how to check a used oil cooler to see if it works before install
vwuguy Premium Member
Location: southwestern ontario, on and netherlands and bc
vwuguy is offline
PostPosted: Wed Dec 09, 2020 9:35 pm    Post subject: how to check a used oil cooler to see if it works before install Reply with quote
so you got a 1600 your putting together for your 68-79 bus well here is how to preliminary check used oil cooler before installing it..besides just bolting it on to the one on the test bench..
Smile please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy
aeromech
aeromech is offline
PostPosted: Wed Dec 09, 2020 9:53 pm    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
Nonononono
You mount an adapter to the cooler and pressurize it with shop air. What a loser this guy is.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
deepcflea
deepcflea is offline
PostPosted: Wed Dec 09, 2020 9:54 pm    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
It would be better, if while in the water, plug one hole with your finger, then run some LP air through the other hole and check for bubbles.
1978 Bay Window Double Cab (1600cc) - Marilyn
https://www.thesamba.com/vw/forum/viewtopic.php?t=...005b041ddd
Formerly owned VW's
1983 Westfalia
1956 Oval Ragtop
1967 Bug
1970 Ghia
1969 Buggy
Abscate
Abscate is offline
PostPosted: Thu Dec 10, 2020 4:47 am    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
I can’t find my oil cooler because it’s covered with snow. Googling “snow covered oil cooler” doesn’t help. Is there any expertise out there?
Mispeld
Mispeld is offline
PostPosted: Thu Dec 10, 2020 5:40 am    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
Idea I have seen a guy use a leaf blower to clear snow off a bus. Perhaps a leaf blower can be used to search for it? Cool
Tom
1977 Westy. 2.0 Fuel Injected.
vwuguy is offline
PostPosted: Thu Dec 10, 2020 7:16 am    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
compressed air only gets you covered in oil and water and its air cooled..although it may be be funny to watch a noob someone blow air in it and get covered with oil and water. lol the theory is if it fills full of water the oil in the cooler will push the water out as the oil is a different density than water..
works great to check out old oil coolers..I highly reccomend changing those seals in the adapter before installing.. and if you see the cooler bubbling you can use a brass weld or epoxy to fix it like a radiator if you want too.. up to you
Abscate
Abscate is offline
PostPosted: Thu Dec 10, 2020 8:53 am    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
That search just brings up turbochargers for Nissans
rastomas
rastomas is offline
PostPosted: Thu Dec 10, 2020 9:04 am    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
Air cleaner? Really?
"It's not 'You are what you eat', it's 'You are what you don't SHIT". Wavy Gravy.
'74 Westy
Q-Dog
Q-Dog is offline
PostPosted: Thu Dec 10, 2020 10:26 am    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
Put the dry oil cooler into the same container but without water in it. Fill the cooler with solvent and walk away. Whe you come back in 15 or 20 minutes you will know if the cooler has a leak. Bonus ... when you pour out the solvent you will see how much gunk is inside the oil cooler and then decide if it is clean enough to use on a new engine build.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
SGKent Premium Member
SGKent is offline
PostPosted: Thu Dec 10, 2020 1:03 pm    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
What you need is an O-kooler Black Hound. They are trained to sniff out hidden oil coolers and other parts. Here is one pointing out a rare vacuum can.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
Wildthings
Wildthings is offline
PostPosted: Thu Dec 10, 2020 2:54 pm    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
Since the oil cooler sees 80-100 psi on a winter's morning startup, then check it with air at the same pressure. You can just spray the cooler with soapy water if you want to be able to see bubbles. With the way you are doing it, you could easily miss a minor and maybe even a fairly major leak.
hazetguy
hazetguy is offline
PostPosted: Thu Dec 10, 2020 3:48 pm    Post subject: I lost 50 IQ points by watching that video Reply with quote
for those that might find this thread in the future, ^^^^^PLEASE DO NOT DO ANYTHING MENTIONED IN THIS POST (except changing the seals between the cooler and adapter, that is one sane suggestion). bad oil coolers should be scrapped, period.
buy or make an inexpensive OIL COOLER PRESSURE TESTER, you know, like VW recommends and even made a special tool to check coolers. you can even adapt it so you can use a bike pump to pressurize it.
tester made of scrap aluminum block and about $10 worth of other materials:
factory special tool:
Abscate
Abscate is offline
PostPosted: Thu Dec 10, 2020 7:07 pm    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
I still have too much snow on my Bus to find my oil cooler, and my leaf blower Is on loan as a cheap as turbo.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu Dec 10, 2020 9:09 pm    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
That's how I was able to get back to San Diego so fast!
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
Abscate
Abscate is offline
PostPosted: Fri Dec 11, 2020 3:06 am    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
Wait a minute, how can you sniff vacuum? This sounds suspicious.
SGKent is offline
PostPosted: Fri Dec 11, 2020 11:26 am    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
That is what makes their skill so amazing. Smile I've got one right now behind me fluffing the carpet, they do it all over the house - fluff the carpet then lay down in the middle of where they were fluffing - maybe the house was built on a landfill of old oil coolers.
George Carlin:
1971 deluxe (sold)
1977 deluxe
Abscate
Abscate is offline
PostPosted: Fri Dec 11, 2020 12:58 pm    Post subject: Re: how to check a used oil cooler to see if it works before install Reply with quote
Do you have one that can find halibut? I’ve lost mine since I took the ferry...
