reinstalled.
Turn signal shows well through the paint and its actually orange again instead of white. Made a huge difference in the looks as I stop to admire them each time I walk past. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17296 Location: Left coast, Canada
Posted: Tue Oct 10, 2023 3:59 pm Post subject: Re: Tail Light Lenses |
kenj06 wrote: |
Thanks for bringing this post up. Going to try the stained glass paint.
You can improve the orangeness of your turn signals by replacing the bulb with an orange one. Or, paint your existing bulbs with your orange stained glass paint! _________________
kenj06 Samba Member
Posted: Tue Oct 10, 2023 5:46 pm Post subject: Re: Tail Light Lenses |
Bruce wrote: |
You can improve the orangeness of your turn signals by replacing the bulb with an orange one. Or, paint your existing bulbs with your orange stained glass paint! |
Thanks for the idea on the orange bulb. I think I have one in the bulb bin I can try out or plenty of paint left to try it out also.
Good luck with the project. |
