How to install new mirrors on your baywindow bus 1968-1979
vwuguy Premium Member
Location: southwestern ontario, on and netherlands and bc
vwuguy is offline
PostPosted: Fri Jan 29, 2021 4:52 pm    Post subject: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
Smile
Smile please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy
richparker
richparker is offline
PostPosted: Fri Jan 29, 2021 6:06 pm    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
Erb, everybody knows you have to angle those mirrors in order to fit in with the cool kids around here…🙄
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Jan 29, 2021 7:35 pm    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
pulls tape off (takes paint with it Laughing )
puts new mirror on without gasket
oh, my head....
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Angus II
Angus II is offline
Hello,
An 9/16 wrench on a"made in China" part? Humm?. OK....
And, Do you really have a (PPE) Covid face mask on?
You're alone, outside. In the wind....
You've got to be fucking kidding me.
Well, at least. You didn't take the doors off the bus to install the mirrors. I've got to give you a plus for that, this time.....
Globespotter
Globespotter is offline
PostPosted: Fri Jan 29, 2021 11:46 pm    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
My mirrors are loose on the arm. How do I tighten them?
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
rsbadura
rsbadura is offline
PostPosted: Sat Jan 30, 2021 12:52 am    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
failed Shame on you
I do not see the plastic washer VW #311857543 below the mirror to protect the door paint:
see 082-00 part 12: http://www.michaelknappmann.de/bulli/michaelk/vw_bus_d/fiche/t208200.html
Before mounting it, a little bit of grease or cavity protection putting inside the door hole would be a good idea.
It's strange how people today require a video for every simple task not only in this case... it looks like I'm getting old Embarassed
I guess these are only reproductions - and not original VW?
(originals have a VW sign and part number at the nut to the door side - only visible if unmounted).
Only as an idea (never had this issue):
have you tried to put an extra washers (soft metal, nylon, plastic) below the nut to get some more friction drag?
In the original there is a metal spring inside to get this friction drag.
Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools collection
Mberglo
Mberglo is offline
PostPosted: Sat Jan 30, 2021 7:10 am    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
Ten minute video to screw a mirror onto a door?
jakokombi
jakokombi is offline
PostPosted: Sat Jan 30, 2021 9:11 am    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
To be fair, he did both sides.
70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja
Angus II
Angus II is offline
PostPosted: Sat Jan 30, 2021 10:29 am    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
Hello,
If what rsbadura said wasn't the problem. And, we are both getting old Stephen...
If the mirror won't stay in place on the arm and you have too readjust it to see(mirror loose on arm) as I understood the issue. You will have to remove the glass from the housing and tighten the nut too increase the pressure.
Here are some pictures of whats behind the glass
You need to tighten up the ball and socket joint/connection. Ignore the drivers side note on the mirror housing(they will fit any side) it was to written in reference too the arms which are directional.
Globespotter
PostPosted: Sat Jan 30, 2021 9:09 pm    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
Angus II wrote:
Hello,
Thanks Angus - yes that's the problem. I wonder if pulling and turning the mirror could possibly tighten the nut without removing the glass? They are re-pops but in good shape. It just annoys my how loose they are. Not sure how easy or wise it would be to try to remove and replace the glass.
Angus II
Angus II is offline
PostPosted: Sun Jan 31, 2021 11:37 am    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
Hello,
You may give that a try.
But, I should have posted more pictures....
The stud that makes up the connection is squared off at the base keeping the cupped part of the ball and socket from moving.
It's not hard to cut the outer edge of the mirrors seal/gasket. And to reinstall mirror use vinyl caulking compound not silicone(it's easier to clean up). And, if you do happen to break the glass, a glass shop can cut a piece to fit. It only cost me $4 each to have new glass cut too size.
Good luck with the project.
I'd rather fix an OEM part than buy aftermarket parts....that's just the way I am.
Globespotter
PostPosted: Sun Jan 31, 2021 2:00 pm    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
Thanks Angus. Appreciate the details!
Mberglo
Mberglo is offline
PostPosted: Sun Jan 31, 2021 2:13 pm    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
oh, my head....
Where can I find these gaskets? My old mirrors didn't have them.
hazetguy
hazetguy is offline
PostPosted: Sun Jan 31, 2021 2:16 pm    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
Mberglo wrote:
[Where can I find these gaskets? My old mirrors didn't have them.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211857519
https://www.eisparts.com/gasket-outer-rear-view-mirror-base-bug-68-79ea-8746.html
http://www.bustoration.com/Mirror-Arm-Gasket-Outside-68--EACH-9-9_p_2007.html
Mberglo
Mberglo is offline
PostPosted: Sun Jan 31, 2021 2:25 pm    Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 Reply with quote
got it. Thanks.
