metz Samba Member
Posted: Sat Sep 25, 2021 3:53 am Post subject: Mystery wheel – ID? |
I've got this wheel that looks like a Crestline or Calpart, but the rear ring is steel. There's no branding or marks on it. Does anyone know what it is?
_________________ 68 panel
64 ghia coupe |
OvalinAz Samba Mini Tech
Typ3nut Samba Member
Joined: October 08, 2002 Posts: 1192 Location: MI, MotorCity ManCave
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3918 Location: In Molinya Orbit
VolksRodT Samba Member
Posted: Sun Oct 10, 2021 7:37 pm Post subject: Re: Mystery wheel – ID? |
Hey, Metz;
This isn't VW specific, but hope it helps.
While I can't ID the wheels' maker, it's not just the rear portion of the rim that's steel. The whole rim is steel, w/an aluminum piece either cast into the rim, or attached onto it(usually steel tabs sticking out of the spokes that were cast into the aluminum "face" & then welded to the rim.). I had some like that awhile ago, but sold them. Look closely at the front of the wheels' face & along its' side edge, you'll see the separation line between the steel rim & cast Al face. They were made by a lot of manufacturers as a cheap alternative to a genuine magnesium, or even aluminum, wheel. I don't have a list anymore, but Mickey Thompson, E.T.(I think), Fenton, U.S.Mag, Senter, & others made some wheels like this. Sold by J.C.Pennys, Sears, Honest Charlie, AutoWorld, J.C. Whitney, et-al. I would guess manufactured in the late 60's -> 70's, but the slightly sharp-edged spoke is of a later style(mid->late 60's, copying the American 5-spoke wheel, made both in Mag & Alum.), & a rounded spoke style is reminiscent of early->mid 60's real mag. Both styles used straight spokes, mostly for drum brakes, unlike the ~ mid 60's Torque Thrust D wheel that had curved spokes to clear disc brake calipers. You could also search the H.A.M.B. for some more info, if you can't find what you need here. BTW, do NOT mention these are for a VW on the HAMB, all I'd give out is wheel size, width, & b.c. size.
Marcus... |
metz Samba Member
Posted: Mon Oct 11, 2021 3:30 am Post subject: Re: Mystery wheel – ID? |
Thanks for all the input.
Very good info, Marcus, appreciate it. I guess even though they might be rare-ish now, they are not particularly sought after and therefore not worth much.
@sputnick60 - Those have an edge on the spokes, the one I have has rounded shapes.
@typ3nut - Looking at the link I found that they actually have the same picture and rim under both ET Rocket and Crestline. I think that picture is the one that looks the most similar.
@OvalinAz - Agree with Typ3nut, the openings looks slimmer. _________________ 68 panel
64 ghia coupe |
Posted: Fri Oct 15, 2021 10:59 pm Post subject: Re: Mystery wheel – ID? |
Hey, Metz;
Iffen those are old ET's, they are not junk. ET made some very high quality wheels. Just because they are not sought after, nor hi-buck, doesn't mean they're crap. Worth is a very subjective thing, lots of different meaning(s) to different people. Resale, well... IDK... ??? Steel rims have some advantages over mag or aluminum. While I'm not a fan,(but I do like those) due to the weight & mostly the "thick" look to the face, iffen you like them, clean 'em & run 'em. If you like the look, & these are better than most of their ilk, they are worth beautifying. They are most likely somewhat rare, as in not many left today, so *may* be worth a real rebuild consisting of proper disassembly & separation of the center section & rim. Then either rechroming the original rim, or re-rimming w/a pre-chromed rim, current width or +/-, your choice meaning you also get to set the backspace as wanted/needed, & welding back in the center section. Can leave the center as-is, fully polished, or painted.
Can always just derust the rim as best you can, epoxy paint it, call it a day. Will work for a good long time.
So, advantages:
Good looking 5spokes.
You have them.
They don't cost the earth.
Not sought after, so less theft-prone. Although, I'd still run McGuard cloverleaf locks. Keeps the assholes sorta-honest.
Remember, the rim thickness on a steel rim is thinner, so that equates to abit more room for larger brakes, either drum(finned ? ) or discs. Granted, no room like 18"s, but a whole lot more than a 15" wheel made in aluminum or mag, since those need much more section thickness to keep reasonable strength compared to steel.
Steel rims are stronger & can be bent/hammered back into shape after an "oops", iffen it's not too bad. Although iffen it takes out the AL center, you're SOL.
BTW, you could consider spun Al rims, but you'd have to have the AL center part welded to the rim, not the steel tabs. NBD, just need to plan & compensate for it. Also, you'd have to have the outside wheel edge done to match the steel wheel, so's the center lip will fit correctly. Or a larger rim, 16'-17" but again, the inside center drop will have to match the steel wheel to make it work, + you'll have to be very creative to get the outside rim edge contoured to work w/the 5spoke center. Lots of work... ;( .
All in all, a nice score.
Marcus... |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Oct 20, 2021 8:58 am Post subject: Re: Mystery wheel – ID? |
The "first generation" AKA Fat Lip Rivieras (GT Mags) were constructed the same way- Aluminum face over steel rim.
When taking them to a tire shop- they'll need to select valve stems the seal against the inner steel band, and protrude through the aluminum skin. Not a nightmare for a competent shop- but make sure your can still get an air chuck on them! _________________
EverettB wrote: |
FU#5 |
metz Samba Member
Posted: Wed Oct 27, 2021 5:37 am Post subject: Re: Mystery wheel – ID? |
Thanks for the insight. Very useful!
I actually only have the one. I think I bought it back in the days as a spare for my set of Crestlines. Or, at least what was sold to me as Crestlines, but these are also unmarked.
As much as I would love to run them, they don't fit by a longshot on neither my Early bay or Ghia.
Would look sweet, though.
64 ghia coupe |
