Joined: January 29, 2003 Posts: 129 Location: College Park, MD
Posted: Fri Jul 02, 2004 5:21 am Post subject: Air Conditioning in Any VW! |
This seems like it would be a cool thing to have if you really wanted some AC in your bus for those real long trips or something. If it actually works.
http://www.compactappliance.com/xq/JSP.detailmain/...roduct.htm _________________ Stephen
"Reach out your hand if your cup be empty,
If your cup be full may it be again..." |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6635 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Fri Jul 02, 2004 6:08 am Post subject: |
It's just a fan that sets on top of your ice chest.
That's giving me some ideas... I've got a bunch of 12v case fans just collecting dust...  |
Posted: Fri Jul 02, 2004 6:17 am Post subject: |
Yeah I started thinking the same thing. I have a bunch of case fans that would work just as well probably. I'll make the thing for like 15 bucks! _________________ Stephen
westy78 Samba Member
Joined: August 20, 2002 Posts: 2005 Location: Portland OR
Posted: Fri Jul 02, 2004 6:56 am Post subject: |
It might work but.... Unlike a normal AC unit that removes the humidity from the air making things more comfortable this method will actually add moisture into the air. Sure it may be cooler but that "sticky" feeling in the air will go up making it *feel* warmer. Cool idea though. _________________ Jasan C.
'78 Westy
VW Campmobile, it goes on vacation with you. |
Posted: Fri Jul 02, 2004 7:03 am Post subject: |
What about their suggestion of using 2 litre bottles that are frozen to eliminate humidity. I know there will still be condensation on the outside of the bottle but it has to a lot less then pushing the air over just ice. Do you think that will work? _________________ Stephen
bajorek Samba Member
Posted: Fri Jul 02, 2004 7:52 am Post subject: |
I don't know why this would work other than in a vERY tight space- smaller than the van. I would thing that unless you were right beside the thing that you wouldn't feel it at all. |
Posted: Fri Jul 02, 2004 8:11 am Post subject: |
The site says it cools a 7X7X5 foot space very well. So if it actually does do that I would imagine it would cool a bus down. I don't know about the humidity though. _________________ Stephen
incynr8 Samba Member
Joined: September 23, 2003 Posts: 822 Location: Soylent Green is PEOPLE!
Posted: Fri Jul 02, 2004 8:20 am Post subject: |
My paintball team has a 5 gal cooler we fill with water, and it pumps water to misters infront of a sealed motor (SUPER IMPORTANT PART!!) fan, using 110v in this case. It keeps a whole group of people cool, lowers temps about 20deg F.
The bad? It's water folks, gets stuff misty and wet, and caused condensate buildup in closed areas. We use ours outside.... |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Fri Jul 02, 2004 10:37 am Post subject: |
Imagine how fast that would melt the ice in your cooler! 1, maybe 2 hours tops!
I'd rather be hot, and have access to a cold drink, than cool for an hour, and then hot and have warm drinks. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
jahshines Samba Member
Posted: Fri Jul 02, 2004 11:17 am Post subject: |
You could fill the chest with dry ice packages |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2730 Location: Ocean Beach - San Diego
Posted: Fri Jul 02, 2004 11:53 am Post subject: |
Dry ice = no humidity, but also = a lack of oxygen in a tight space? Mammals cannot live on CO2. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
NovaHippie Samba Member
Joined: March 08, 2004 Posts: 49 Location: The Streets of the Silicon Valley
Posted: Fri Jul 02, 2004 1:13 pm Post subject: |
open one or two of the vents and lack of oxygen problem is solved. i suppose it would cut down on some of the cooling power, but not too significantly.
nh _________________ "I'm more of the shove-a-pencil-in-the-fuel-line kinda guy."
I'm almost ready... just let me fix my car. |
Bottomend Grease
Joined: September 20, 2003 Posts: 1500 Location: Smell Aye! via Nude Hamster!
Posted: Fri Jul 02, 2004 2:31 pm Post subject: |
Heres a trick I learned while liveing in Japan. It gets SUPER hot and humid in the summer. RAIN FOREST HUMID! No kidding...
Combine a one gallon bucket/container of ice water with about 1/2 container of rubbing alcohol. (It's probably 8 oz) Dip a small towel in the water mixture, roll it up and then place across the back of neck at the base of the head. I was shown this method of staying cooling during 105*/ 90% humidity heat. in southern Japan. I got so chilled I was shakeing!
If I was driveing across the desert here in USA I would bring this to stay sane. |
steponmebbbboom Samba Member
Posted: Fri Jul 02, 2004 8:56 pm Post subject: |
no kidding, i was there once and my balls were LITERALLY SWEATING |
Jealous_Zack Samba Member
Joined: June 10, 2004 Posts: 78 Location: Confusedly wandering through Tucson
Posted: Sun Jul 04, 2004 6:36 pm Post subject: |
I remember seeing some 'hang on the passenger window' type evaporative coolers on bugs - just fill 'em with ice water and the faster you drive the better you'll feel. I suppose one could build/buy the same sort of thing for a bus. _________________ Not so jealous anymore.
79 for Cruisin
78 for Parts |
Posted: Sun Jul 04, 2004 7:13 pm Post subject: |
Jealous_Zack wrote: |
I remember seeing some 'hang on the passenger window' type evaporative coolers on bugs - just fill 'em with ice water and the faster you drive the better you'll feel. I suppose one could build/buy the same sort of thing for a bus. |
Yep, swamp coolers. Thermador was one brand. They were a popular accesory back then. I see them come up in the classifieds here every once in a while. Here is a shot of a Thermador on a bug.
'78 Westy
jrodcat Samba Member
Posted: Wed Jul 07, 2004 8:15 pm Post subject: |
I'm working on a project to put a 110 AC powered window unit that is 7000 BTU's into the back doors window of my bus. It's only 12" in height so it will fit in there. A power converter that turns 12 volts into 115 AC current runs about $200 though. The trick here is to fabricate a panel to accept the unit and still have two small custom built windows on each side of the unit (so you can see out). The obsticle i'm running into is getting someone to weld me an aluminum bracket that mounts to the fabricated panel and the back door. This way you can make the installation as permanent as possible with a fully functional back door. My wife says I've been watching too much MTV Pimp My Ride!!! _________________ jrodcat |
Posted: Wed Jul 07, 2004 10:07 pm Post subject: |
pimp my ride, or Red Green.
The efficiency losses of the electric motor and DC to AC inverter just don't make any sense. |
Posted: Thu Jul 08, 2004 3:00 pm Post subject: |
What do you mean? You dont think it will work? Why? _________________ jrodcat |
