What is this?
Mrdriver10
Mrdriver10 is offline
PostPosted: Thu Apr 20, 2023 7:11 am    Post subject: What is this? Reply with quote
I’m in the process of rewiring the car. Found this under the dash and can’t figure out what it is. 1966 type 3 notchback
Any help is appreciated.
andybla
andybla is offline
PostPosted: Thu Apr 20, 2023 7:31 am    Post subject: Re: What is this? Reply with quote
blinker/flasher relay
Mrdriver10
PostPosted: Thu Apr 20, 2023 7:54 am    Post subject: Re: What is this? Reply with quote
Would you happen to know what the terminals mean? Cause all I’ve searched about that they don’t have l1 l2 l3 l4
I couldn’t find a wiring diagram that referred to those terminals
GjMan
GjMan is offline
PostPosted: Thu Apr 20, 2023 11:17 am    Post subject: Re: What is this? Reply with quote
Did you check the wiring diagrams in the Technical section?
And, oh, welcome aboard.
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 20, 2023 11:45 am    Post subject: Re: What is this? Reply with quote
It's a 12 volt relay. No idea what it does, as most 66 type 3s are 6 volt. My first guess is that one of the cars PO's was trying to fix an electrical problem and didn't know what he was doing. It wouldn't be the first time something like that happened. At this point in time, it might have been an "extra" part he carried out to the car, and just left it behind.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Ossipon
Ossipon is offline
PostPosted: Thu Apr 20, 2023 12:06 pm    Post subject: Re: What is this? Reply with quote
I dug around in my pile of junk and found a 91/18 relay. It looks like a 91/17 except it has push on and not screw downs.
According to the what someone wrote on the side, 98/18 is for Fog lamps and fanfare horns. The diagram on top is almost identical except it uses 80,85,86, and 87 instead of L1, L2, L3, and L4.
OR
Just a Flashing relay
https://picclick.co.uk/Hella-91-17-Blinkgeber-Flas...11668.html
Ossipon
--Two truths in life: Volkswagens Rust and everything will die at some point --
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 /Taos 24... And don't about me and my experiences with my Dasher and Quantum
Air-Cooled Head
Air-Cooled Head is offline
PostPosted: Thu Apr 27, 2023 10:24 am    Post subject: Re: What is this? Reply with quote
Instead of starting a new topic, thought I’d jump on here, since my question is kinda the same. Found a box of engine tin and noticed something new (to me)
The one on the left is two pieces.
What’s that from?
Everything known to man has been written.
Readers are Leaders!
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Apr 27, 2023 10:43 am    Post subject: Re: What is this? Reply with quote
Guess: Type 3 industrial engine?
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Apr 27, 2023 11:05 am    Post subject: Re: What is this? Reply with quote
91 indicates lighting system. 30 is battery +, 31 is ground, L1,2,3 and 4 are light out terminals, S1 and S2 are signal inputs to energized breaker points. Looks like what we have here may be an early add- on hazard flasher unit. Only USA cars (and maybe Canada) got these in 1966/67. Since the NB was never officially imported, this may have needed to be installed to get it into USA. This could explain the screw type terminals- this could have been sourced from an aftermarket accessorizer prior to importation.
M630 was for 12 volt electrical systems, first available optionally in 1962 if memory serves.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
sjbartnik
sjbartnik is offline
PostPosted: Thu Apr 27, 2023 7:27 pm    Post subject: Re: What is this? Reply with quote
I don't think it's a flasher, my bet is fog lamp relay
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
andybla
andybla is offline
PostPosted: Fri Apr 28, 2023 3:03 am    Post subject: Re: What is this? Reply with quote
here is the same
https://www.ebay.de/itm/234788811668?hash=item36aa...R5qThvX4YQ
Pelle
Pelle is offline
PostPosted: Fri Apr 28, 2023 4:17 am    Post subject: Re: What is this? Reply with quote
What’s that from?
They are "widened" by the factory to fill the wider engine compartment introduced in August 1963.
Air-Cooled Head
PostPosted: Fri Apr 28, 2023 8:33 am    Post subject: Re: What is this? Reply with quote
Thanks!
KTPhil is offline
PostPosted: Fri Apr 28, 2023 10:17 am    Post subject: Re: What is this? Reply with quote
I think mine are not the widened style ('71). Are you sure that's it?
Bobnotch
Bobnotch is offline
PostPosted: Fri Apr 28, 2023 11:26 am    Post subject: Re: What is this? Reply with quote
Your 71 would use 1 piece already widened cooling tin.
Tram wrote:
Tram wrote:
notchboy
notchboy is offline
PostPosted: Fri Apr 28, 2023 12:15 pm    Post subject: Re: What is this? Reply with quote
The original piece in question is a 64/65 piece and is a cross over from single side draft carb to dual carb. The SSD trim was adapted for the dual carbs. The engine bay was widened due to the dual carbs in 63 as said. Anyone who has stuffed a dual carb motor in a 62/63 knows how tight it is already. If it had the electromagnet cut offs it would hit the engine bay metal - necessitating the removal of the cut offs. Even the carb linkage may hit. So when the engine bay was widened the tin was widened - Single port - two year only modified tin.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Tram
Samba Socialist
Tram is offline
PostPosted: Fri Apr 28, 2023 1:17 pm    Post subject: Re: What is this? Reply with quote
Used until the heater system was modified to include thermostatically controlled mixing boxes, at which point they redesigned the tin and elbows sometime in August 1964. So the modified wider tin was only in use about a year.
Bryan67 wrote:
Those who can- do.
