Mckinleyvillian Samba Member
Joined: July 22, 2021 Posts: 596 Location: Bristol County, MA
Posted: Fri Feb 10, 2023 12:18 pm Post subject: OE cv axles fit across WBX years |
Having trouble finding this info, but i'm needing to reboot and looks like PO had put some cheapo empis across the board.
my van is an 85 manual tin top and I've got access to OE axles and joints from an 86 manual westfalia. Any reason these won't work out?
thanks _________________ so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10462 Location: Orbiting San Diego
Posted: Fri Feb 10, 2023 4:03 pm Post subject: Re: OE cv axles fit across WBX years |
The WBX axle length was unchanged over the WBX years.
Older vans had slightly longer axles.
The Bentley only gives the lengths for the early longer ones.
The difference between early and wbx is small, something like 1/4".
Mark |
Posted: Fri Feb 10, 2023 4:24 pm Post subject: Re: OE cv axles fit across WBX years |
Awesome. This is in-line with what I was thinking. Wasn’t sure however if there were shifts between 1.9-2.1 transition. Thank you both. _________________ so many roads i know
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7300 Location: Honolulu,Hawaii and France
Posted: Sat Feb 11, 2023 8:48 pm Post subject: Re: OE cv axles fit across WBX years |
| ALIKA T3 wrote: |
I posted all axle lengths not too long ago here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9937643&highlight=axle+length#9937643
Driveshaft, axle lengths:
251501203 548mm, 091 transmission and superceded by 251501203G 094 Syncro, 548mm as well.
251501203D, 541mm 091/1+ 094 transmissions 2WD.
251501201G Syncro 16" (28 splines anyway vs 33splines)
251501203A 531mm 090 early (aircooled) Left side
251501203E 522mm 090 Left side
251501204 579mm 090 early (aircooled) Right side
251501204B 570mm 090 Right side |
that's dope. thanks. you IG is pretty rad too  _________________ so many roads i know
