Accelerator Cable Replacement (Step by Step)
FJBLF
FJBLF is offline
PostPosted: Sun Oct 02, 2022 5:32 pm    Post subject: Accelerator Cable Replacement (Step by Step) Reply with quote
I hope you find it useful, please follow my YouTube channel.
1972 VW 181 SAFARI 1500 cc GRB Trans-axle
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Oct 02, 2022 5:41 pm    Post subject: Re: Accelerator Cable Replacement (Step by Step) Reply with quote
I would recommend bending the angled tip to more of a 90*. Many times, over the years, the tip has ovaled the hole and it can pull through when you step on the gas.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
FJBLF
FJBLF is offline
PostPosted: Sun Oct 02, 2022 7:08 pm    Post subject: Re: Accelerator Cable Replacement (Step by Step) Reply with quote
Considering that these are 50 year old cars, if the hole is oval, maybe is time to replace the part.
Mr. 010
Glenn is offline
PostPosted: Sun Oct 02, 2022 7:27 pm    Post subject: Re: Accelerator Cable Replacement (Step by Step) Reply with quote
A lot more complicated since you have to remove the cluster and disconnect the clutch cable. At that point you might as well rebuild it.
Old cars are like an onion, peel a layer and then there's another.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
